Public Types | Public Member Functions | Static Public Member Functions | List of all members
vtkPVContextView Class Referenceabstract
#include <vtkPVContextView.h>
Inheritance diagram for vtkPVContextView:
Collaboration diagram for vtkPVContextView:
typedef vtkPVView Superclass
- Public Types inherited from vtkPVView
typedef vtkView Superclass
- Public Types inherited from vtkView
void StillRender () override
 Triggers a high-resolution render. More...
void InteractiveRender () override
 Triggers a interactive render. More...
virtual vtkAbstractContextItem * GetContextItem ()=0
 Get the context item. More...
virtual void SetSelection (vtkChartRepresentation *repr, vtkSelection *selection)=0
 Representations can use this method to set the selection for a particular representation. More...
vtkSelection * GetSelection ()
 Get the current selection created in the view. More...
virtual bool Export (vtkAbstractChartExporter *exporter)
 Export the contents of this view using the exporter. More...
virtual vtkContextView * GetContextView ()
 Get the context view. More...
virtual void SetupInteractor (vtkRenderWindowInteractor *)
 Set the interactor. More...
vtkRenderWindowInteractor * GetInteractor ()
virtual void SetTitle (const char *)
 Get/Set the title. More...
virtual char * GetTitle ()
virtual void SetTitleFont (const char *family, int pointSize, bool bold, bool italic)=0
 Get/Set the font of the title. More...
virtual void SetTitleFontFamily (const char *family)=0
virtual void SetTitleFontSize (int pointSize)=0
virtual void SetTitleBold (bool bold)=0
virtual void SetTitleItalic (bool italic)=0
virtual void SetTitleFontFile (const char *file)=0
virtual const char * GetTitleFontFamily ()=0
virtual int GetTitleFontSize ()=0
virtual int GetTitleFontBold ()=0
virtual int GetTitleFontItalic ()=0
virtual void SetTitleColor (double red, double green, double blue)=0
 Get/Set the color of the title. More...
virtual double * GetTitleColor ()=0
- Public Member Functions inherited from vtkPVView
virtual void SetPPI (int)
 Description: Set the screen PPI. More...
virtual int GetPPI ()
virtual bool GetViewTimeValid ()
 Get ViewTimeValid. More...
void Update () override
 Overridden to not call Update() directly on the input representations, instead use ProcessViewRequest() for all vtkPVDataRepresentations. More...
bool InTileDisplayMode ()
 Returns true if the application is currently in tile display mode. More...
bool InCaveDisplayMode ()
 Returns true if the application is currently in cave/immersive display mode. More...
bool GetLocalProcessSupportsInteraction ()
 Returns true if the local process can support interaction. More...
vtkRenderWindow * GetRenderWindow ()
 If this view needs a render window (not all views may use one), this method can be used to get the render window associated with this view on the current process. More...
virtual void ScaleRendererViewports (const double viewport[4])
 vtkViewLayout calls this method to update the total viewport available for this view. More...
vtkMTimeType GetUpdateTimeStamp ()
 Provides access to the time when Update() was last called. More...
virtual void Deliver (int use_lod, unsigned int size, unsigned int *representation_ids)
 Called on all processes to request data-delivery for the list of representations. More...
virtual bool IsCached (vtkPVDataRepresentation *)
 Called in vtkPVDataRepresentation::ProcessViewRequest to check if the representation already has cached data. More...
virtual void ClearCache (vtkPVDataRepresentation *)
 Called by vtkPVDataRepresentation whenever vtkPVDataRepresentation::MarkModified is called. More...
virtual void SetPosition (int, int)
 Set the position on this view in the multiview configuration. More...
virtual int * GetPosition ()
virtual void GetPosition (int &, int &)
virtual void GetPosition (int[2])
virtual void SetSize (int, int)
 Set the size of this view in the multiview configuration. More...
virtual int * GetSize ()
virtual void GetSize (int &, int &)
virtual void GetSize (int[2])
virtual void SetViewTime (double value)
 Get/Set the time this view is showing. More...
virtual double GetViewTime ()
virtual void SetCacheKey (double)
 Get/Set the cache key. More...
