vtkVolumeRepresentation Class Reference
Abstract base class for volume representations. Provides some functionality common to volume representations. More...
#include <vtkVolumeRepresentation.h>
Inheritance diagram for vtkVolumeRepresentation:
Collaboration diagram for vtkVolumeRepresentation:
enum  DesiredOutputPrecision
void SetVisibility (bool val) override
void SetOrientation (double, double, double)
void SetOrigin (double, double, double)
void SetPickable (int val)
void SetPosition (double, double, double)
void SetScale (double, double, double)
void SetInterpolationType (int val)
void SetColor (vtkColorTransferFunction *lut)
void SetScalarOpacity (vtkPiecewiseFunction *pwf)
void SetScalarOpacityUnitDistance (double val)
void SetMapScalars (bool)
void SetMultiComponentsMapping (bool)
void SetUseSeparateOpacityArray (bool)
void SelectOpacityArray (int, int, int, int, const char *name)
void SelectOpacityArrayComponent (int component)
vtkPVLODVolume * GetActor ()
 Provides access to the actor used by this representation. More...
virtual int ProcessViewRequest (vtkInformationRequestKey *request_type, vtkInformation *inInfo, vtkInformation *outInfo)
virtual void MarkModified ()
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkVolumeRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkVolumeRepresentation ()
 ~vtkVolumeRepresentation () override
bool AppendOpacityComponent (vtkDataSet *dataset)
 Appends a designated opacity component to a scalar array used for color/opacity mapping. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkNew< vtkVolumeProperty > Property
vtkSmartPointer< vtkPVLODVolume > Actor
vtkNew< vtkOutlineSource > OutlineSource
unsigned long DataSize = 0
double DataBounds [6]
bool MapScalars = true
bool MultiComponentsMapping = false
bool UseSeparateOpacityArray = false
std::string OpacityArrayName
int OpacityArrayFieldAssociation = -1
int OpacityArrayComponent = -1
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
Definition at line 25 of file vtkVolumeRepresentation.h.
Definition at line 28 of file vtkVolumeRepresentation.h.
◆ vtkVolumeRepresentation()
vtkVolumeRepresentation::vtkVolumeRepresentation ( )
◆ ~vtkVolumeRepresentation()
vtkVolumeRepresentation::~vtkVolumeRepresentation ( )
virtual const char* vtkVolumeRepresentation::GetClassName ( )
static int vtkVolumeRepresentation::IsTypeOf ( const char *  type)
virtual int vtkVolumeRepresentation::IsA ( const char *  type)
static vtkVolumeRepresentation* vtkVolumeRepresentation::SafeDownCast ( vtkObject *  o)
void vtkVolumeRepresentation::PrintSelf ( ostream &  os,
◆ SetVisibility()
void vtkVolumeRepresentation::SetVisibility ( bool  val)
When the visibility of representation of false, all view passes are ignored.
◆ SetOrientation()
void vtkVolumeRepresentation::SetOrientation ( double  ,
double  ,
double
◆ SetOrigin()
void vtkVolumeRepresentation::SetOrigin ( double  ,
double  ,
double
◆ SetPickable()
void vtkVolumeRepresentation::SetPickable ( int  val)
◆ SetPosition()
void vtkVolumeRepresentation::SetPosition ( double  ,
double  ,
double
◆ SetScale()
void vtkVolumeRepresentation::SetScale ( double  ,
double  ,
double
◆ SetInterpolationType()
void vtkVolumeRepresentation::SetInterpolationType ( int  val)
◆ SetColor()
void vtkVolumeRepresentation::SetColor ( vtkColorTransferFunction *  lut)
◆ SetScalarOpacity()
void vtkVolumeRepresentation::SetScalarOpacity ( vtkPiecewiseFunction *  pwf)
◆ SetScalarOpacityUnitDistance()
void vtkVolumeRepresentation::SetScalarOpacityUnitDistance ( double  val)
◆ SetMapScalars()
void vtkVolumeRepresentation::SetMapScalars ( bool  )
◆ SetMultiComponentsMapping()
void vtkVolumeRepresentation::SetMultiComponentsMapping ( bool  )
◆ SetUseSeparateOpacityArray()
void vtkVolumeRepresentation::SetUseSeparateOpacityArray ( bool  )
◆ SelectOpacityArray()
void vtkVolumeRepresentation::SelectOpacityArray ( int  ,
int  ,
int  ,
int  ,
const char *  name
◆ SelectOpacityArrayComponent()
void vtkVolumeRepresentation::SelectOpacityArrayComponent ( int  component)
◆ GetActor()
vtkPVLODVolume* vtkVolumeRepresentation::GetActor ( )
inline
Definition at line 63 of file vtkVolumeRepresentation.h.
◆ AppendOpacityComponent()
bool vtkVolumeRepresentation::AppendOpacityComponent ( vtkDataSet *  dataset)
◆ Property
vtkNew<vtkVolumeProperty> vtkVolumeRepresentation::Property
Definition at line 69 of file vtkVolumeRepresentation.h.
◆ Actor
vtkSmartPointer<vtkPVLODVolume> vtkVolumeRepresentation::Actor
Definition at line 70 of file vtkVolumeRepresentation.h.
◆ OutlineSource
vtkNew<vtkOutlineSource> vtkVolumeRepresentation::OutlineSource
Definition at line 71 of file vtkVolumeRepresentation.h.
◆ DataSize
unsigned long vtkVolumeRepresentation::DataSize = 0
Definition at line 73 of file vtkVolumeRepresentation.h.
◆ DataBounds
double vtkVolumeRepresentation::DataBounds[6]
Definition at line 74 of file vtkVolumeRepresentation.h.
◆ MapScalars
bool vtkVolumeRepresentation::MapScalars = true
Definition at line 76 of file vtkVolumeRepresentation.h.
◆ MultiComponentsMapping
bool vtkVolumeRepresentation::MultiComponentsMapping = false
Definition at line 77 of file vtkVolumeRepresentation.h.
◆ UseSeparateOpacityArray
bool vtkVolumeRepresentation::UseSeparateOpacityArray = false
Definition at line 79 of file vtkVolumeRepresentation.h.
◆ OpacityArrayName
std::string vtkVolumeRepresentation::OpacityArrayName
Definition at line 80 of file vtkVolumeRepresentation.h.
◆ OpacityArrayFieldAssociation
int vtkVolumeRepresentation::OpacityArrayFieldAssociation = -1
Definition at line 81 of file vtkVolumeRepresentation.h.
◆ OpacityArrayComponent
int vtkVolumeRepresentation::OpacityArrayComponent = -1
Definition at line 82 of file vtkVolumeRepresentation.h.
