vtkAbstractChartExporter Class Referenceabstract
exporter used by certain views to export data into a file or stream. More...
#include <vtkAbstractChartExporter.h>
Inheritance diagram for vtkAbstractChartExporter:
Collaboration diagram for vtkAbstractChartExporter:
enum  ExporterModes { STREAM_ROWS, STREAM_COLUMNS }
virtual bool Open (ExporterModes mode=STREAM_ROWS)=0
 Open the file and set mode in which the exporter is operating. More...
virtual void Close ()=0
 Closes the file cleanly. More...
virtual void Abort ()=0
 Same as Close except deletes the file, if created. More...
virtual void AddColumn (vtkAbstractArray *yarray, const char *yarrayname=nullptr, vtkDataArray *xarray=nullptr)=0
 In STREAM_COLUMNS mode, use this method to add a column (yarray). More...
virtual void AddStyle (vtkPlot *plot, const char *plotName)=0
 Attach information about the style of the plot (color,line type, marker type etc. More...
virtual void SetGlobalStyle (vtkChart *chart)=0
 Set Global style elements like graph and axis titles. More...
virtual void WriteHeader (vtkFieldData *)=0
 In STREAM_ROWS mode, use these methods to write column headers once using WriteHeader and then use WriteData as many times as needed to write out rows. More...
virtual void WriteData (vtkFieldData *)=0
static vtkAbstractChartExporter * New ()
static vtkAbstractChartExporter * SafeDownCast (vtkObject *o)
 vtkAbstractChartExporter ()
 ~vtkAbstractChartExporter () override
Definition at line 23 of file vtkAbstractChartExporter.h.
Definition at line 27 of file vtkAbstractChartExporter.h.
◆ ExporterModes
Enumerator
STREAM_ROWS
STREAM_COLUMNS
Definition at line 30 of file vtkAbstractChartExporter.h.
◆ vtkAbstractChartExporter()
vtkAbstractChartExporter::vtkAbstractChartExporter ( )
◆ ~vtkAbstractChartExporter()
vtkAbstractChartExporter::~vtkAbstractChartExporter ( )
static vtkAbstractChartExporter* vtkAbstractChartExporter::New ( )
virtual const char* vtkAbstractChartExporter::GetClassName ( )
Reimplemented in vtkCSVExporter, and vtkPlotlyJsonExporter.
static int vtkAbstractChartExporter::IsTypeOf ( const char *  type)
virtual int vtkAbstractChartExporter::IsA ( const char *  type)
static vtkAbstractChartExporter* vtkAbstractChartExporter::SafeDownCast ( vtkObject *  o)
void vtkAbstractChartExporter::PrintSelf ( ostream &  os,
◆ Open()
virtual bool vtkAbstractChartExporter::Open ( ExporterModes  mode = STREAM_ROWS)
pure virtual
Implemented in vtkPlotlyJsonExporter.
◆ Close()
virtual void vtkAbstractChartExporter::Close ( )
pure virtual
Call this at the end to close the file and dump out any cached data.
Implemented in vtkCSVExporter, and vtkPlotlyJsonExporter.
◆ Abort()
virtual void vtkAbstractChartExporter::Abort ( )
pure virtual
This is useful to interrupt the exporting on failure.
◆ WriteHeader()
virtual void vtkAbstractChartExporter::WriteHeader ( vtkFieldData *  )
pure virtual
◆ WriteData()
virtual void vtkAbstractChartExporter::WriteData ( vtkFieldData *  )
pure virtual
◆ AddColumn()
virtual void vtkAbstractChartExporter::AddColumn ( vtkAbstractArray *  yarray,
const char *  yarrayname = nullptr,
vtkDataArray *  xarray = nullptr
pure virtual
One can assign it a name different the the name of the array using yarrayname. If xarray is not nullptr, then is used as the row-id. This makes it possible to add multiple columns with varying number of samples. The final output will have empty cells for missing values.
◆ AddStyle()
virtual void vtkAbstractChartExporter::AddStyle ( vtkPlot *  plot,
const char *  plotName
pure virtual
To the plot accosiated with plotName. plotName should match the yarrayname used when adding the data via Add Column. AddColumn needs to be called before adding the style.
◆ SetGlobalStyle()
virtual void vtkAbstractChartExporter::SetGlobalStyle ( vtkChart *  chart)
pure virtual
Each implementation is expected to get what it can support from the public vtkChart API.
