| | called to set the active view. More...
| | This signal is emitted when the current view changes. More...
| void | changeAvailable () |
| | This signal is fired as soon as the user starts editing in the widget. More...
| void | changeFinished () |
| | This signal is fired as soon as the user is done with making an atomic change. More...
| void | restartRequired () |
| | Indicates that a restart of the program is required for the setting to take effect. More...
| template<class T > |
A property widget with a push button for invoking a command on a proxy.
To use this widget for a property add the 'panel_widget="command_button"' to the property's XML.
If the property has a "command" attribute set, then the command will be invoked immediately. If the property has no command set, then clicking the button will call vtkSMProxy::RecreateVTKObjects().
Definition at line 50 of file pqCommandButtonPropertyWidget.h.