virtual double GetCacheKey ()
virtual void SetUseCache (bool)
 Get/Set whether caching is enabled. More...
virtual bool GetUseCache ()
virtual void PrepareForScreenshot ()
 These methods are used to setup the view for capturing screen shots. More...
virtual void CleanupAfterScreenshot ()
void SetTileScale (int x, int y)
 When saving screenshots with tiling, these methods get called. More...
void SetTileViewport (double x0, double y0, double x1, double y1)
void SetDeliveryManager (vtkPVDataDeliveryManager *)
 Provides access to data delivery & cache manager for this view. More...
virtual vtkPVDataDeliveryManager * GetDeliveryManager ()
- Public Member Functions inherited from vtkView
vtkView * NewInstance () const
void AddRepresentation (vtkDataRepresentation *rep)
void SetRepresentation (vtkDataRepresentation *rep)
vtkDataRepresentation * AddRepresentationFromInputConnection (vtkAlgorithmOutput *conn)
vtkDataRepresentation * SetRepresentationFromInputConnection (vtkAlgorithmOutput *conn)
vtkDataRepresentation * AddRepresentationFromInput (vtkDataObject *input)
vtkDataRepresentation * SetRepresentationFromInput (vtkDataObject *input)
void RemoveRepresentation (vtkDataRepresentation *rep)
void RemoveRepresentation (vtkAlgorithmOutput *rep)
void RemoveAllRepresentations ()
int GetNumberOfRepresentations ()
vtkDataRepresentation * GetRepresentation (int index=0)
bool IsRepresentationPresent (vtkDataRepresentation *rep)
vtkCommand * GetObserver ()
void RegisterProgress (vtkObject *algorithm, const char *message=NULL)
void UnRegisterProgress (vtkObject *algorithm)
static vtkPVContextView * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVView
static vtkPVView * SafeDownCast (vtkObject *o)
static void SetEnableStreaming (bool)
static bool GetEnableStreaming ()
static vtkInformationObjectBaseKey * VIEW ()
 Key used to pass the vtkPVView pointer to the representation during any of the view passes such as REQUEST_UPDATE(), REQUEST_UPDATE_LOD(), REQUEST_RENDER(), etc. More...
static vtkInformationRequestKey * REQUEST_UPDATE ()
 This is a Update-Data pass. More...
static vtkInformationRequestKey * REQUEST_UPDATE_LOD ()
 This is a Update-LOD-Data pass. More...
static vtkInformationRequestKey * REQUEST_RENDER ()
 This is a render pass. More...
static void SetPiece (vtkInformation *info, vtkPVDataRepresentation *repr, vtkDataObject *data, unsigned long trueSize=0, int port=0)
static vtkDataObject * GetPiece (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static vtkDataObject * GetDeliveredPiece (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static void SetPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, vtkDataObject *data, unsigned long trueSize=0, int port=0)
static vtkDataObject * GetPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static vtkDataObject * GetDeliveredPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static void SetUseGenericOpenGLRenderWindow (bool val)
 Use this to indicate that the process should use vtkGenericOpenGLRenderWindow rather than vtkRenderWindow when creating an new render window. More...
static bool GetUseGenericOpenGLRenderWindow ()
- Static Public Member Functions inherited from vtkView
static vtkView * New ()
static vtkView * SafeDownCast (vtkObjectBase *o)
vtkContextView * ContextView
 Get/Set the alignement of the title. More...
virtual void SetTitleAlignment (int alignment)=0
virtual int GetTitleAlignment ()=0
 vtkPVContextView ()
 ~vtkPVContextView () override
virtual void Render (bool interactive)
 Actual rendering implementation. More...
virtual bool MapSelectionToInput (vtkSelection *)
 Called to transform the selection. More...
virtual std::string GetFormattedTitle ()
 Method to get the Formatted title after formatting it using the pushed arguments provided by vtkPVStringFormatter. More...
