| | called to set the active view. More...
| | This signal is emitted when the current view changes. More...
| void | changeAvailable () |
| | This signal is fired as soon as the user starts editing in the widget. More...
| void | changeFinished () |
| | This signal is fired as soon as the user is done with making an atomic change. More...
| void | restartRequired () |
| | Indicates that a restart of the program is required for the setting to take effect. More...
| template<class T > |
pqCommandPropertyWidget is used for vtkSMProperty instances (not one of its subclasses).
It simply creates a button that the users can press. Unlike other pqPropertyWidget subclasses, the result of clicking this button does not affect the state of the Apply/Reset buttons. It triggers the action prompted by the property immediately.
Definition at line 44 of file pqCommandPropertyWidget.h.
