Classes | Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | Friends | List of all members
vtkXYChartRepresentation Class Reference
#include <vtkXYChartRepresentation.h>
Inheritance diagram for vtkXYChartRepresentation:
Collaboration diagram for vtkXYChartRepresentation:
class  vtkInternals
typedef vtkChartRepresentation Superclass
- Public Types inherited from vtkChartRepresentation
enum  DesiredOutputPrecision
void SetVisibility (bool visible) override
 Set visibility of the representation. More...
void SetChartTypeToLine ()
void SetChartTypeToPoints ()
void SetChartTypeToBar ()
void SetChartTypeToStacked ()
void SetChartTypeToBag ()
void SetChartTypeToFunctionalBag ()
void SetChartTypeToArea ()
vtkChartXY * GetChart ()
 Returns the vtkChartXY instance from the view to which this representation is added. More...
void ClearSeriesVisibilities ()
void ClearLineThicknesses ()
void ClearLineStyles ()
void ClearColors ()
void ClearOpacities ()
void ClearAxisCorners ()
void ClearMarkerSizes ()
void ClearMarkerStyles ()
void ClearLabels ()
virtual void SetSelectionColor (double, double, double)
virtual void SetSelectionColor (double[3])
virtual double * GetSelectionColor ()
virtual void GetSelectionColor (double &, double &, double &)
virtual void GetSelectionColor (double[3])
bool Export (vtkAbstractChartExporter *exporter) override
 Called by vtkPVContextView::Export() to export the representation's data to a CSV file. More...
virtual void SetChartType (int)
 Get/Set the chart type, defaults to line chart. More...
virtual int GetChartType ()
virtual void SetXAxisSeriesName (const char *)
 Set the series to use as the X-axis. More...
virtual char * GetXAxisSeriesName ()
virtual void SetUseIndexForXAxis (bool)
 Set whether the index should be used for the x axis. More...
virtual bool GetUseIndexForXAxis ()
void SetSortDataByXAxis (bool val)
 Get/set whether the points in the chart should be sorted by their x-axis value. More...
virtual bool GetSortDataByXAxis ()
void SetSeriesVisibility (const char *seriesname, bool visible)
 Set/Clear the properties for Y series/columns. More...
void SetLineThickness (const char *name, double value)
void SetLineStyle (const char *name, int value)
void SetColor (const char *name, double r, double g, double b)
void SetOpacity (const char *seriesname, double opacity)
void SetAxisCorner (const char *name, int corner)
void SetMarkerStyle (const char *name, int style)
void SetMarkerSize (const char *name, double value)
void SetLabel (const char *name, const char *label)
void SetUseColorMapping (const char *name, bool useColorMapping)
void SetLookupTable (const char *name, vtkScalarsToColors *lut)
const char * GetLabel (const char *name) const
virtual void SetSeriesLabelPrefix (const char *)
 Get/Set the series label prefix. More...
virtual char * GetSeriesLabelPrefix ()
- Public Member Functions inherited from vtkChartRepresentation
void SetSelectionRepresentation (vtkChartSelectionRepresentation *)
 These must only be set during initialization before adding the representation to any views or calling Update(). More...
void MarkModified () override
 This needs to be called on all instances of vtkGeometryRepresentation when the input is modified. More...
void SetCompositeDataSetIndex (unsigned int)
void AddCompositeDataSetIndex (unsigned int)
void ResetCompositeDataSetIndices ()
unsigned int Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) override
 Override because of internal selection representations that need to be initialized as well. More...
virtual std::string GetDefaultSeriesLabel (const std::string &tableName, const std::string &columnName)
 Method to provide the default name given the name of a table and a column in that table. More...
virtual bool MapSelectionToInput (vtkSelection *sel)
 This method is called on the client-side by the vtkPVContextView whenever a new selection is made on all the visible representations in that view. More...
virtual bool MapSelectionToView (vtkSelection *sel)
 This is the inverse of MapSelectionToInput(). More...
virtual bool Export (vtkAbstractChartExporter *vtkNotUsed(exporter))
void SetFieldAssociation (int)
 Set the field association for arrays to use. More...
virtual void SetFlattenTable (int)
 Flatten the table, i.e. More...
virtual int GetFlattenTable ()
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkXYChartRepresentation * New ()
static vtkXYChartRepresentation * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkChartRepresentation
static vtkChartRepresentation * New ()
static vtkChartRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkXYChartRepresentation ()
 ~vtkXYChartRepresentation () override
 Overridden to remove all plots from the view. More...
 Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
vtkSmartPointer< vtkDataObject > TransformTable (vtkSmartPointer< vtkDataObject >) override
 Method to be overridden to apply an operation of the table after it is gathered to the first rank for rendering the chart. More...
void PrepareForRendering () override
 This method is called before actual render if this->MTime was modified since the last time this method was called. More...
