#include <pqCompositeTreePropertyWidget.h>
| | called to set the active view. More...
| template<class T > |
◆ pqCompositeTreePropertyWidget()
◆ ~pqCompositeTreePropertyWidget()
| pqCompositeTreePropertyWidget::~pqCompositeTreePropertyWidget |
◆ values()
| QList<QVariant> pqCompositeTreePropertyWidget::values |
const |
API to get/set the selected values.
What there values represents depends on the domain and the property e.g. it can represent flat indices or amr-level number or (amr-level, amr-block) pairs.
◆ setValues()
| void pqCompositeTreePropertyWidget::setValues |
const QList< QVariant > & |
values | ) |
◆ valuesChanged
| void pqCompositeTreePropertyWidget::valuesChanged |
signal |
◆ values
readwrite |
