vtkXYChartRepresentation.h
19 #ifndef vtkXYChartRepresentation_h
20 #define vtkXYChartRepresentation_h
21
22 #include "vtkChartRepresentation.h"
23
24 class vtkChartXY;
25 class vtkScalarsToColors;
26
27 class VTKREMOTINGVIEWS_EXPORT vtkXYChartRepresentation : public vtkChartRepresentation
28 {
29 public:
30  static vtkXYChartRepresentation* New();
32  void PrintSelf(ostream& os, vtkIndent indent) override;
33
38  void SetVisibility(bool visible) override;
41
47  vtkSetMacro(ChartType, int);
48  vtkGetMacro(ChartType, int);
50
51  void SetChartTypeToLine();
52  void SetChartTypeToPoints();
53  void SetChartTypeToBar();
54  void SetChartTypeToStacked();
55  void SetChartTypeToBag();
56  void SetChartTypeToFunctionalBag();
57  void SetChartTypeToArea();
58
64  vtkChartXY* GetChart();
65
67
70  vtkSetStringMacro(XAxisSeriesName);
71  vtkGetStringMacro(XAxisSeriesName);
73
75
79  vtkSetMacro(UseIndexForXAxis, bool);
80  vtkGetMacro(UseIndexForXAxis, bool);
82
84
89  void SetSortDataByXAxis(bool val);
90  vtkGetMacro(SortDataByXAxis, bool);
92
94
97  void SetSeriesVisibility(const char* seriesname, bool visible);
98  void SetLineThickness(const char* name, double value);
99  void SetLineStyle(const char* name, int value);
100  void SetColor(const char* name, double r, double g, double b);
101  void SetOpacity(const char* seriesname, double opacity);
102  void SetAxisCorner(const char* name, int corner);
103  void SetMarkerStyle(const char* name, int style);
104  void SetMarkerSize(const char* name, double value);
105  void SetLabel(const char* name, const char* label);
106  void SetUseColorMapping(const char* name, bool useColorMapping);
107  void SetLookupTable(const char* name, vtkScalarsToColors* lut);
108  const char* GetLabel(const char* name) const;
110
111  void ClearSeriesVisibilities();
112  void ClearLineThicknesses();
113  void ClearLineStyles();
114  void ClearColors();
115  void ClearOpacities();
116  void ClearAxisCorners();
117  void ClearMarkerSizes();
118  void ClearMarkerStyles();
119  void ClearLabels();
120
121  vtkSetVector3Macro(SelectionColor, double);
122  vtkGetVector3Macro(SelectionColor, double);
123
125
128  vtkSetStringMacro(SeriesLabelPrefix);
129  vtkGetStringMacro(SeriesLabelPrefix);
131
137  bool Export(vtkAbstractChartExporter* exporter) override;
138
139 protected:
141  ~vtkXYChartRepresentation() override;
142
146  bool RemoveFromView(vtkView* view) override;
147
149  vtkInformation* outInfo) override;
150
152
154
155  void PrepareForRendering() override;
156
158  friend class vtkInternals;
160
161  class SortTableFilter;
162
163 private:
165  void operator=(const vtkXYChartRepresentation&) = delete;
166
167  int ChartType;
168  char* XAxisSeriesName;
169  bool UseIndexForXAxis;
170  bool SortDataByXAxis;
171  bool PlotDataHasChanged;
172  double SelectionColor[3];
173  char* SeriesLabelPrefix;
174 };
175
176 #endif
vtkXYChartRepresentation::vtkInternals
Definition: vtkXYChartRepresentationInternals.h:26
vtkChartRepresentation::RequestData
int RequestData(vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
Subclasses should override this to connect inputs to the internal pipeline as necessary.
vtkXYChartRepresentation::Internals
vtkInternals * Internals
Definition: vtkXYChartRepresentation.h:159
vtkChartRepresentation::RemoveFromView
bool RemoveFromView(vtkView *view) override
vtkChartRepresentation::SetVisibility
Set visibility of the representation.
vtkChartRepresentation::PrepareForRendering
virtual void PrepareForRendering()
This method is called before actual render if this->MTime was modified since the last time this metho...
Definition: vtkChartRepresentation.h:164
vtkChartRepresentation::New
static vtkChartRepresentation * New()
vtkSmartPointer< vtkDataObject >
exporter used by certain views to export data into a file or stream.
Definition: vtkAbstractChartExporter.h:23
Definition: vtkXYChartRepresentation.h:27
vtkView
vtkIndent
vtkInformationRequestKey
vtkChartRepresentation::PrintSelf
vtkScalarsToColors
vtkInformation
vtkChartRepresentation::TransformTable
virtual vtkSmartPointer< vtkDataObject > TransformTable(vtkSmartPointer< vtkDataObject > table)
Method to be overridden to apply an operation of the table after it is gathered to the first rank for...
vtkChartRepresentation::Export
virtual bool Export(vtkAbstractChartExporter *vtkNotUsed(exporter))
Called by vtkPVContextView::Export() to export the representation's data to a CSV file.
Definition: vtkChartRepresentation.h:143
Definition: vtkChartRepresentation.h:33
vtkChartXY
vtkChartRepresentation::ProcessViewRequest
int ProcessViewRequest(vtkInformationRequestKey *request_type, vtkInformation *inInfo, vtkInformation *outInfo) override