- Protected Member Functions inherited from vtkChartRepresentation
 vtkChartRepresentation ()
 ~vtkChartRepresentation () override
vtkTable * GetLocalOutput (bool pre_delivery=false)
 Convenience method to get the first vtkTable from LocalOutput, if any. More...
virtual vtkSmartPointer< vtkDataObject > TransformInputData (vtkDataObject *data)
 Method to be overridden to transform input data. More...
virtual vtkSmartPointer< vtkDataObject > ReduceDataToRoot (vtkDataObject *data)
 Chart representation/views expect that the data is reduced to root node and then passed on the rendering nodes. More...
bool GetLocalOutput (MapOfTables &tables)
 Convenience method to get all vtkTable instances with their associated names. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkInternals * Internals
- Protected Attributes inherited from vtkChartRepresentation
int FieldAssociation
vtkWeakPointer< vtkPVContextView > ContextView
int FlattenTable
vtkSmartPointer< vtkMultiBlockDataSet > LocalOutput
std::set< unsigned int > CompositeIndices
vtkWeakPointer< vtkChartSelectionRepresentation > SelectionRepresentation
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
Friends
class vtkInternals
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Protected Types inherited from vtkChartRepresentation
typedef std::map< std::string, std::pair< vtkSmartPointer< vtkTable >, unsigned int > > MapOfTables
vtkXYChartRepresentation is representation that is used to add vtkPlot subclasses to a vtkChartXY instance e.g. adding vtkPlotBar to create a bar chart or vtkPlotLine to create a line chart. For every selected series (or column in a vtkTable), this class adds a new vtkPlot to the vtkChartXY. vtkXYChartRepresentation provides a union of APIs for changing the appearance of vtkPlot instances. Developers should only expose the applicable API in the ServerManager XML.
To select which type of vtkPlot instances this class will use, you must set the ChartType. Refer to vtkChartXY::AddPlot() for details on what the type must be.
Definition at line 27 of file vtkXYChartRepresentation.h.
Definition at line 31 of file vtkXYChartRepresentation.h.
◆ vtkXYChartRepresentation()
vtkXYChartRepresentation::vtkXYChartRepresentation ( )
◆ ~vtkXYChartRepresentation()
vtkXYChartRepresentation::~vtkXYChartRepresentation ( )
static vtkXYChartRepresentation* vtkXYChartRepresentation::New ( )
virtual const char* vtkXYChartRepresentation::GetClassName ( )
static int vtkXYChartRepresentation::IsTypeOf ( const char *  type)
virtual int vtkXYChartRepresentation::IsA ( const char *  type)
static vtkXYChartRepresentation* vtkXYChartRepresentation::SafeDownCast ( vtkObject *  o)
void vtkXYChartRepresentation::PrintSelf ( ostream &  os,
Reimplemented from vtkChartRepresentation.
◆ SetVisibility()
void vtkXYChartRepresentation::SetVisibility ( bool  visible)
Overridden to ensure that internally added vtkPlot instances are updated when hiding the representation.
◆ SetChartType()
virtual void vtkXYChartRepresentation::SetChartType ( int  )
This must be set before this representation is updated. Valid values are vtkChart::LINE, vtkChart::POINTS, vtkChart::BAR, etc. Default is vtkChart::LINE.
◆ GetChartType()
virtual int vtkXYChartRepresentation::GetChartType ( )
◆ SetChartTypeToLine()
void vtkXYChartRepresentation::SetChartTypeToLine ( )
◆ SetChartTypeToPoints()
void vtkXYChartRepresentation::SetChartTypeToPoints ( )
◆ SetChartTypeToBar()
void vtkXYChartRepresentation::SetChartTypeToBar ( )
◆ SetChartTypeToStacked()
void vtkXYChartRepresentation::SetChartTypeToStacked ( )
◆ SetChartTypeToBag()
void vtkXYChartRepresentation::SetChartTypeToBag ( )
◆ SetChartTypeToFunctionalBag()
void vtkXYChartRepresentation::SetChartTypeToFunctionalBag ( )
◆ SetChartTypeToArea()
void vtkXYChartRepresentation::SetChartTypeToArea ( )
◆ GetChart()
vtkChartXY* vtkXYChartRepresentation::GetChart ( )
Thus this will return a non-null value only when this representation is added to a view.
◆ SetXAxisSeriesName()
virtual void vtkXYChartRepresentation::SetXAxisSeriesName ( const char *  )
◆ GetXAxisSeriesName()
virtual char* vtkXYChartRepresentation::GetXAxisSeriesName ( )
◆ SetUseIndexForXAxis()
virtual void vtkXYChartRepresentation::SetUseIndexForXAxis ( bool  )
When true, XSeriesName is ignored.
◆ GetUseIndexForXAxis()
virtual bool vtkXYChartRepresentation::GetUseIndexForXAxis ( )
◆ SetSortDataByXAxis()
void vtkXYChartRepresentation::SetSortDataByXAxis ( bool  val)
Points are connected in line plots in the order they are in the table. Sorting by the x-axis allows the line to have no cycles.
