vtkStructuredGridVolumeRepresentation Class Reference
representation for rendering vtkStructuredGrid as volume. More...
#include <vtkStructuredGridVolumeRepresentation.h>
Inheritance diagram for vtkStructuredGridVolumeRepresentation:
Collaboration diagram for vtkStructuredGridVolumeRepresentation:
typedef vtkUnstructuredGridVolumeRepresentation Superclass
- Public Types inherited from vtkUnstructuredGridVolumeRepresentation
typedef vtkVolumeRepresentation Superclass
- Public Types inherited from vtkVolumeRepresentation
enum  DesiredOutputPrecision
- Public Member Functions inherited from vtkUnstructuredGridVolumeRepresentation
void AddVolumeMapper (const char *name, vtkAbstractVolumeMapper *)
 Register a volume mapper with the representation. More...
void SetSamplingDimensions (int dims[3])
void SetSamplingDimensions (int xdim, int ydim, int zdim)
virtual void SetActiveVolumeMapper (const char *)
 Set the active volume mapper to use. More...
vtkAbstractVolumeMapper * GetActiveVolumeMapper ()
void SetActiveAssembly (const char *)
 Forwarded to vtkVolumeRepresentationPreprocessor. More...
void AddBlockSelector (const char *)
void RemoveAllBlockSelectors ()
virtual void SetUseDataPartitions (bool)
 Specify whether or not to redistribute the data. More...
virtual bool GetUseDataPartitions ()
- Public Member Functions inherited from vtkVolumeRepresentation
void SetVisibility (bool val) override
void SetOrientation (double, double, double)
void SetOrigin (double, double, double)
void SetPickable (int val)
void SetPosition (double, double, double)
void SetScale (double, double, double)
void SetInterpolationType (int val)
void SetColor (vtkColorTransferFunction *lut)
void SetScalarOpacity (vtkPiecewiseFunction *pwf)
void SetScalarOpacityUnitDistance (double val)
void SetMapScalars (bool)
void SetMultiComponentsMapping (bool)
void SetUseSeparateOpacityArray (bool)
void SelectOpacityArray (int, int, int, int, const char *name)
void SelectOpacityArrayComponent (int component)
vtkPVLODVolume * GetActor ()
 Provides access to the actor used by this representation. More...
virtual void MarkModified ()
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkStructuredGridVolumeRepresentation * New ()
static vtkStructuredGridVolumeRepresentation * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkUnstructuredGridVolumeRepresentation
static vtkUnstructuredGridVolumeRepresentation * New ()
static vtkUnstructuredGridVolumeRepresentation * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkVolumeRepresentation
static vtkVolumeRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkStructuredGridVolumeRepresentation ()
 ~vtkStructuredGridVolumeRepresentation () override
- Protected Member Functions inherited from vtkUnstructuredGridVolumeRepresentation
 vtkUnstructuredGridVolumeRepresentation ()
 ~vtkUnstructuredGridVolumeRepresentation () override
virtual void UpdateMapperParameters ()
 Passes on parameters to the active volume mapper. More...
int ProcessViewRequestResampleToImage (vtkInformationRequestKey *request_type, vtkInformation *inInfo, vtkInformation *outInfo)
int RequestDataResampleToImage (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector)
- Protected Member Functions inherited from vtkVolumeRepresentation
 vtkVolumeRepresentation ()
 ~vtkVolumeRepresentation () override
bool AppendOpacityComponent (vtkDataSet *dataset)
 Appends a designated opacity component to a scalar array used for color/opacity mapping. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Protected Attributes inherited from vtkUnstructuredGridVolumeRepresentation
vtkNew< vtkVolumeRepresentationPreprocessor > Preprocessor
vtkNew< vtkProjectedTetrahedraMapper > DefaultMapper
vtkNew< vtkResampleToImage > ResampleToImageFilter
vtkNew< vtkPVGeometryFilter > LODGeometryFilter
vtkNew< vtkPolyDataMapper > LODMapper
bool UseDataPartitions = false
- Protected Attributes inherited from vtkVolumeRepresentation
vtkNew< vtkVolumeProperty > Property
vtkSmartPointer< vtkPVLODVolume > Actor
vtkNew< vtkOutlineSource > OutlineSource
unsigned long DataSize = 0
double DataBounds [6]
bool MapScalars = true
bool MultiComponentsMapping = false
bool UseSeparateOpacityArray = false
std::string OpacityArrayName
int OpacityArrayFieldAssociation = -1
int OpacityArrayComponent = -1
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
vtkStructuredGridVolumeRepresentation is a representation for volume rendering vtkStructuredGrid datasets. For the mast part the work is done by vtkUnstructuredGridVolumeRepresentation. It converts the input vtkStructuredGrid to vtkUnstructuredGrid and then renders it.
Definition at line 18 of file vtkStructuredGridVolumeRepresentation.h.
Definition at line 23 of file vtkStructuredGridVolumeRepresentation.h.
◆ vtkStructuredGridVolumeRepresentation()
vtkStructuredGridVolumeRepresentation::vtkStructuredGridVolumeRepresentation ( )
◆ ~vtkStructuredGridVolumeRepresentation()
vtkStructuredGridVolumeRepresentation::~vtkStructuredGridVolumeRepresentation ( )
static vtkStructuredGridVolumeRepresentation* vtkStructuredGridVolumeRepresentation::New ( )
virtual const char* vtkStructuredGridVolumeRepresentation::GetClassName ( )
static int vtkStructuredGridVolumeRepresentation::IsTypeOf ( const char *  type)
virtual int vtkStructuredGridVolumeRepresentation::IsA ( const char *  type)
static vtkStructuredGridVolumeRepresentation* vtkStructuredGridVolumeRepresentation::SafeDownCast ( vtkObject *  o)
void vtkStructuredGridVolumeRepresentation::PrintSelf ( ostream &  os,
◆ FillInputPortInformation()
int vtkStructuredGridVolumeRepresentation::FillInputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
Fill input port information.
