vtkPVGeometryFilter Class Reference
Geometry filter that does outlines for volumes. More...
#include <vtkPVGeometryFilter.h>
Inheritance diagram for vtkPVGeometryFilter:
Collaboration diagram for vtkPVGeometryFilter:
enum  DesiredOutputPrecision
virtual int GetOutlineFlag ()
 This flag is set during the execute method. More...
virtual void SetUseOutline (int)
 Set/get whether to produce outline (vs. More...
virtual int GetUseOutline ()
virtual void SetGenerateFeatureEdges (bool)
 Set/get whether to produce feature edges (vs. More...
virtual bool GetGenerateFeatureEdges ()
virtual void SetBlockColorsDistinctValues (int)
 Determines the number of distinct values in vtkBlockColors. More...
virtual int GetBlockColorsDistinctValues ()
 PARAVIEW_DEPRECATED_IN_5_11_0 ("Removed; the backing implementation has done nothing since VTK 9.1.0") void SetUseStrips(int)
 When input is structured data, this flag will generate faces with triangle strips. More...
 PARAVIEW_DEPRECATED_IN_5_11_0 ("Removed; the backing implementation has done nothing since VTK 9.1.0") virtual int GetUseStrips() VTK_FUTURE_CONST
 PARAVIEW_DEPRECATED_IN_5_11_0 ("Removed; the backing implementation has done nothing since VTK 9.1.0") virtual void UseStripsOn()
 PARAVIEW_DEPRECATED_IN_5_11_0 ("Removed; the backing implementation has done nothing since VTK 9.1.0") virtual void UseStripsOff()
 PARAVIEW_DEPRECATED_IN_5_11_0 ("Removed; the backing implementation has done nothing since VTK 9.1.0") void SetForceUseStrips(int)
 PARAVIEW_DEPRECATED_IN_5_11_0 ("Removed; the backing implementation has done nothing since VTK 9.1.0") virtual int GetForceUseStrips() VTK_FUTURE_CONST
 PARAVIEW_DEPRECATED_IN_5_11_0 ("Removed; the backing implementation has done nothing since VTK 9.1.0") virtual void ForceUseStripsOn()
 PARAVIEW_DEPRECATED_IN_5_11_0 ("Removed; the backing implementation has done nothing since VTK 9.1.0") virtual void ForceUseStripsOff()
virtual void SetGenerateCellNormals (int)
 Whether to generate cell normals. More...
virtual int GetGenerateCellNormals ()
virtual void GenerateCellNormalsOn ()
virtual void GenerateCellNormalsOff ()
virtual void SetTriangulate (int)
 Whether to triangulate mesh for rendering. More...
virtual int GetTriangulate ()
virtual void TriangulateOn ()
virtual void TriangulateOff ()
virtual void SetNonlinearSubdivisionLevel (int)
 Nonlinear faces are approximated with flat polygons. More...
virtual int GetNonlinearSubdivisionLevel ()
virtual void SetMatchBoundariesIgnoringCellOrder (int)
 When two volumetric cells of different order are connected by their corners (for instance, a quadratic hexahedron next to a linear hexahedron ), the internal face is rendered and is not considered as a ghost cell. More...
virtual int GetMatchBoundariesIgnoringCellOrder ()
virtual void SetController (vtkMultiProcessController *)
 Set and get the controller. More...
void SetPassThroughCellIds (int)
 If on, the output polygonal dataset will have a celldata array that holds the cell index of the original 3D cell that produced each output cell. More...
virtual int GetPassThroughCellIds ()
virtual void PassThroughCellIdsOn ()
virtual void PassThroughCellIdsOff ()
void SetPassThroughPointIds (int)
 If on, the output polygonal dataset will have a pointdata array that holds the point index of the original vertex that produced each output vertex. More...
virtual int GetPassThroughPointIds ()
virtual void PassThroughPointIdsOn ()
virtual void PassThroughPointIdsOff ()
virtual void SetGenerateProcessIds (bool)
 If on, point arrays named vtkProcessId is added. More...
virtual bool GetGenerateProcessIds ()
virtual void GenerateProcessIdsOn ()
virtual void GenerateProcessIdsOff ()
virtual void SetHideInternalAMRFaces (bool)
 This property affects the way AMR outlines and faces are generated. More...
