vtkPVPluginTracker Class Reference
a global manager for each processes to keep track of plugins loaded on that process. More...
#include <vtkPVPluginTracker.h>
Inheritance diagram for vtkPVPluginTracker:
Collaboration diagram for vtkPVPluginTracker:
enum  { RegisterAvailablePluginEvent = vtkCommand::UserEvent + 91 }
void RegisterPlugin (vtkPVPlugin *)
 Called by vtkPVPluginLoader after a plugin is loaded on the process. More...
unsigned int RegisterAvailablePlugin (const char *filename)
 This API is used to register available plugins without actually loading them. More...
unsigned int GetNumberOfPlugins ()
 Methods to iterate over registered plugins. More...
vtkPVPlugin * GetPlugin (unsigned int index)
 Returns the plugin instance. More...
void LoadPluginConfigurationXMLs (const char *appname)
 Called to load application-specific configuration xml. More...
void LoadPluginConfigurationXML (const char *filename, bool forceLoad=false)
void LoadPluginConfigurationXML (vtkPVXMLElement *, bool forceLoad=false)
void LoadPluginConfigurationXMLFromString (const char *xmlcontents, bool forceLoad=false)
const char * GetPluginName (unsigned int index)
 This is provided for wrapped languages since they can't directly access the vtkPVPlugin instance. More...
const char * GetPluginFileName (unsigned int index)
bool GetPluginLoaded (unsigned int index)
bool GetPluginAutoLoad (unsigned int index)
bool GetPluginDelayedLoad (unsigned int index)
std::vector< std::string > GetPluginXMLs (unsigned int index)
static vtkPVPluginTracker * New ()
static vtkPVPluginTracker * SafeDownCast (vtkObject *o)
static vtkPVPluginTracker * GetInstance ()
 Provides access to the singleton. More...
static void RegisterStaticPluginSearchFunction (vtkPluginSearchFunction function)
 Sets the function used to load static plugins. More...
static void RegisterStaticPluginListFunction (vtkPluginListFunction function)
 vtkPVPluginTracker ()
 ~vtkPVPluginTracker () override
vtkPVPluginTracker is a singleton that's present on each process to keep track of plugins loaded on that process. Whenever is plugin is loaded (either statically using PV_PLUGIN_IMPORT() or dynamically, it gets registered with the on every process that it is loaded. Whenever a plugin is registered, this class fires a vtkCommand::RegisterEvent that handlers can listen to, to process the plugin.
Definition at line 32 of file vtkPVPluginTracker.h.
Definition at line 36 of file vtkPVPluginTracker.h.
◆ anonymous enum
anonymous enum
Enumerator
Definition at line 123 of file vtkPVPluginTracker.h.
◆ vtkPVPluginTracker()
vtkPVPluginTracker::vtkPVPluginTracker ( )
◆ ~vtkPVPluginTracker()
vtkPVPluginTracker::~vtkPVPluginTracker ( )
static vtkPVPluginTracker* vtkPVPluginTracker::New ( )
virtual const char* vtkPVPluginTracker::GetClassName ( )
static int vtkPVPluginTracker::IsTypeOf ( const char *  type)
virtual int vtkPVPluginTracker::IsA ( const char *  type)
static vtkPVPluginTracker* vtkPVPluginTracker::SafeDownCast ( vtkObject *  o)
void vtkPVPluginTracker::PrintSelf ( ostream &  os,
◆ GetInstance()
static vtkPVPluginTracker* vtkPVPluginTracker::GetInstance ( )
This will create the vtkPVPluginTracker singleton the first time this method is called.
◆ RegisterPlugin()
void vtkPVPluginTracker::RegisterPlugin ( vtkPVPlugin *  )
This registers the plugin instance with the manager. It fires an event (vtkCommand::RegisterEvent) signalling that a plugin was loaded. Handlers that the process the plugin by detecting the interfaces implemented by the plugin and the processing those on a case-by-case basis. Note there's no call to unregister a plugin. Once a plugin has been loaded, it cannot be unloaded for the lifetime of the process.
◆ RegisterAvailablePlugin()
unsigned int vtkPVPluginTracker::RegisterAvailablePlugin ( const char *  filename)
This fires vtkPVPluginTracker::RegisterAvailablePluginEvent to notify a new plugin has been made available.
◆ LoadPluginConfigurationXMLs()
void vtkPVPluginTracker::LoadPluginConfigurationXMLs ( const char *  appname)
The xml is of the form:
<Plugins>
<Plugin name="[plugin name]" filename="[optional file name]" auto_load="[bool]" />
</Plugins>
This method will process the XML, locate the plugin shared library and either load the plugin or call RegisterAvailablePlugin based on the status of the auto_load flag. auto_load flag is optional and is 0 by default. filename is also optional, if not provided this method will look in different place to find the plugin, eg. paraview lib dir. It will NOT look in PV_PLUGIN_PATH.
◆ LoadPluginConfigurationXML() [1/2]
void vtkPVPluginTracker::LoadPluginConfigurationXML ( const char *  filename,
bool  forceLoad = false
<Plugins>
</Plugins>
◆ LoadPluginConfigurationXML() [2/2]
void vtkPVPluginTracker::LoadPluginConfigurationXML ( vtkPVXMLElement *  ,
<Plugins>
</Plugins>
◆ LoadPluginConfigurationXMLFromString()
void vtkPVPluginTracker::LoadPluginConfigurationXMLFromString ( const char *  xmlcontents,
<Plugins>
</Plugins>
◆ GetNumberOfPlugins()
unsigned int vtkPVPluginTracker::GetNumberOfPlugins ( )
◆ GetPlugin()
vtkPVPlugin* vtkPVPluginTracker::GetPlugin ( unsigned int  index)
This is non-null only for loaded plugins. If a plugin was merely registered as a "available" plugin, then one can only use the methods to query some primitive information about that plugin.
◆ GetPluginName()
const char* vtkPVPluginTracker::GetPluginName ( unsigned int  index)
This is also used by vtkPluginsInformation to copy plugins information.
◆ GetPluginFileName()
const char* vtkPVPluginTracker::GetPluginFileName ( unsigned int  index)
◆ GetPluginLoaded()
bool vtkPVPluginTracker::GetPluginLoaded ( unsigned int  index)
◆ GetPluginAutoLoad()
bool vtkPVPluginTracker::GetPluginAutoLoad ( unsigned int  index)
◆ GetPluginDelayedLoad()
bool vtkPVPluginTracker::GetPluginDelayedLoad ( unsigned int  index)
◆ GetPluginXMLs()
std::vector<std::string> vtkPVPluginTracker::GetPluginXMLs ( unsigned int  index)
◆ RegisterStaticPluginSearchFunction()
static void vtkPVPluginTracker::RegisterStaticPluginSearchFunction ( vtkPluginSearchFunction  function)
◆ RegisterStaticPluginListFunction()
static void vtkPVPluginTracker::RegisterStaticPluginListFunction ( vtkPluginListFunction  function)