- Protected Member Functions inherited from vtkPVView
 vtkPVView (bool create_render_window=true)
 ~vtkPVView () override
vtkRenderWindow * NewRenderWindow ()
 Subclasses should use this method to create new render windows instead of directly creating a new one. More...
void SetRenderWindow (vtkRenderWindow *)
 Subclasses can use this method to set the render window created for this view. More...
void AllReduce (const vtkBoundingBox &source, vtkBoundingBox &dest)
 Reduce bounding box between all participating processes. More...
void AllReduce (vtkTypeUInt64 source, vtkTypeUInt64 &dest, int operation, bool skip_data_server=false)
 Reduce between all participating processes using the operation (vtkCommunicator::StandardOperations) specified. More...
vtkPVSession * GetSession ()
virtual bool GetInCaptureScreenshot ()
 Flag set to true between calls to PrepareForScreenshot and CleanupAfterScreenshot. More...
void SynchronizeRepresentationTemporalPipelineStates ()
 Called in Update() to sync HasTemporalPipeline flags between representations on all processes. More...
void AddRepresentationInternal (vtkDataRepresentation *rep) override
 Overridden to assign IDs to each representation. More...
void RemoveRepresentationInternal (vtkDataRepresentation *rep) override
int CallProcessViewRequest (vtkInformationRequestKey *passType, vtkInformation *request, vtkInformationVector *reply)
 Subclasses can use this method to trigger a pass on all representations. More...
- Protected Member Functions inherited from vtkView
 vtkView ()
 ~vtkView ()
virtual vtkDataRepresentation * CreateDefaultRepresentation (vtkAlgorithmOutput *conn)
virtual void AddRepresentationInternal (vtkDataRepresentation *vtkNotUsed(rep))
virtual void RemoveRepresentationInternal (vtkDataRepresentation *vtkNotUsed(rep))
virtual void SetReuseSingleRepresentation (bool)
virtual bool GetReuseSingleRepresentation ()
virtual void ReuseSingleRepresentationOn ()
virtual void ReuseSingleRepresentationOff ()
- Static Protected Member Functions inherited from vtkPVView
static vtkPVDataDeliveryManager * GetDeliveryManager (vtkInformation *info)
- Protected Attributes inherited from vtkPVView
double ViewTime
double CacheKey
bool UseCache
int Size [2]
int Position [2]
int PPI
vtkTimeStamp UpdateTimeStamp
 Keeps track of the time when vtkPVRenderView::Update() was called. More...
vtkInformation * RequestInformation
 These are passed as arguments to vtkDataRepresentation::ProcessViewRequest(). More...
vtkInformationVector * ReplyInformationVector
- Protected Attributes inherited from vtkView
bool ReuseSingleRepresentation
vtkPVContextView adopts vtkContextView so that it can be used in ParaView configurations.
Definition at line 29 of file vtkPVContextView.h.
Definition at line 32 of file vtkPVContextView.h.
◆ vtkPVContextView()
vtkPVContextView::vtkPVContextView ( )
These methods should not be called directly. They are made public only so that the client-server-stream-interpreter can invoke them. Use the corresponding properties to change these values.
◆ ~vtkPVContextView()
vtkPVContextView::~vtkPVContextView ( )
virtual const char* vtkPVContextView::GetClassName ( )
Reimplemented from vtkPVView.
Reimplemented in vtkPVXYChartView, and vtkPVPlotMatrixView.
static int vtkPVContextView::IsTypeOf ( const char *  type)
virtual int vtkPVContextView::IsA ( const char *  type)
static vtkPVContextView* vtkPVContextView::SafeDownCast ( vtkObject *  o)
void vtkPVContextView::PrintSelf ( ostream &  os,
Reimplemented from vtkView.
◆ StillRender()
void vtkPVContextView::StillRender ( )
Note
CallOnAllProcesses
Implements vtkPVView.
◆ InteractiveRender()
void vtkPVContextView::InteractiveRender ( )
Based on the settings on the view, this may result in a low-resolution rendering or a simplified geometry rendering.
Note
CallOnAllProcesses
◆ GetContextView()
virtual vtkContextView* vtkPVContextView::GetContextView ( )
◆ GetContextItem()
virtual vtkAbstractContextItem* vtkPVContextView::GetContextItem ( )
pure virtual
Implemented in vtkPVXYChartView, and vtkPVPlotMatrixView.