virtual bool GetHideInternalAMRFaces ()
virtual void HideInternalAMRFacesOn ()
virtual void HideInternalAMRFacesOff ()
virtual void SetUseNonOverlappingAMRMetaDataForOutlines (bool)
 For overlapping AMR, this property controls affects the way AMR outlines are generated. More...
virtual bool GetUseNonOverlappingAMRMetaDataForOutlines ()
virtual void UseNonOverlappingAMRMetaDataForOutlinesOn ()
virtual void UseNonOverlappingAMRMetaDataForOutlinesOff ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVGeometryFilter * New ()
static vtkPVGeometryFilter * SafeDownCast (vtkObject *o)
static vtkInformationIntegerVectorKey * POINT_OFFSETS ()
static vtkInformationIntegerVectorKey * VERTS_OFFSETS ()
static vtkInformationIntegerVectorKey * LINES_OFFSETS ()
static vtkInformationIntegerVectorKey * POLYS_OFFSETS ()
static vtkInformationIntegerVectorKey * STRIPS_OFFSETS ()
static vtkAlgorithm * New ()
 vtkPVGeometryFilter ()
 ~vtkPVGeometryFilter () override
void ExecuteAMRBlock (vtkUniformGrid *input, vtkPolyData *output, const bool extractface[6])
 Produce geometry for a block in the dataset. More...
void ExecuteAMRBlockOutline (const double bounds[6], vtkPolyData *output, const bool extractface[6])
 Used instead of ExecuteAMRBlock() when this->UseOutline is true. More...
void ExecuteBlock (vtkDataObject *input, vtkPolyData *output, int doCommunicate, int updatePiece, int updateNumPieces, int updateGhosts, const int *wholeExtent)
void DataSetExecute (vtkDataSet *input, vtkPolyData *output, int doCommunicate)
void GenericDataSetExecute (vtkGenericDataSet *input, vtkPolyData *output, int doCommunicate)
void ImageDataExecute (vtkImageData *input, vtkPolyData *output, int doCommunicate, int updatePiece, const int *ext)
void StructuredGridExecute (vtkStructuredGrid *input, vtkPolyData *output, int updatePiece, int updateNumPieces, int updateGhosts, const int *wholeExtent)
void RectilinearGridExecute (vtkRectilinearGrid *input, vtkPolyData *output, int updatePiece, int updateNumPieces, int updateGhosts, const int *wholeExtent)
void UnstructuredGridExecute (vtkUnstructuredGridBase *input, vtkPolyData *output, int doCommunicate)
void PolyDataExecute (vtkPolyData *input, vtkPolyData *output, int doCommunicate)
void HyperTreeGridExecute (vtkHyperTreeGrid *input, vtkPolyData *output, int doCommunicate)
void ExplicitStructuredGridExecute (vtkExplicitStructuredGrid *input, vtkPolyData *out, int doCommunicate, const int *wholeExtent)
void CellGridExecute (vtkCellGrid *input, vtkPolyData *output, int doCommunicate)
void CleanupOutputData (vtkPolyData *output, int doCommunicate)
 Cleans up the output polydata. More...
void ExecuteCellNormals (vtkPolyData *output, int doCommunicate)
int CheckAttributes (vtkDataObject *input)
 Call CheckAttributes on the input which ensures that all attribute arrays have valid lengths. More...
void HandleGeometryFilterProgress (vtkObject *caller, unsigned long, void *)
int FillInputPortInformation (int, vtkInformation *) override
void ReportReferences (vtkGarbageCollector *) override
int RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
 Overridden to request ghost-cells for vtkUnstructuredGrid inputs so that we don't generate internal surfaces. More...
int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
 Overridden to create vtkMultiBlockDataSet when input is a composite-dataset and vtkPolyData when input is a vtkDataSet. More...
virtual int RequestAMRData (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector)
virtual int RequestDataObjectTree (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector)
 vtkDataObjectAlgorithm ()
 ~vtkDataObjectAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
int OutlineFlag
int UseOutline
int BlockColorsDistinctValues
int GenerateCellNormals
int Triangulate
int NonlinearSubdivisionLevel
int MatchBoundariesIgnoringCellOrder = 0
vtkOutlineSource * OutlineSource
vtkGeometryFilter * GeometryFilter
vtkGenericGeometryFilter * GenericGeometryFilter
vtkUnstructuredGridGeometryFilter * UnstructuredGridGeometryFilter
vtkRecoverGeometryWireframe * RecoverWireframeFilter
vtkFeatureEdges * FeatureEdgesFilter
bool GenerateProcessIds
int PassThroughCellIds
int PassThroughPointIds
bool HideInternalAMRFaces
bool UseNonOverlappingAMRMetaDataForOutlines
bool GenerateFeatureEdges
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
This filter defaults to using the outline filter unless the input is a structured volume.
