pqColorAnnotationsPropertyWidget is used to edit the Annotations property on the "PVLookupTable" proxy.
#include <pqColorAnnotationsPropertyWidget.h>
| | called to set the active view. More...
| template<class T > |
The property group can comprise of two properties, Annotations and IndexedColors.
Definition at line 46 of file pqColorAnnotationsPropertyWidget.h.
◆ pqColorAnnotationsPropertyWidget()
| pqColorAnnotationsPropertyWidget::pqColorAnnotationsPropertyWidget |
vtkSMProxy * |
proxy, |
vtkSMPropertyGroup * |
smgroup, |
QWidget * |
parent = 0 |
◆ ~pqColorAnnotationsPropertyWidget()
| pqColorAnnotationsPropertyWidget::~pqColorAnnotationsPropertyWidget |
◆ annotations()
| QList<QVariant> pqColorAnnotationsPropertyWidget::annotations |
const |
Get/Set the annotations.
This is a list generated by flattening 2-tuples where 1st value is the annotated value and second is the annotation text.
◆ setAnnotations()
| void pqColorAnnotationsPropertyWidget::setAnnotations |
const QList< QVariant > & |
◆ indexedColors()
| QList<QVariant> pqColorAnnotationsPropertyWidget::indexedColors |
const |
Get/Set the indexed colors.
This is a list generated by flattening 3-tuples (r,g,b).
◆ setIndexedColors()
| void pqColorAnnotationsPropertyWidget::setIndexedColors |
◆ indexedOpacities()
| QList<QVariant> pqColorAnnotationsPropertyWidget::indexedOpacities |
const |
Get/Set the indexed opacities.
◆ setIndexedOpacities()
| void pqColorAnnotationsPropertyWidget::setIndexedOpacities |
◆ opacityMapping()
| QVariant pqColorAnnotationsPropertyWidget::opacityMapping |
const |
Get/Set the opacity mapping status.
◆ setOpacityMapping()
| void pqColorAnnotationsPropertyWidget::setOpacityMapping |
const QVariant & |
◆ annotationsChanged
| void pqColorAnnotationsPropertyWidget::annotationsChanged |
signal |
Fired when the annotations are changed.
◆ indexedColorsChanged
| void pqColorAnnotationsPropertyWidget::indexedColorsChanged |
signal |
Fired when the indexed colors are changed.
◆ indexedOpacitiesChanged
| void pqColorAnnotationsPropertyWidget::indexedOpacitiesChanged |
signal |
Fired when the indexed opacities are changed.
◆ opacityMappingChanged
| void pqColorAnnotationsPropertyWidget::opacityMappingChanged |
signal |
Fired when the opacity mapping is changed.
◆ annotations
readwrite |
◆ indexedColors
readwrite |
◆ indexedOpacities
readwrite |
◆ opacityMapping
readwrite |