◆ SetupInteractor()
virtual void vtkPVContextView::SetupInteractor ( vtkRenderWindowInteractor *  )
Set the interactor.
Client applications must set the interactor to enable interactivity. Note this method will also change the interactor styles set on the interactor.
◆ GetInteractor()
vtkRenderWindowInteractor* vtkPVContextView::GetInteractor ( )
Set the interactor.
◆ SetSelection()
virtual void vtkPVContextView::SetSelection ( vtkChartRepresentation *  repr,
vtkSelection *  selection
pure virtual
Subclasses override this method to pass on the selection to the chart using annotation link. Note this is meant to pass selection for the local process alone. The view does not manage data movement for the selection.
◆ GetSelection()
vtkSelection* vtkPVContextView::GetSelection ( )
This will call this->MapSelectionToInput() to transform the selection every time a new selection is available. Subclasses should override MapSelectionToInput() to convert the selection, as appropriate.
◆ Export()
virtual bool vtkPVContextView::Export ( vtkAbstractChartExporter *  exporter)
Called vtkChartRepresentation::Export() on all visible representations. This is expected to called only on the client side after a render/update. Thus all data is expected to available on the local process.
◆ SetTitle()
virtual void vtkPVContextView::SetTitle ( const char *  )
Get/Set the title.
◆ GetTitle()
virtual char* vtkPVContextView::GetTitle ( )
Get/Set the title.
◆ SetTitleFont()
virtual void vtkPVContextView::SetTitleFont ( const char *  family,
int  pointSize,
bool  bold,
bool  italic
pure virtual
Implemented in vtkPVPlotMatrixView, and vtkPVXYChartView.
◆ SetTitleFontFamily()
virtual void vtkPVContextView::SetTitleFontFamily ( const char *  family)
pure virtual
◆ SetTitleFontSize()
virtual void vtkPVContextView::SetTitleFontSize ( int  pointSize)
pure virtual
◆ SetTitleBold()
virtual void vtkPVContextView::SetTitleBold ( bool  bold)
pure virtual
◆ SetTitleItalic()
virtual void vtkPVContextView::SetTitleItalic ( bool  italic)
pure virtual
◆ SetTitleFontFile()
virtual void vtkPVContextView::SetTitleFontFile ( const char *  file)
pure virtual
◆ GetTitleFontFamily()
virtual const char* vtkPVContextView::GetTitleFontFamily ( )
pure virtual
◆ GetTitleFontSize()
virtual int vtkPVContextView::GetTitleFontSize ( )
pure virtual
◆ GetTitleFontBold()
virtual int vtkPVContextView::GetTitleFontBold ( )
pure virtual
◆ GetTitleFontItalic()
virtual int vtkPVContextView::GetTitleFontItalic ( )
pure virtual
◆ SetTitleColor()
virtual void vtkPVContextView::SetTitleColor ( double  red,
double  green,
double  blue
pure virtual
◆ GetTitleColor()
virtual double* vtkPVContextView::GetTitleColor ( )
pure virtual
◆ SetTitleAlignment()
virtual void vtkPVContextView::SetTitleAlignment ( int  alignment)
pure virtual
◆ GetTitleAlignment()
virtual int vtkPVContextView::GetTitleAlignment ( )
pure virtual
◆ Render()
virtual void vtkPVContextView::Render ( bool  interactive)
protectedvirtual
◆ MapSelectionToInput()
virtual bool vtkPVContextView::MapSelectionToInput ( vtkSelection *  )
protectedvirtual
This is only called on the client-side. Subclasses should transform the selection in place as needed. Default implementation simply goes to the first visible representation and asks it to transform (by calling vtkChartRepresentation::MapSelectionToInput()). We need to extend the infrastructrue to work properly when making selections in views showing multiple representations, but until that happens, this naive approach works for most cases. Return false on failure.
◆ GetFormattedTitle()
virtual std::string vtkPVContextView::GetFormattedTitle ( )
protectedvirtual
◆ ContextView
vtkContextView* vtkPVContextView::ContextView
Definition at line 173 of file vtkPVContextView.h.
