vtkSciVizStatistics Class Referenceabstract
Abstract base class for computing statistics with vtkStatistics. More...
#include <vtkSciVizStatistics.h>
Inheritance diagram for vtkSciVizStatistics:
Collaboration diagram for vtkSciVizStatistics:
enum  Tasks { MODEL_INPUT, CREATE_MODEL, ASSESS_INPUT, MODEL_AND_ASSESS }
 Possible tasks the filter can perform. More...
typedef vtkTableAlgorithm Superclass
- Public Types inherited from vtkTableAlgorithm
enum  DesiredOutputPrecision
int GetNumberOfAttributeArrays ()
 Return the number of columns available for the current value of AttributeMode. More...
const char * GetAttributeArrayName (int n)
 Get the name of the n-th array ffor the current value of AttributeMode. More...
int GetAttributeArrayStatus (const char *arrName)
 Get the status of the specified array (i.e., whether or not it is a column of interest). More...
vtkInformationIntegerKey * MULTIPLE_MODELS ()
 A key used to mark the output model data object (output port 0) when it is a multiblock of models (any of which may be multiblock dataset themselves) as opposed to a multiblock dataset containing a single model. More...
virtual int GetAttributeMode ()
 Set/get the type of field attribute (cell, point, field) More...
virtual void SetAttributeMode (int)
void EnableAttributeArray (const char *arrName)
 An alternate interface for preparing a selection of arrays in ParaView. More...
void ClearAttributeArrays ()
virtual void SetTrainingFraction (double)
 Set/get the amount of data to be used for training. More...
virtual double GetTrainingFraction ()
virtual void SetController (vtkMultiProcessController *)
 Get/Set the multiprocess controller. More...
virtual void SetTask (int)
 Set/get whether this filter should create a model of the input or assess the input or both. More...
virtual int GetTask ()
- Public Member Functions inherited from vtkTableAlgorithm
vtkTableAlgorithm * NewInstance () const
vtkTable * GetOutput ()
vtkTable * GetOutput (int index)
void SetInputData (vtkDataObject *obj)
void SetInputData (int index, vtkDataObject *obj)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkSciVizStatistics * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkTableAlgorithm
static vtkTableAlgorithm * New ()
static vtkTableAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkSciVizStatistics ()
 ~vtkSciVizStatistics () override
int ProcessRequest (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) override
virtual int RequestDataObject (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output)
int RequestData (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) override
virtual int RequestData (vtkCompositeDataSet *compDataOu, vtkCompositeDataSet *compModelOu, vtkCompositeDataSet *compDataIn, vtkCompositeDataSet *compModelIn, vtkDataObject *singleModel)
virtual int RequestData (vtkDataObject *observationsOut, vtkDataObject *modelOut, vtkDataObject *observationsIn, vtkDataObject *modelIn)
virtual int PrepareFullDataTable (vtkTable *table, vtkFieldData *dataAttrIn)
virtual int PrepareTrainingTable (vtkTable *trainingTable, vtkTable *fullDataTable, vtkIdType numObservations)
virtual int LearnAndDerive (vtkMultiBlockDataSet *model, vtkTable *inData)=0
 Method subclasses must override to calculate a full model from the given input data. More...
virtual int AssessData (vtkTable *observations, vtkDataObject *dataset, vtkMultiBlockDataSet *model)=0
 Method subclasses must override to assess an input table given a model of the proper type. More...
virtual vtkIdType GetNumberOfObservationsForTraining (vtkIdType N)
 Subclasses may (but need not) override this function to guarantee that some minimum number of observations are included in the training data. More...
void ShallowCopy (vtkDataObject *out, vtkDataObject *in)
 A variant of shallow copy that calls vtkDataObject::ShallowCopy() and then for composite datasets, creates clones for each leaf node that then shallow copies the fields and geometry. More...
- Protected Member Functions inherited from vtkTableAlgorithm
 vtkTableAlgorithm ()
 ~vtkTableAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
int AttributeMode
int Task
double TrainingFraction
vtkSciVizStatisticsP * P
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
This filter either computes a statistical model of a dataset or takes such a model as its second input. Then, the model (however it is obtained) may optionally be used to assess the input dataset.
