vtkUnstructuredGridVolumeRepresentation Class Reference
representation for showing vtkUnstructuredGrid datasets as volumes. More...
#include <vtkUnstructuredGridVolumeRepresentation.h>
Inheritance diagram for vtkUnstructuredGridVolumeRepresentation:
Collaboration diagram for vtkUnstructuredGridVolumeRepresentation:
typedef vtkVolumeRepresentation Superclass
- Public Types inherited from vtkVolumeRepresentation
enum  DesiredOutputPrecision
void AddVolumeMapper (const char *name, vtkAbstractVolumeMapper *)
 Register a volume mapper with the representation. More...
void SetSamplingDimensions (int dims[3])
void SetSamplingDimensions (int xdim, int ydim, int zdim)
virtual void SetActiveVolumeMapper (const char *)
 Set the active volume mapper to use. More...
vtkAbstractVolumeMapper * GetActiveVolumeMapper ()
void SetActiveAssembly (const char *)
 Forwarded to vtkVolumeRepresentationPreprocessor. More...
void AddBlockSelector (const char *)
void RemoveAllBlockSelectors ()
virtual void SetUseDataPartitions (bool)
 Specify whether or not to redistribute the data. More...
virtual bool GetUseDataPartitions ()
- Public Member Functions inherited from vtkVolumeRepresentation
void SetVisibility (bool val) override
void SetOrientation (double, double, double)
void SetOrigin (double, double, double)
void SetPickable (int val)
void SetPosition (double, double, double)
void SetScale (double, double, double)
void SetInterpolationType (int val)
void SetColor (vtkColorTransferFunction *lut)
void SetScalarOpacity (vtkPiecewiseFunction *pwf)
void SetScalarOpacityUnitDistance (double val)
void SetMapScalars (bool)
void SetMultiComponentsMapping (bool)
void SetUseSeparateOpacityArray (bool)
void SelectOpacityArray (int, int, int, int, const char *name)
void SelectOpacityArrayComponent (int component)
vtkPVLODVolume * GetActor ()
 Provides access to the actor used by this representation. More...
virtual void MarkModified ()
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkUnstructuredGridVolumeRepresentation * New ()
static vtkUnstructuredGridVolumeRepresentation * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkVolumeRepresentation
static vtkVolumeRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkUnstructuredGridVolumeRepresentation ()
 ~vtkUnstructuredGridVolumeRepresentation () override
virtual void UpdateMapperParameters ()
 Passes on parameters to the active volume mapper. More...
int ProcessViewRequestResampleToImage (vtkInformationRequestKey *request_type, vtkInformation *inInfo, vtkInformation *outInfo)
int RequestDataResampleToImage (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector)
- Protected Member Functions inherited from vtkVolumeRepresentation
 vtkVolumeRepresentation ()
 ~vtkVolumeRepresentation () override
bool AppendOpacityComponent (vtkDataSet *dataset)
 Appends a designated opacity component to a scalar array used for color/opacity mapping. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkNew< vtkVolumeRepresentationPreprocessor > Preprocessor
vtkNew< vtkProjectedTetrahedraMapper > DefaultMapper
vtkNew< vtkResampleToImage > ResampleToImageFilter
vtkNew< vtkPVGeometryFilter > LODGeometryFilter
vtkNew< vtkPolyDataMapper > LODMapper
bool UseDataPartitions = false
- Protected Attributes inherited from vtkVolumeRepresentation
vtkNew< vtkVolumeProperty > Property
vtkSmartPointer< vtkPVLODVolume > Actor
vtkNew< vtkOutlineSource > OutlineSource
unsigned long DataSize = 0
double DataBounds [6]
bool MapScalars = true
bool MultiComponentsMapping = false
bool UseSeparateOpacityArray = false
std::string OpacityArrayName
int OpacityArrayFieldAssociation = -1
int OpacityArrayComponent = -1
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkUnstructuredGridVolumeRepresentation is a representation for volume rendering vtkUnstructuredGrid datasets. It simply renders a translucent surface for LOD i.e. interactive rendering.
Definition at line 32 of file vtkUnstructuredGridVolumeRepresentation.h.
Definition at line 37 of file vtkUnstructuredGridVolumeRepresentation.h.
◆ vtkUnstructuredGridVolumeRepresentation()
vtkUnstructuredGridVolumeRepresentation::vtkUnstructuredGridVolumeRepresentation ( )
◆ ~vtkUnstructuredGridVolumeRepresentation()
vtkUnstructuredGridVolumeRepresentation::~vtkUnstructuredGridVolumeRepresentation ( )
static vtkUnstructuredGridVolumeRepresentation* vtkUnstructuredGridVolumeRepresentation::New ( )
virtual const char* vtkUnstructuredGridVolumeRepresentation::GetClassName ( )
Reimplemented from vtkVolumeRepresentation.
