| | called to set the active view. More...
| | This signal is emitted when the current view changes. More...
| void | changeAvailable () |
| | This signal is fired as soon as the user starts editing in the widget. More...
| void | changeFinished () |
| | This signal is fired as soon as the user is done with making an atomic change. More...
| void | restartRequired () |
| | Indicates that a restart of the program is required for the setting to take effect. More...
| template<class T > |
pqCalculatorWidget is a property-widget that can shows a calculator-like UI for the property.
It is designed to be used with vtkPVArrayCalculator (or similar) filters. It allows users to enter expressions to compute derived quantities. To determine the list of input arrays available.
CAVEATS: Currently, this widget expects two additional properties on the proxy: "Input", that provides the input and "AttributeMode", which corresponds to the chosen attribute type. This code can be revised to use RequiredProperties on the domain to make it reuseable, if needed.
Definition at line 48 of file pqCalculatorWidget.h.