This class serves as a base class that handles table conversion, interfacing with the array selection in the ParaView user interface, and provides a simplified interface to vtkStatisticsAlgorithm.
Thanks to David Thompson and Philippe Pebay from Sandia National Laboratories for implementing this class. Updated by Philippe Pebay, Kitware SAS 2012
Definition at line 36 of file vtkSciVizStatistics.h.
Definition at line 39 of file vtkSciVizStatistics.h.
◆ Tasks
The MODEL_AND_ASSESS task is not recommended; you should never evaluate data with a model if that data was used to create the model. Doing so can result in a too-liberal estimate of model error, especially if overfitting occurs. Because we expect that MODEL_AND_ASSESS, despite being ill-advised, will be frequently used the TrainingFraction parameter has been created.
Enumerator
MODEL_INPUT
Execute Learn and Derive operations of a statistical engine on the input dataset.
CREATE_MODEL
Create a statistical model from a random subset the input dataset.
ASSESS_INPUT
Assess the input dataset using a statistical model from input port 1.
MODEL_AND_ASSESS
Create a statistical model of the input dataset and use it to assess the dataset.
This is a bad idea.
Definition at line 109 of file vtkSciVizStatistics.h.
◆ vtkSciVizStatistics()
vtkSciVizStatistics::vtkSciVizStatistics ( )
◆ ~vtkSciVizStatistics()
vtkSciVizStatistics::~vtkSciVizStatistics ( )
virtual const char* vtkSciVizStatistics::GetClassName ( )
static int vtkSciVizStatistics::IsTypeOf ( const char *  type)
virtual int vtkSciVizStatistics::IsA ( const char *  type)
static vtkSciVizStatistics* vtkSciVizStatistics::SafeDownCast ( vtkObject *  o)
void vtkSciVizStatistics::PrintSelf ( ostream &  os,
Reimplemented from vtkTableAlgorithm.
◆ GetAttributeMode()
virtual int vtkSciVizStatistics::GetAttributeMode ( )
◆ SetAttributeMode()
virtual void vtkSciVizStatistics::SetAttributeMode ( int  )
◆ GetNumberOfAttributeArrays()
int vtkSciVizStatistics::GetNumberOfAttributeArrays ( )
◆ GetAttributeArrayName()
const char* vtkSciVizStatistics::GetAttributeArrayName ( int  n)
◆ GetAttributeArrayStatus()
int vtkSciVizStatistics::GetAttributeArrayStatus ( const char *  arrName)
◆ EnableAttributeArray()
void vtkSciVizStatistics::EnableAttributeArray ( const char *  arrName)
◆ ClearAttributeArrays()
void vtkSciVizStatistics::ClearAttributeArrays ( )
◆ SetTrainingFraction()
virtual void vtkSciVizStatistics::SetTrainingFraction ( double  )
When 0.0 < TrainingFraction < 1.0, a randomly-sampled subset of the data is used for training. When an assessment is requested, all data (including the training data) is assessed, regardless of the value of TrainingFraction. The default value is 0.1.
The random sample of the original dataset (say, of size N) is obtained by choosing N random numbers in [0,1). Any sample where the random number is less than TrainingFraction is included in the training data. Samples are then randomly added or removed from the training data until it is the desired size.
◆ GetTrainingFraction()
virtual double vtkSciVizStatistics::GetTrainingFraction ( )
◆ SetController()
virtual void vtkSciVizStatistics::SetController ( vtkMultiProcessController *  )
If no controller is set, single process is assumed.
◆ GetController()
virtual vtkMultiProcessController* vtkSciVizStatistics::GetController ( )
◆ SetTask()
virtual void vtkSciVizStatistics::SetTask ( int  )
This should take on a value from the Tasks enum. The default is MODEL_AND_ASSESS.
