#include <pqStringVectorPropertyWidget.h>
| pqStringVectorPropertyWidget (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parent=nullptr) | |
| ~pqStringVectorPropertyWidget () override | |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | select () |
| static pqPropertyWidget * | createWidget (vtkSMStringVectorProperty *smproperty, vtkSMProxy *smproxy, QWidget *parent=nullptr) |
| Factory method to instantiate a hard-coded type of pqPropertyWidget subclass for t he vtkSMStringVectorProperty. More... | |
| static void | processFileChooserHints (vtkPVXMLElement *hints, bool &directoryMode, bool &anyFile, QString &filter, bool &browseLocalFileSystem) |
| Method to process file-choice related hints. More... | |
| template<class T > | |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
Definition at line 12 of file pqStringVectorPropertyWidget.h.
| pqStringVectorPropertyWidget::pqStringVectorPropertyWidget | ( | vtkSMProperty * | property, |
| vtkSMProxy * | proxy, | ||