Definition at line 42 of file vtkPVGeometryFilter.h.
Definition at line 46 of file vtkPVGeometryFilter.h.
◆ vtkPVGeometryFilter()
vtkPVGeometryFilter::vtkPVGeometryFilter ( )
◆ ~vtkPVGeometryFilter()
vtkPVGeometryFilter::~vtkPVGeometryFilter ( )
static vtkPVGeometryFilter* vtkPVGeometryFilter::New ( )
virtual const char* vtkPVGeometryFilter::GetClassName ( )
static int vtkPVGeometryFilter::IsTypeOf ( const char *  type)
virtual int vtkPVGeometryFilter::IsA ( const char *  type)
static vtkPVGeometryFilter* vtkPVGeometryFilter::SafeDownCast ( vtkObject *  o)
void vtkPVGeometryFilter::PrintSelf ( ostream &  os,
◆ GetOutlineFlag()
virtual int vtkPVGeometryFilter::GetOutlineFlag ( )
It indicates that the input was 3d and an outline representation was used.
◆ SetUseOutline()
virtual void vtkPVGeometryFilter::SetUseOutline ( int  )
surface).
◆ GetUseOutline()
virtual int vtkPVGeometryFilter::GetUseOutline ( )
surface).
◆ SetGenerateFeatureEdges()
virtual void vtkPVGeometryFilter::SetGenerateFeatureEdges ( bool  )
surface). If both this and UseOutline are true, then an outline will be produced.
◆ GetGenerateFeatureEdges()
virtual bool vtkPVGeometryFilter::GetGenerateFeatureEdges ( )
◆ SetBlockColorsDistinctValues()
virtual void vtkPVGeometryFilter::SetBlockColorsDistinctValues ( int  )
◆ GetBlockColorsDistinctValues()
virtual int vtkPVGeometryFilter::GetBlockColorsDistinctValues ( )
◆ PARAVIEW_DEPRECATED_IN_5_11_0() [1/8]
vtkPVGeometryFilter::PARAVIEW_DEPRECATED_IN_5_11_0 ( "Removed; the backing implementation has done nothing since VTK 9.1.0"  )
inline
This should render faster and use less memory, but no cell data is copied. By default, UseStrips is Off.
Definition at line 88 of file vtkPVGeometryFilter.h.
◆ PARAVIEW_DEPRECATED_IN_5_11_0() [2/8]
inline
Definition at line 91 of file vtkPVGeometryFilter.h.
◆ PARAVIEW_DEPRECATED_IN_5_11_0() [3/8]
inline
Definition at line 94 of file vtkPVGeometryFilter.h.
◆ PARAVIEW_DEPRECATED_IN_5_11_0() [4/8]
inline
Definition at line 97 of file vtkPVGeometryFilter.h.
◆ PARAVIEW_DEPRECATED_IN_5_11_0() [5/8]
inline
Definition at line 103 of file vtkPVGeometryFilter.h.
◆ PARAVIEW_DEPRECATED_IN_5_11_0() [6/8]
inline
Definition at line 106 of file vtkPVGeometryFilter.h.
◆ PARAVIEW_DEPRECATED_IN_5_11_0() [7/8]
inline
Definition at line 109 of file vtkPVGeometryFilter.h.
◆ PARAVIEW_DEPRECATED_IN_5_11_0() [8/8]
inline
Definition at line 112 of file vtkPVGeometryFilter.h.
◆ SetGenerateCellNormals()
virtual void vtkPVGeometryFilter::SetGenerateCellNormals ( int  )
They can only be used for poly cells now. This option does nothing if the output contains lines, verts, or strips.
◆ GetGenerateCellNormals()
virtual int vtkPVGeometryFilter::GetGenerateCellNormals ( )
◆ GenerateCellNormalsOn()
virtual void vtkPVGeometryFilter::GenerateCellNormalsOn ( )
◆ GenerateCellNormalsOff()
virtual void vtkPVGeometryFilter::GenerateCellNormalsOff ( )
◆ SetTriangulate()
virtual void vtkPVGeometryFilter::SetTriangulate ( int  )
This parameter avoid rendering issues of non-convex polygons. This option has no effect when using OpenGL2 rendering backend. OpenGL2 rendering always triangulates polygonal meshes.
