pqPropertyWidget subclass for properties with vtkSMArrayListDomain. More...
#include <pqArraySelectorPropertyWidget.h>
Public Slots | |
| void | setArray (int assoc, const QString &val) |
| Set the chosen array name and association. More... | |
| void | setArray (const QList< QVariant > &val) |
| A setArray overload useful to expose the setArray using Qt's property system. More... | |
| void | setArrayName (const QString &name) |
| Set the array name without caring for the array association. More... | |
Signals | |
| void | arrayChanged () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| pqArraySelectorPropertyWidget (vtkSMProperty *smproperty, vtkSMProxy *smproxy, QWidget *parent=nullptr) | |
| pqArraySelectorPropertyWidget (vtkSMProperty *smproperty, vtkSMProxy *smproxy, std::initializer_list< QPair< int, QString >> knownArrays, QWidget *parent=nullptr) | |
| ~pqArraySelectorPropertyWidget () override | |
| QString | arrayName () const |
| Returns the chosen array name. More... | |
| int | arrayAssociation () const |
| Returns the chosen array association. More... | |
| QList< QVariant > | array () const |
Returns the {association, name} for the chosen array. More... | |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | select () |
Properties | |
| QList< QVariant > | array |
| QString | arrayName |
| template<class T > | |
pqArraySelectorPropertyWidget is intended to be used for vtkSMStringVectorProperty instances that have a vtkSMArrayListDomain domain and want to show a single combo-box to allow the user to choose the array to use.
We support non-repeatable string-vector property with a 1, 2, or 5 elements. When 1 element is present, we interpret the property value as the name of chosen array, thus the user won't be able to pick array association. While for 2 and 5 element properties the array association and name can be picked.
The list of available arrays is built using the vtkSMArrayListDomain and updated anytime the domain is updated. If the currently chosen value is no longer in the domain, we will preserve it and flag it by adding a (?) suffix to the displayed label.
pqStringVectorPropertyWidget::createWidget instantiates this for any string vector property with a vtkSMArrayListDomain that is not repeatable.
Pre-defined entries can be provided with the KnownArrays argument when constructing the widget.
Definition at line 38 of file pqArraySelectorPropertyWidget.h.
| pqArraySelectorPropertyWidget::pqArraySelectorPropertyWidget | ( | vtkSMProperty * | smproperty, |
| vtkSMProxy * | smproxy, | ||
| std::initializer_list< QPair< int, QString >> | knownArrays, | ||
| QString pqArraySelectorPropertyWidget::arrayName | ( | ) | const |
| int pqArraySelectorPropertyWidget::arrayAssociation | ( | ) | const |
| QList<QVariant> pqArraySelectorPropertyWidget::array | ( | ) | const |
slot |
val must be a two-tuple.
slot |
In general, this is only meant to be used for connecting to a SMProperty which only lets the user choose the array name and not the association.
signal |
readwrite |
Definition at line 43 of file pqArraySelectorPropertyWidget.h.
readwrite |
