widget to choose a color palette to load/select. More...
#include <pqColorPaletteSelectorWidget.h>
Signals | |
| void | paletteNameChanged () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| pqColorPaletteSelectorWidget (vtkSMProxy *smproxy, vtkSMProperty *smproperty, QWidget *parent=0) | |
| ~pqColorPaletteSelectorWidget () override | |
| QString | paletteName () const |
| void | setPaletteName (const QString &name) |
| pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=0) | |
| virtual void | apply () |
| virtual void | reset () |
| virtual void | select () |
| pqView * | view () const |
| bool | showLabel () const |
Properties | |
| QString | paletteName |
| template<class T > | |
pqColorPaletteSelectorWidget is a pqPropertyWidget intended to be used in two roles:
Mode (1) is used when the widget is used for a vtkSMProperty e.g. **'Load Palette'** property on the ColorPalette proxy. In that case, the user's action is expected to update the proxy with the chosen palette.
Mode (2) is used when the widget is used for a vtkSMStringVectorProperty e.g. OverrideColorPalette property on ImageOptions proxy. In that case, the selected palette name is simply set on the vtkSMStringVectorProperty.
Definition at line 59 of file pqColorPaletteSelectorWidget.h.
| pqColorPaletteSelectorWidget::pqColorPaletteSelectorWidget | ( | vtkSMProxy * | smproxy, |
| vtkSMProperty * | smproperty, | ||
| QWidget * | parent = 0 |
| QString pqColorPaletteSelectorWidget::paletteName | ( | ) | const |
| void pqColorPaletteSelectorWidget::setPaletteName | ( | const QString & | name | ) |
signal |
readwrite |
Definition at line 62 of file pqColorPaletteSelectorWidget.h.
