vtkPVTemporalDataInformation Class Reference
extends vtkPVDataInformation to gather information across timesteps. More...
#include <vtkPVTemporalDataInformation.h>
Inheritance diagram for vtkPVTemporalDataInformation:
Collaboration diagram for vtkPVTemporalDataInformation:
typedef vtkPVDataInformation Superclass
- Public Types inherited from vtkPVDataInformation
typedef vtkPVInformation Superclass
- Public Types inherited from vtkPVInformation
void CopyFromObject (vtkObject *object) override
 Transfer information about a single object into this object. More...
- Public Member Functions inherited from vtkPVDataInformation
void Initialize ()
 Initializes and clears all values updated in CopyFromObject. More...
void DeepCopy (vtkPVDataInformation *info)
 Simply copies from another vtkPVDataInformation. More...
vtkPVArrayInformation * GetArrayInformation (const char *arrayname, int fieldAssociation) const
 Finds and returns array information associated with the chosen array. More...
virtual int GetDataSetType ()
 Returns the data set type. More...
virtual int GetCompositeDataSetType ()
 Returns the type flag for composite datasets. More...
bool IsCompositeDataSet () const
 Returns true if the data information corresponds to a composite dataset. More...
bool IsNull () const
 Returns true if the data information is empty or invalid. More...
vtkTypeInt64 GetNumberOfElements (int elementType) const
 Returns number of elements of the chosen type in the data. More...
virtual vtkTypeInt64 GetNumberOfAMRLevels ()
 For vtkUniformGridAMR and subclasses, this returns the number of levels. More...
vtkTypeInt64 GetNumberOfAMRDataSets (vtkTypeInt64 level) const
 For vtkUniformGridAMR and subclasses, this returns the number of datasets at each level. More...
virtual vtkTypeInt64 GetNumberOfDataSets ()
 This is count of non-null non-composite datasets. More...
virtual vtkTypeInt64 GetMemorySize ()
 Returns the memory size as reported by vtkDataObject::GetActualMemorySize. More...
virtual double * GetBounds ()
 Returns bounds for the dataset. More...
virtual void GetBounds (double &, double &, double &, double &, double &, double &)
virtual void GetBounds (double [6])
virtual vtkPVArrayInformation * GetPointArrayInformation ()
 For a vtkPointSet and subclasses, this provides information about the vtkPoints array. More...
bool IsDataStructured () const
 Returns true if the data is structured i.e. More...
bool HasStructuredData () const
 Returns true if the data has structured data. More...
bool HasUnstructuredData () const
 Returns true if the data has unstructured data. More...
bool IsAttributeValid (int fieldAssociation) const
 Returns true if provided fieldAssociation is valid for this dataset, false otherwise. More...
virtual vtkTypeUInt64 GetFirstLeafCompositeIndex ()
 Until multiblock dataset is deprecated, applications often want to locate the composite-index for the first leaf node. More...
std::string GetBlockName (vtkTypeUInt64 cid) const
 Given a composite index, return the blockname, if any. More...
std::vector< std::string > GetBlockNames (const std::vector< std::string > &selectors, const char *assemblyName) const
 Given a collection of selectors, returns all block names for chosen blocks. More...
unsigned int ComputeCompositeIndexForAMR (unsigned int level, unsigned int index) const
 A helper method to convert an AMR level-index to a flat index. More...
virtual void SetPortNumber (int)
 Indicates which output port of an algorithm this data should information should be / has been collected from. More...
virtual int GetPortNumber ()
virtual void SetRank (int)
 Indicates which rank to gather the information from. More...
virtual int GetRank ()
virtual char * GetSubsetSelector ()
 Path if non-null, used to limit blocks from a composite dataset. More...
virtual void SetSubsetSelector (const char *)
virtual void SetSubsetAssemblyName (const char *)
 Get/Set the assembly to use for subsetting. More...
virtual char * GetSubsetAssemblyName ()
void SetSubsetAssemblyNameToHierarchy ()
void AddInformation (vtkPVInformation *info) override
 vtkPVInformation API implementation. More...
void CopyToStream (vtkClientServerStream *) override
void CopyFromStream (const vtkClientServerStream *) override
void CopyParametersToStream (vtkMultiProcessStream &) override
void CopyParametersFromStream (vtkMultiProcessStream &) override
const std::vector< int > & GetUniqueBlockTypes () const
 For a composite dataset, returns a list of unique data set types for all non-null leaf nodes. More...
unsigned int GetNumberOfUniqueBlockTypes () const
int GetUniqueBlockType (unsigned int index) const
bool DataSetTypeIsA (const char *classname) const
 Returns true if the type is of the requested classname (or typeId). More...
bool DataSetTypeIsA (int typeId) const
bool HasDataSetType (const char *classname) const
 Similar to DataSetTypeIsA except, in case of composite datasets, returns true if any of the leaf nodes match the requested type. More...
bool HasDataSetType (int typeId) const
vtkTypeInt64 GetNumberOfPoints () const
 Convenience methods that simply call GetNumberOfElements with appropriate element type. More...
vtkTypeInt64 GetNumberOfCells () const
vtkTypeInt64 GetNumberOfVertices () const
vtkTypeInt64 GetNumberOfEdges () const
vtkTypeInt64 GetNumberOfRows () const
virtual vtkTypeInt64 GetNumberOfTrees ()
 vtkHyperTreeGrid / vtkUniformHyperTreeGrid specific properties. More...
