list of arrays obtained from input More...
#include <vtkSMArrayListDomain.h>
| enum | InformationKeyStrategy { NEED_KEY, REJECT_KEY } |
| typedef vtkSMStringListDomain | Superclass |
Public Types inherited from vtkSMStringListDomain | |
| typedef vtkSMDomain | Superclass |
Public Types inherited from vtkSMDomain | |
| enum | IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 } |
| void | Update (vtkSMProperty *prop) override |
| Updates the string list based on the available arrays. More... | |
| int | IsArrayPartial (unsigned int idx) |
| Returns true if the array with the given idx is partial false otherwise. More... | |
| int | GetFieldAssociation (unsigned int idx) |
| Get field association for the array. More... | |
| int | GetDomainAssociation (unsigned int idx) |
| Get the true field association for the array. More... | |
| int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| A vtkSMProperty is often defined with a default value in the XML itself. More... | |
| unsigned int | RemoveInformationKey (const char *location, const char *name) |
| Removes an InformationKey from this domain. More... | |
| unsigned int | GetNumberOfInformationKeys () |
| Returns the number of InformationKeys in this domain. More... | |
| void | RemoveAllInformationKeys () |
| Removes all InformationKeys from this domain. More... | |
| virtual int | GetAttributeType () |
| Return the attribute type. More... | |
| virtual unsigned int | AddInformationKey (const char *location, const char *name, int strategy) |
| Adds a new InformationKey to the domain. More... | |
| virtual unsigned int | AddInformationKey (const char *location, const char *name) |
| const char * | GetInformationKeyLocation (unsigned int) |
| Returns the location/name/strategy of a given InformationKey. More... | |
| const char * | GetInformationKeyName (unsigned int) |
| int | GetInformationKeyStrategy (unsigned int) |
Public Member Functions inherited from vtkSMStringListDomain | |
| int | IsInDomain (vtkSMProperty *property) override |
| Returns true if the value of the property is in the domain. More... | |
| int | IsInDomain (const char *string, unsigned int &idx) |
| Returns true if the string is in the domain. More... | |
| const char * | GetString (unsigned int idx) |
| Returns a string in the domain. More... | |
| unsigned int | GetNumberOfStrings () |
| Returns the number of strings in the domain. More... | |
| Update self checking the "unchecked" values of all required properties. More... | |
| void | SetAnimationValue (vtkSMProperty *, int, double) override |
| Set the value of an element of a property from the animation editor. More... | |
| virtual char * | GetNoneString () |
| Return the string that is used as "none_string" in XML configuration. More... | |
| virtual void | SetNoneString (const char *) |
Public Member Functions inherited from vtkSMDomain | |
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More... | |
| Provides access to the vtkSMProperty on which this domain is hooked up. More... | |
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More... | |
| Returns a given required property of the given function. More... | |
| When the IsOptional flag is set, IsInDomain() always returns true. More... | |
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More... | |
| virtual vtkPVDataInformation * | GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0) |
| static vtkSMArrayListDomain * | New () |
| static vtkSMArrayListDomain * | SafeDownCast (vtkObject *o) |
| static std::string | CreateMangledName (vtkPVArrayInformation *arrayInfo, int component) |
| returns the mangled name for the component index that is passed in. More... | |
| static std::string | ArrayNameFromMangledName (const char *name) |
| static int | ComponentIndexFromMangledName (vtkPVArrayInformation *info, const char *name) |
Static Public Member Functions inherited from vtkSMStringListDomain | |
| static vtkSMStringListDomain * | New () |
| static vtkSMStringListDomain * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSMDomain | |
| static vtkSMDomain * | New () |
| static vtkSMDomain * | SafeDownCast (vtkObject *o) |
| vtkSMArrayListDomain () | |
| ~vtkSMArrayListDomain () override | |
| int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| virtual vtkPVDataInformation * | GetExtraDataInformation () |
| HACK: Provides a temporary mechanism for subclasses to provide an "additional" vtkPVDataInformation instance to get available arrays list from. More... | |
| virtual bool | IsFilteredArray (vtkPVDataInformation *info, int association, const char *arrayName) |