Reimplemented in vtkStructuredGridVolumeRepresentation.
static int vtkUnstructuredGridVolumeRepresentation::IsTypeOf ( const char *  type)
virtual int vtkUnstructuredGridVolumeRepresentation::IsA ( const char *  type)
static vtkUnstructuredGridVolumeRepresentation* vtkUnstructuredGridVolumeRepresentation::SafeDownCast ( vtkObject *  o)
void vtkUnstructuredGridVolumeRepresentation::PrintSelf ( ostream &  os,
◆ AddVolumeMapper()
void vtkUnstructuredGridVolumeRepresentation::AddVolumeMapper ( const char *  name,
◆ SetActiveVolumeMapper()
virtual void vtkUnstructuredGridVolumeRepresentation::SetActiveVolumeMapper ( const char *  )
◆ GetActiveVolumeMapper()
vtkAbstractVolumeMapper* vtkUnstructuredGridVolumeRepresentation::GetActiveVolumeMapper ( )
◆ ProcessViewRequest()
int vtkUnstructuredGridVolumeRepresentation::ProcessViewRequest ( vtkInformationRequestKey *  request_type,
vtkInformation *  inInfo,
vtkInformation *  outInfo
◆ SetActiveAssembly()
void vtkUnstructuredGridVolumeRepresentation::SetActiveAssembly ( const char *  )
Controls which blocks in a composite dataset are rendered.
◆ AddBlockSelector()
void vtkUnstructuredGridVolumeRepresentation::AddBlockSelector ( const char *  )
◆ RemoveAllBlockSelectors()
void vtkUnstructuredGridVolumeRepresentation::RemoveAllBlockSelectors ( )
◆ SetSamplingDimensions() [1/2]
void vtkUnstructuredGridVolumeRepresentation::SetSamplingDimensions ( int  dims[3])
inline
Definition at line 75 of file vtkUnstructuredGridVolumeRepresentation.h.
◆ SetSamplingDimensions() [2/2]
void vtkUnstructuredGridVolumeRepresentation::SetSamplingDimensions ( int  xdim,
int  ydim,
int  zdim
◆ SetUseDataPartitions()
virtual void vtkUnstructuredGridVolumeRepresentation::SetUseDataPartitions ( bool  )
The default is false since that is the only way in general to guarantee correct rendering. Can set to true if all rendered data sets are based on the same data partitioning in order to save on the data redistribution.
◆ GetUseDataPartitions()
virtual bool vtkUnstructuredGridVolumeRepresentation::GetUseDataPartitions ( )
◆ FillInputPortInformation()
int vtkUnstructuredGridVolumeRepresentation::FillInputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
Fill input port information.
◆ RequestData()
int vtkUnstructuredGridVolumeRepresentation::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
Overridden to invoke vtkCommand::UpdateDataEvent.
◆ AddToView()
bool vtkUnstructuredGridVolumeRepresentation::AddToView ( vtkView *  view)
◆ RemoveFromView()
bool vtkUnstructuredGridVolumeRepresentation::RemoveFromView ( vtkView *  view)
◆ UpdateMapperParameters()
virtual void vtkUnstructuredGridVolumeRepresentation::UpdateMapperParameters ( )
protectedvirtual
◆ ProcessViewRequestResampleToImage()
int vtkUnstructuredGridVolumeRepresentation::ProcessViewRequestResampleToImage ( vtkInformationRequestKey *  request_type,
◆ RequestDataResampleToImage()
int vtkUnstructuredGridVolumeRepresentation::RequestDataResampleToImage ( vtkInformation *  request,
◆ Preprocessor
vtkNew<vtkVolumeRepresentationPreprocessor> vtkUnstructuredGridVolumeRepresentation::Preprocessor
Definition at line 127 of file vtkUnstructuredGridVolumeRepresentation.h.
◆ DefaultMapper
vtkNew<vtkProjectedTetrahedraMapper> vtkUnstructuredGridVolumeRepresentation::DefaultMapper
Definition at line 128 of file vtkUnstructuredGridVolumeRepresentation.h.
◆ ResampleToImageFilter
vtkNew<vtkResampleToImage> vtkUnstructuredGridVolumeRepresentation::ResampleToImageFilter
Definition at line 130 of file vtkUnstructuredGridVolumeRepresentation.h.
◆ LODGeometryFilter
vtkNew<vtkPVGeometryFilter> vtkUnstructuredGridVolumeRepresentation::LODGeometryFilter
Definition at line 132 of file vtkUnstructuredGridVolumeRepresentation.h.
◆ LODMapper
vtkNew<vtkPolyDataMapper> vtkUnstructuredGridVolumeRepresentation::LODMapper
Definition at line 133 of file vtkUnstructuredGridVolumeRepresentation.h.
◆ UseDataPartitions
bool vtkUnstructuredGridVolumeRepresentation::UseDataPartitions = false
Definition at line 135 of file vtkUnstructuredGridVolumeRepresentation.h.