◆ GetSortDataByXAxis()
virtual bool vtkXYChartRepresentation::GetSortDataByXAxis ( )
◆ SetSeriesVisibility()
void vtkXYChartRepresentation::SetSeriesVisibility ( const char *  seriesname,
bool  visible
◆ SetLineThickness()
void vtkXYChartRepresentation::SetLineThickness ( const char *  name,
double  value
◆ SetLineStyle()
void vtkXYChartRepresentation::SetLineStyle ( const char *  name,
int  value
◆ SetColor()
void vtkXYChartRepresentation::SetColor ( const char *  name,
double  r,
double  g,
double  b
◆ SetOpacity()
void vtkXYChartRepresentation::SetOpacity ( const char *  seriesname,
double  opacity
◆ SetAxisCorner()
void vtkXYChartRepresentation::SetAxisCorner ( const char *  name,
int  corner
◆ SetMarkerStyle()
void vtkXYChartRepresentation::SetMarkerStyle ( const char *  name,
int  style
◆ SetMarkerSize()
void vtkXYChartRepresentation::SetMarkerSize ( const char *  name,
double  value
◆ SetLabel()
void vtkXYChartRepresentation::SetLabel ( const char *  name,
const char *  label
◆ SetUseColorMapping()
void vtkXYChartRepresentation::SetUseColorMapping ( const char *  name,
◆ SetLookupTable()
void vtkXYChartRepresentation::SetLookupTable ( const char *  name,
vtkScalarsToColors *  lut
◆ GetLabel()
const char* vtkXYChartRepresentation::GetLabel ( const char *  name) const
◆ ClearSeriesVisibilities()
void vtkXYChartRepresentation::ClearSeriesVisibilities ( )
◆ ClearLineThicknesses()
void vtkXYChartRepresentation::ClearLineThicknesses ( )
◆ ClearLineStyles()
void vtkXYChartRepresentation::ClearLineStyles ( )
◆ ClearColors()
void vtkXYChartRepresentation::ClearColors ( )
◆ ClearOpacities()
void vtkXYChartRepresentation::ClearOpacities ( )
◆ ClearAxisCorners()
void vtkXYChartRepresentation::ClearAxisCorners ( )
◆ ClearMarkerSizes()
void vtkXYChartRepresentation::ClearMarkerSizes ( )
◆ ClearMarkerStyles()
void vtkXYChartRepresentation::ClearMarkerStyles ( )
◆ ClearLabels()
void vtkXYChartRepresentation::ClearLabels ( )
◆ SetSelectionColor() [1/2]
virtual void vtkXYChartRepresentation::SetSelectionColor ( double  ,
double  ,
double
◆ SetSelectionColor() [2/2]
virtual void vtkXYChartRepresentation::SetSelectionColor ( double  [3])
◆ GetSelectionColor() [1/3]
virtual double* vtkXYChartRepresentation::GetSelectionColor ( )
◆ GetSelectionColor() [2/3]
virtual void vtkXYChartRepresentation::GetSelectionColor ( double &  ,
double &  ,
double &
◆ GetSelectionColor() [3/3]
virtual void vtkXYChartRepresentation::GetSelectionColor ( double  [3])
◆ SetSeriesLabelPrefix()
virtual void vtkXYChartRepresentation::SetSeriesLabelPrefix ( const char *  )
◆ GetSeriesLabelPrefix()
virtual char* vtkXYChartRepresentation::GetSeriesLabelPrefix ( )
◆ Export()
bool vtkXYChartRepresentation::Export ( vtkAbstractChartExporter *  exporter)
override
Return false on failure which will call the exporting process to abort and raise an error. Default implementation simply returns false.
◆ RemoveFromView()
bool vtkXYChartRepresentation::RemoveFromView ( vtkView *  view)
◆ ProcessViewRequest()
int vtkXYChartRepresentation::ProcessViewRequest ( vtkInformationRequestKey *  request_type,
vtkInformation *  inInfo,
vtkInformation *  outInfo
overrideprotectedvirtual
This is typically called by the vtkView to request meta-data from the representations or ask them to perform certain tasks e.g. PrepareForRendering. Overridden to handle REQUEST_RENDER() to call PrepareForRendering.
◆ RequestData()
int vtkXYChartRepresentation::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
Since most representations are "meta-filters" (i.e. filters containing other filters), you should create shallow copies of your input before connecting to the internal pipeline. The convenience method GetInternalOutputPort will create a cached shallow copy of a specified input for you. The related helper functions GetInternalAnnotationOutputPort, GetInternalSelectionOutputPort should be used to obtain a selection or annotation port whose selections are localized for a particular input data object.
◆ TransformTable()
vtkSmartPointer<vtkDataObject> vtkXYChartRepresentation::TransformTable ( vtkSmartPointer< vtkDataObject >  table)
This allows subclasses to operate on the final table. The default implementation just returns the input.
◆ PrepareForRendering()
void vtkXYChartRepresentation::PrepareForRendering ( )
Subclasses should override to update "appearance" related changes that don't affect data. When this method is called, you're assured that this->ContextView is valid. Note that this method will not be called if this->GetVisibility() returns false, this subclasses should also override SetVisibility() to hide "actors" and such.
◆ vtkInternals
friend class vtkInternals
friend
Definition at line 157 of file vtkXYChartRepresentation.h.
◆ Internals
vtkInternals* vtkXYChartRepresentation::Internals
Definition at line 159 of file vtkXYChartRepresentation.h.