| Returns true if an array should be filtered out. More... | |
| virtual char * | GetInputDomainName () |
| InputDomainName refers to a input property domain that describes the type of array is needed by this property. More... | |
| virtual void | SetInputDomainName (const char *) |
Protected Member Functions inherited from vtkSMStringListDomain | |
| void | ChildSaveState (vtkPVXMLElement *domainElement) override |
| Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More... | |
| virtual void | SetStrings (const std::vector< std::string > &strings) |
| Call to set the strings. More... | |
| const std::vector< std::string > & | GetStrings () |
| vtkSMStringListDomain () | |
| ~vtkSMStringListDomain () override | |
Protected Member Functions inherited from vtkSMDomain | |
| vtkSMDomain () | |
| ~vtkSMDomain () override | |
| Load the state of the domain from the XML. More... | |
| Remove the given property from the required properties list. More... | |
| Add a new required property to this domain. More... | |
| void | DomainModified () |
| Invokes DomainModifiedEvent. More... | |
| void | InvokeModified () |
| Gets the number of required properties added. More... | |
| Set the domain's property. More... | |
| vtkSMSessionObject () | |
| vtkSMObject () | |
Protected Attributes | |
| char * | InputDomainName |
| bool | PickFirstAvailableArrayByDefault |
Protected Attributes inherited from vtkSMStringListDomain | |
| char * | NoneString |
| Default string always present in this string list. More... | |
Protected Attributes inherited from vtkSMDomain | |
| char * | XMLName |
| bool | IsOptional |
| vtkSMDomainInternals * | Internals |
Friends | |
| class | vtkSMArrayListDomainInternals |
| int | AttributeType |
| Set to an attribute type defined in vtkDataSetAttributes. More... | |
| virtual void | SetAttributeType (int) |
vtkSMArrayListDomain is used on vtkSMStringVectorProperty when the values on the property correspond to data arrays in the input.
Supported Required Property Functions:
Input : (required) this point to a vtkSMInputProperty on the parent proxy. The value of this property provides the source that provides the data information to determine the available arrays. FieldDataSelection : (optional) this points a vtkSMIntVectorProperty that provide the array association for accepted arrays as defined by vtkDataObject::FieldAssociations. If FieldDataSelection is missing, then the array association is determined using the vtkSMInputArrayDomain on the vtkSMInputProperty pointed by the required function Input. If the input property has multiple vtkSMInputArrayDomain types, you can identify the domain to use by using the AssemblyName : (optional) Instead of checking all the arrays, you can check only the arrays that are part of a specific assembly using specified selectors. This is useful when you want to get a subset of the arrays. Selectors : (optional) The selectors are used in conjunction with the AssemblyName property. The selectors are used to filter the arrays that are part of the assembly.Supported XML attributes:
attribute_type : (optional) when specified, this is used to pick the default value in SetDefaultValues. This specifies the array-attribute type to pick as the default, if available e.g. if value is "Scalars", then by default the active scalar array will be picked, if available. Not to be confused with vtkDataObject::AttributeTypes, this corresponds to vtkDataSetAttributes::AttributeTypes. Accepted values are "Scalars", "Vectors", etc., as defined by vtkDataSetAttributes::AttributeNames. data_type: (optional) when specified qualifies the acceptable arrays list to the types specified. Value can be one or more of VTK_BIT, VTK_CHAR, VTK_INT, VTK_FLOAT, VTK_DOUBLE,... etc. or the equivalent integers from vtkType.h. VTK_VOID, and 0 are equivalent to not specifying, meaning any data type. VTK_DATA_ARRAY can be used to limit to vtkDataArray subclasses. none_string: (optional) when specified, this string appears as the first entry in the domain the list and can be used to show "None", or "Not available" etc. key_location / key_name / key_strategy: (optional) those tree attributes are related to InformationKey of the array. key_location/key_name are the location and name of the given InformationKey key_strategy specifies if this specific key is needed to be in the domain or if this key is rejected. One of need_key or reject_key. if nothing is specified, the default is to add a vtkAbstractArray::GUI_HIDE key, with the reject_key strategy, so that arrays that have this InformationKey are not visible in the user interface. Definition at line 79 of file vtkSMArrayListDomain.h.