◆ GetTriangulate()
virtual int vtkPVGeometryFilter::GetTriangulate ( )
◆ TriangulateOn()
virtual void vtkPVGeometryFilter::TriangulateOn ( )
◆ TriangulateOff()
virtual void vtkPVGeometryFilter::TriangulateOff ( )
◆ SetNonlinearSubdivisionLevel()
virtual void vtkPVGeometryFilter::SetNonlinearSubdivisionLevel ( int  )
This parameter controls how many times to subdivide nonlinear surface cells. Higher subdivisions generate closer approximations but take more memory and rendering time. Subdivision is recursive, so the number of output polygons can grow exponentially with this parameter.
◆ GetNonlinearSubdivisionLevel()
virtual int vtkPVGeometryFilter::GetNonlinearSubdivisionLevel ( )
◆ SetMatchBoundariesIgnoringCellOrder()
virtual void vtkPVGeometryFilter::SetMatchBoundariesIgnoringCellOrder ( int  )
To remove these faces, switch MatchBoundariesIgnoringCellOrder to 1 (default is 0).
◆ GetMatchBoundariesIgnoringCellOrder()
virtual int vtkPVGeometryFilter::GetMatchBoundariesIgnoringCellOrder ( )
◆ SetController()
virtual void vtkPVGeometryFilter::SetController ( vtkMultiProcessController *  )
◆ GetController()
virtual vtkMultiProcessController* vtkPVGeometryFilter::GetController ( )
◆ SetPassThroughCellIds()
void vtkPVGeometryFilter::SetPassThroughCellIds ( int  )
This is useful for picking but it takes memory. The default is on.
◆ GetPassThroughCellIds()
virtual int vtkPVGeometryFilter::GetPassThroughCellIds ( )
◆ PassThroughCellIdsOn()
virtual void vtkPVGeometryFilter::PassThroughCellIdsOn ( )
◆ PassThroughCellIdsOff()
virtual void vtkPVGeometryFilter::PassThroughCellIdsOff ( )
◆ SetPassThroughPointIds()
void vtkPVGeometryFilter::SetPassThroughPointIds ( int  )
◆ GetPassThroughPointIds()
virtual int vtkPVGeometryFilter::GetPassThroughPointIds ( )
◆ PassThroughPointIdsOn()
virtual void vtkPVGeometryFilter::PassThroughPointIdsOn ( )
◆ PassThroughPointIdsOff()
virtual void vtkPVGeometryFilter::PassThroughPointIdsOff ( )
◆ SetGenerateProcessIds()
virtual void vtkPVGeometryFilter::SetGenerateProcessIds ( bool  )
◆ GetGenerateProcessIds()
virtual bool vtkPVGeometryFilter::GetGenerateProcessIds ( )
◆ GenerateProcessIdsOn()
virtual void vtkPVGeometryFilter::GenerateProcessIdsOn ( )
◆ GenerateProcessIdsOff()
virtual void vtkPVGeometryFilter::GenerateProcessIdsOff ( )
◆ SetHideInternalAMRFaces()
virtual void vtkPVGeometryFilter::SetHideInternalAMRFaces ( bool  )
When set to true (default), internal data-set faces/outlines for datasets within the AMR grids are hidden. Set it to false to see boxes for all the datasets in the AMR, internal or otherwise.
◆ GetHideInternalAMRFaces()
virtual bool vtkPVGeometryFilter::GetHideInternalAMRFaces ( )
◆ HideInternalAMRFacesOn()
virtual void vtkPVGeometryFilter::HideInternalAMRFacesOn ( )
◆ HideInternalAMRFacesOff()
virtual void vtkPVGeometryFilter::HideInternalAMRFacesOff ( )
◆ SetUseNonOverlappingAMRMetaDataForOutlines()
virtual void vtkPVGeometryFilter::SetUseNonOverlappingAMRMetaDataForOutlines ( bool  )
When set to true (default), it uses the overlapping AMR meta-data to identify the blocks present in the AMR. Which implies that even if the input did not fill in the uniform grids for all datasets in the AMR, this filter can generate outlines using the metadata alone. When set to false, the filter will only generate outlines for datasets that are actually present. Note, this only affects overlapping AMR.
