pqCameraManipulatorWidget used on "Camera2DManipulators" and "Camera3DManipulators" property on a RenderView proxy.
#include <pqCameraManipulatorWidget.h>
| template<class T > |
Definition at line 42 of file pqCameraManipulatorWidget.h.
◆ pqCameraManipulatorWidget()
| pqCameraManipulatorWidget::pqCameraManipulatorWidget |
vtkSMProxy * |
proxy, |
vtkSMProperty * |
smproperty, |
QWidget * |
parent = 0 |
◆ ~pqCameraManipulatorWidget()
| pqCameraManipulatorWidget::~pqCameraManipulatorWidget |
◆ manipulatorTypes()
| QList<QVariant> pqCameraManipulatorWidget::manipulatorTypes |
const |
returns a list for the selected manipulator types.
This has exactly 9 items always.
◆ setManipulatorTypes
| void pqCameraManipulatorWidget::setManipulatorTypes |
const QList< QVariant > & |
value | ) |
slot |
Set the manipulator types selection.
This must have exactly 9 items or less. Any missing items are treated as "None".
◆ manipulatorTypesChanged
| void pqCameraManipulatorWidget::manipulatorTypesChanged |
signal |
◆ manipulatorTypes
readwrite |