virtual vtkTypeInt64 GetNumberOfLeaves ()
virtual int * GetExtent ()
 Returns structured extents for the data. More...
virtual void GetExtent (int &, int &, int &, int &, int &, int &)
virtual void GetExtent (int [6])
vtkPVDataSetAttributesInformation * GetAttributeInformation (int fieldAssociation) const
 Get vtkPVDataSetAttributesInformation information for the given association. More...
vtkPVDataSetAttributesInformation * GetPointDataInformation () const
 Convenience methods to get vtkPVDataSetAttributesInformation for specific field type. More...
vtkPVDataSetAttributesInformation * GetCellDataInformation () const
vtkPVDataSetAttributesInformation * GetVertexDataInformation () const
vtkPVDataSetAttributesInformation * GetEdgeDataInformation () const
vtkPVDataSetAttributesInformation * GetRowDataInformation () const
vtkPVDataSetAttributesInformation * GetFieldDataInformation () const
virtual bool GetHasTime ()
 Returns DATA_TIME_STEP, if any, provided by the information object associated with data. More...
virtual double GetTime ()
virtual double * GetTimeRange ()
 Strictly speaking, these are not data information since these cannot be obtained from the data but from the pipeline producing the data. More...
virtual void GetTimeRange (double &, double &)
virtual void GetTimeRange (double [2])
virtual std::string GetTimeLabel ()
const std::set< double > & GetTimeSteps () const
vtkTypeInt64 GetNumberOfTimeSteps () const
vtkDataAssembly * GetHierarchy () const
 For composite datasets, this provides access to the information about the dataset hierarchy and any data assembly associated with it. More...
vtkDataAssembly * GetDataAssembly () const
vtkDataAssembly * GetDataAssembly (const char *assemblyName) const
const char * GetDataSetTypeAsString () const
 Returns a string for the given type. More...
const char * GetDataClassName () const
const char * GetCompositeDataClassName () const
const char * GetPrettyDataTypeString () const
 Returns a user-friendly string describing the datatype. More...
- Public Member Functions inherited from vtkPVInformation
virtual int GetRootOnly ()
 Set/get whether to gather information only from the root. More...
static vtkPVTemporalDataInformation * New ()
static vtkPVTemporalDataInformation * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVDataInformation
static vtkPVDataInformation * New ()
static vtkPVDataInformation * SafeDownCast (vtkObject *o)
static int GetExtentType (int dataType)
 Returns the extent type for a given data-object type. More...
static const char * GetDataSetTypeAsString (int type)
static const char * GetPrettyDataTypeString (int dtype)
- Static Public Member Functions inherited from vtkPVInformation
static vtkPVInformation * SafeDownCast (vtkObject *o)
 vtkPVTemporalDataInformation ()
 ~vtkPVTemporalDataInformation () override
- Protected Member Functions inherited from vtkPVDataInformation
 vtkPVDataInformation ()
 ~vtkPVDataInformation () override
void CopyFromPipelineInformation (vtkInformation *pipelineInfo)
 Populate information object with contents from producer pipeline's output port information. More...
void CopyFromDataObject (vtkDataObject *dobj)
virtual vtkSmartPointer< vtkCompositeDataSet > SimplifyCompositeDataSet (vtkCompositeDataSet *cd)
 Simplifies a composite dataset for faster processing when accumulating data-information. More...
vtkSmartPointer< vtkDataObject > GetSubset (vtkDataObject *dobj) const
 Extracts selected blocks. More...
- Protected Member Functions inherited from vtkPVInformation
 vtkPVInformation ()
 ~vtkPVInformation () override
virtual void SetRootOnly (int)
 vtkPVInformation (const vtkPVInformation &)=delete
void operator= (const vtkPVInformation &)=delete
- Protected Attributes inherited from vtkPVInformation
int RootOnly
vtkPVTemporalDataInformation is used to gather data information over time. It simply overrides vtkPVDataInformation::CopyFromObject to ensure that the data information is collected from all timesteps and not just 1.
Definition at line 21 of file vtkPVTemporalDataInformation.h.
Definition at line 25 of file vtkPVTemporalDataInformation.h.
◆ vtkPVTemporalDataInformation()
vtkPVTemporalDataInformation::vtkPVTemporalDataInformation ( )
◆ ~vtkPVTemporalDataInformation()
vtkPVTemporalDataInformation::~vtkPVTemporalDataInformation ( )
static vtkPVTemporalDataInformation* vtkPVTemporalDataInformation::New ( )
virtual const char* vtkPVTemporalDataInformation::GetClassName ( )
Reimplemented from vtkPVDataInformation.
static int vtkPVTemporalDataInformation::IsTypeOf ( const char *  type)
virtual int vtkPVTemporalDataInformation::IsA ( const char *  type)
static vtkPVTemporalDataInformation* vtkPVTemporalDataInformation::SafeDownCast ( vtkObject *  o)
void vtkPVTemporalDataInformation::PrintSelf ( ostream &  os,
◆ CopyFromObject()
void vtkPVTemporalDataInformation::CopyFromObject ( vtkObject *  object)
This expects the object to be a vtkAlgorithmOutput.