◆ GetUseNonOverlappingAMRMetaDataForOutlines()
virtual bool vtkPVGeometryFilter::GetUseNonOverlappingAMRMetaDataForOutlines ( )
◆ UseNonOverlappingAMRMetaDataForOutlinesOn()
virtual void vtkPVGeometryFilter::UseNonOverlappingAMRMetaDataForOutlinesOn ( )
◆ UseNonOverlappingAMRMetaDataForOutlinesOff()
virtual void vtkPVGeometryFilter::UseNonOverlappingAMRMetaDataForOutlinesOff ( )
◆ POINT_OFFSETS()
static vtkInformationIntegerVectorKey* vtkPVGeometryFilter::POINT_OFFSETS ( )
◆ VERTS_OFFSETS()
static vtkInformationIntegerVectorKey* vtkPVGeometryFilter::VERTS_OFFSETS ( )
◆ LINES_OFFSETS()
static vtkInformationIntegerVectorKey* vtkPVGeometryFilter::LINES_OFFSETS ( )
◆ POLYS_OFFSETS()
static vtkInformationIntegerVectorKey* vtkPVGeometryFilter::POLYS_OFFSETS ( )
◆ STRIPS_OFFSETS()
static vtkInformationIntegerVectorKey* vtkPVGeometryFilter::STRIPS_OFFSETS ( )
◆ RequestDataObject()
int vtkPVGeometryFilter::RequestDataObject ( vtkInformation *  ,
vtkInformationVector **  ,
overrideprotectedvirtual
◆ RequestAMRData()
virtual int vtkPVGeometryFilter::RequestAMRData ( vtkInformation *  request,
protectedvirtual
◆ RequestDataObjectTree()
virtual int vtkPVGeometryFilter::RequestDataObjectTree ( vtkInformation *  request,
protectedvirtual
◆ RequestData()
int vtkPVGeometryFilter::RequestData ( vtkInformation *  request,
◆ CreateDefaultExecutive()
vtkExecutive* vtkPVGeometryFilter::CreateDefaultExecutive ( )
◆ ExecuteAMRBlock()
void vtkPVGeometryFilter::ExecuteAMRBlock ( vtkUniformGrid *  input,
vtkPolyData *  output,
This does not handle producing outlines. Call only when this->UseOutline == 0; extractface mask it is used to determine external faces.
◆ ExecuteAMRBlockOutline()
void vtkPVGeometryFilter::ExecuteAMRBlockOutline ( const double  bounds[6],
◆ ExecuteBlock()
void vtkPVGeometryFilter::ExecuteBlock ( vtkDataObject *  input,
int  doCommunicate,
int  updatePiece,
int  updateGhosts,
const int *  wholeExtent
◆ DataSetExecute()
void vtkPVGeometryFilter::DataSetExecute ( vtkDataSet *  input,
int  doCommunicate
◆ GenericDataSetExecute()
void vtkPVGeometryFilter::GenericDataSetExecute ( vtkGenericDataSet *  input,
int  doCommunicate
◆ ImageDataExecute()
void vtkPVGeometryFilter::ImageDataExecute ( vtkImageData *  input,
int  doCommunicate,
int  updatePiece,
const int *  ext
◆ StructuredGridExecute()
void vtkPVGeometryFilter::StructuredGridExecute ( vtkStructuredGrid *  input,
int  updatePiece,
int  updateGhosts,
◆ RectilinearGridExecute()
void vtkPVGeometryFilter::RectilinearGridExecute ( vtkRectilinearGrid *  input,
int  updatePiece,
int  updateGhosts,
◆ UnstructuredGridExecute()
void vtkPVGeometryFilter::UnstructuredGridExecute ( vtkUnstructuredGridBase *  input,
int  doCommunicate
◆ PolyDataExecute()
void vtkPVGeometryFilter::PolyDataExecute ( vtkPolyData *  input,
int  doCommunicate
◆ HyperTreeGridExecute()
void vtkPVGeometryFilter::HyperTreeGridExecute ( vtkHyperTreeGrid *  input,
int  doCommunicate
◆ ExplicitStructuredGridExecute()
void vtkPVGeometryFilter::ExplicitStructuredGridExecute ( vtkExplicitStructuredGrid *  input,
vtkPolyData *  out,
int  doCommunicate,
◆ CellGridExecute()
void vtkPVGeometryFilter::CellGridExecute ( vtkCellGrid *  input,
int  doCommunicate
◆ CleanupOutputData()
void vtkPVGeometryFilter::CleanupOutputData ( vtkPolyData *  output,
int  doCommunicate
If doCommunicate is true the method is free to communicate with other processes as needed.