◆ GetTask()
virtual int vtkSciVizStatistics::GetTask ( )
◆ MULTIPLE_MODELS()
vtkInformationIntegerKey* vtkSciVizStatistics::MULTIPLE_MODELS ( )
◆ FillInputPortInformation()
int vtkSciVizStatistics::FillInputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
◆ FillOutputPortInformation()
int vtkSciVizStatistics::FillOutputPortInformation ( int  port,
◆ ProcessRequest()
int vtkSciVizStatistics::ProcessRequest ( vtkInformation *  request,
vtkInformationVector **  input,
vtkInformationVector *  output
◆ RequestDataObject()
virtual int vtkSciVizStatistics::RequestDataObject ( vtkInformation *  request,
protectedvirtual
◆ RequestData() [1/3]
int vtkSciVizStatistics::RequestData ( vtkInformation *  request,
◆ RequestData() [2/3]
virtual int vtkSciVizStatistics::RequestData ( vtkCompositeDataSet *  compDataOu,
vtkCompositeDataSet *  compModelOu,
vtkCompositeDataSet *  compDataIn,
vtkCompositeDataSet *  compModelIn,
vtkDataObject *  singleModel
protectedvirtual
◆ RequestData() [3/3]
virtual int vtkSciVizStatistics::RequestData ( vtkDataObject *  observationsOut,
vtkDataObject *  modelOut,
vtkDataObject *  observationsIn,
vtkDataObject *  modelIn
protectedvirtual
◆ PrepareFullDataTable()
virtual int vtkSciVizStatistics::PrepareFullDataTable ( vtkTable *  table,
vtkFieldData *  dataAttrIn
protectedvirtual
◆ PrepareTrainingTable()
virtual int vtkSciVizStatistics::PrepareTrainingTable ( vtkTable *  trainingTable,
vtkTable *  fullDataTable,
protectedvirtual
◆ LearnAndDerive()
virtual int vtkSciVizStatistics::LearnAndDerive ( vtkMultiBlockDataSet *  model,
vtkTable *  inData
protectedpure virtual
The model should be placed on the first output port of the passed vtkInformationVector as well as returned in the model parameter.
Implemented in vtkPSciVizMultiCorrelativeStats, vtkPSciVizKMeans, vtkPSciVizPCAStats, vtkPSciVizContingencyStats, and vtkPSciVizDescriptiveStats.
◆ AssessData()
virtual int vtkSciVizStatistics::AssessData ( vtkTable *  observations,
vtkDataObject *  dataset,
The dataset parameter contains a shallow copy of input port 0 and should be modified to include the assessment.
Adding new arrays to point/cell/vertex/edge data should not pose a problem, but any alterations to the dataset itself will probably require that you create a deep copy before modification.
Parameters
observations- a table containing the field data of the dataset converted to a table
dataset- a shallow copy of the input dataset that should be altered to include an assessment of the output.
model- the statistical model with which to assess the observations.
◆ GetNumberOfObservationsForTraining()
virtual vtkIdType vtkSciVizStatistics::GetNumberOfObservationsForTraining ( vtkIdType  N)
protectedvirtual
By default, it returns the maximum of: observations->GetNumberOfRows() * this->TrainingFraction and min( observations->GetNumberOfRows(), 100 ). Thus, it will require the entire set of observations unless there are more than 100. Parameter N is the number of non-ghost observations.
◆ ShallowCopy()
void vtkSciVizStatistics::ShallowCopy ( vtkDataObject *  out,
vtkDataObject *  in
◆ AttributeMode
int vtkSciVizStatistics::AttributeMode
Definition at line 200 of file vtkSciVizStatistics.h.
◆ Task
int vtkSciVizStatistics::Task
Definition at line 201 of file vtkSciVizStatistics.h.
◆ TrainingFraction
double vtkSciVizStatistics::TrainingFraction
Definition at line 202 of file vtkSciVizStatistics.h.
◆ P
vtkSciVizStatisticsP* vtkSciVizStatistics::P
Definition at line 203 of file vtkSciVizStatistics.h.
◆ Controller
vtkMultiProcessController* vtkSciVizStatistics::Controller
Definition at line 204 of file vtkSciVizStatistics.h.