Definition at line 83 of file vtkSMArrayListDomain.h.
| Enumerator | |
| NEED_KEY | |
| REJECT_KEY | |
Definition at line 154 of file vtkSMArrayListDomain.h.
Reimplemented from vtkSMStringListDomain.
Reimplemented in vtkSMRepresentedArrayListDomain.
Requires a property of class vtkSMProxyProperty which points to a vtkSMSourceProxy and contains a vtkSMInputArrayDomain. Only the first proxy and domain are used.
See vtkPVArrayInformation for more information.
When vtkSMInputArrayDomain::AutomaticPropertyConversion is ON, this is not the true association for a particular array, but what the target filter is expecting. Thus use this to set the value on the property. To correctly show icons in UI, use GetDomainAssociation().
This is same as GetFieldAssociation() except when vtkSMInputArrayDomain::AutomaticPropertyConversion is ON. In that case, this may be different. e.g. let's say Pressure is a point array on the input, however this filter only works with cell array. In that case, since AutomaticPropertyConversion is ON, vtkPVPostFilter is going to automatically convert the point array Pressure to a cell array for the filter. Now in this case, the SetInputArrayToProcess property on the filter must be set to ask a "cell" array named Pressure, despite the fact that there's no such cell array. And the UI needs to show the "Pressure" as a point array, since that's what the user is expecting. In this case, GetFieldAssociation() is going to return "CELL" for the "Pressure", while GetDomainAssociation() is going to return "POINT". Thus, use GetFieldAssociation() for setting the property value, but use GetDomainAssociation() for the icon.
The values are listed in vtkDataSetAttributes.h.
However, many times, the default value must be determined at run time. To facilitate this, domains can override this method to compute and set the default value for the property. Note that unlike the compile-time default values, the application must explicitly call this method to initialize the property. Returns 1 if the domain updated the property.
The default strategy is NEED_KEY if none is specified. If no InformationKey is specified in the xml, the default behavior is to create a rejected key vtkAbstractArray::GUI_HIDE
inlinevirtual |
Definition at line 168 of file vtkSMArrayListDomain.h.
| unsigned int vtkSMArrayListDomain::RemoveInformationKey | ( | const char * | location, |
| const char * | name | ||
| unsigned int vtkSMArrayListDomain::GetNumberOfInformationKeys | ( | ) |
| void vtkSMArrayListDomain::RemoveAllInformationKeys | ( | ) |
| const char* vtkSMArrayListDomain::GetInformationKeyLocation | ( | unsigned | int | ) |
| const char* vtkSMArrayListDomain::GetInformationKeyName | ( | unsigned | int | ) |
| int vtkSMArrayListDomain::GetInformationKeyStrategy | ( | unsigned | int | ) |
overrideprotectedvirtual |
inlineprotectedvirtual |
Definition at line 228 of file vtkSMArrayListDomain.h.
protectedvirtual |
This is typically used to filter out arrays based on their names by subclasses. This implementation always returns false, but subclasses may override.
protectedvirtual |
protectedvirtual |
protectedvirtual |
friend |
Definition at line 265 of file vtkSMArrayListDomain.h.
Definition at line 241 of file vtkSMArrayListDomain.h.
Definition at line 251 of file vtkSMArrayListDomain.h.
Definition at line 259 of file vtkSMArrayListDomain.h.