◆ ExecuteCellNormals()
void vtkPVGeometryFilter::ExecuteCellNormals ( vtkPolyData *  output,
int  doCommunicate
◆ CheckAttributes()
int vtkPVGeometryFilter::CheckAttributes ( vtkDataObject *  input)
◆ HandleGeometryFilterProgress()
void vtkPVGeometryFilter::HandleGeometryFilterProgress ( vtkObject *  caller,
unsigned long  ,
void *
◆ FillInputPortInformation()
int vtkPVGeometryFilter::FillInputPortInformation ( int  ,
vtkInformation *
◆ ReportReferences()
void vtkPVGeometryFilter::ReportReferences ( vtkGarbageCollector *  )
◆ RequestUpdateExtent()
int vtkPVGeometryFilter::RequestUpdateExtent ( vtkInformation *  ,
◆ OutlineFlag
int vtkPVGeometryFilter::OutlineFlag
Definition at line 307 of file vtkPVGeometryFilter.h.
◆ UseOutline
int vtkPVGeometryFilter::UseOutline
Definition at line 308 of file vtkPVGeometryFilter.h.
◆ BlockColorsDistinctValues
int vtkPVGeometryFilter::BlockColorsDistinctValues
Definition at line 309 of file vtkPVGeometryFilter.h.
int vtkPVGeometryFilter::GenerateCellNormals
Definition at line 310 of file vtkPVGeometryFilter.h.
◆ Triangulate
int vtkPVGeometryFilter::Triangulate
Definition at line 311 of file vtkPVGeometryFilter.h.
◆ NonlinearSubdivisionLevel
int vtkPVGeometryFilter::NonlinearSubdivisionLevel
Definition at line 312 of file vtkPVGeometryFilter.h.
◆ MatchBoundariesIgnoringCellOrder
int vtkPVGeometryFilter::MatchBoundariesIgnoringCellOrder = 0
Definition at line 313 of file vtkPVGeometryFilter.h.
◆ Controller
vtkMultiProcessController* vtkPVGeometryFilter::Controller
Definition at line 315 of file vtkPVGeometryFilter.h.
◆ OutlineSource
vtkOutlineSource* vtkPVGeometryFilter::OutlineSource
Definition at line 316 of file vtkPVGeometryFilter.h.
◆ GeometryFilter
vtkGeometryFilter* vtkPVGeometryFilter::GeometryFilter
Definition at line 317 of file vtkPVGeometryFilter.h.
◆ GenericGeometryFilter
vtkGenericGeometryFilter* vtkPVGeometryFilter::GenericGeometryFilter
Definition at line 318 of file vtkPVGeometryFilter.h.
◆ UnstructuredGridGeometryFilter
vtkUnstructuredGridGeometryFilter* vtkPVGeometryFilter::UnstructuredGridGeometryFilter
Definition at line 319 of file vtkPVGeometryFilter.h.
◆ RecoverWireframeFilter
vtkRecoverGeometryWireframe* vtkPVGeometryFilter::RecoverWireframeFilter
Definition at line 320 of file vtkPVGeometryFilter.h.
◆ FeatureEdgesFilter
vtkFeatureEdges* vtkPVGeometryFilter::FeatureEdgesFilter
Definition at line 321 of file vtkPVGeometryFilter.h.
bool vtkPVGeometryFilter::GenerateProcessIds
Definition at line 342 of file vtkPVGeometryFilter.h.
int vtkPVGeometryFilter::PassThroughCellIds
Definition at line 343 of file vtkPVGeometryFilter.h.
int vtkPVGeometryFilter::PassThroughPointIds
Definition at line 344 of file vtkPVGeometryFilter.h.
bool vtkPVGeometryFilter::HideInternalAMRFaces
Definition at line 345 of file vtkPVGeometryFilter.h.
bool vtkPVGeometryFilter::UseNonOverlappingAMRMetaDataForOutlines
Definition at line 346 of file vtkPVGeometryFilter.h.
◆ GenerateFeatureEdges
bool vtkPVGeometryFilter::GenerateFeatureEdges
Definition at line 347 of file vtkPVGeometryFilter.h.
