vtkPSciVizPCAStats Class Reference
Perform PCA on data and/or project data into a subspace defined by the PCA. More...
#include <vtkPSciVizPCAStats.h>
Inheritance diagram for vtkPSciVizPCAStats:
Collaboration diagram for vtkPSciVizPCAStats:
typedef vtkSciVizStatistics Superclass
- Public Types inherited from vtkSciVizStatistics
enum  Tasks { MODEL_INPUT, CREATE_MODEL, ASSESS_INPUT, MODEL_AND_ASSESS }
 Possible tasks the filter can perform. More...
typedef vtkTableAlgorithm Superclass
- Public Types inherited from vtkTableAlgorithm
enum  DesiredOutputPrecision
virtual void SetNormalizationScheme (int)
virtual int GetNormalizationScheme ()
virtual void SetBasisScheme (int)
virtual int GetBasisScheme ()
virtual void SetFixedBasisSize (int)
virtual int GetFixedBasisSize ()
virtual void SetFixedBasisEnergy (double)
virtual double GetFixedBasisEnergy ()
virtual void SetRobustPCA (bool)
virtual bool GetRobustPCA ()
virtual void RobustPCAOn ()
virtual void RobustPCAOff ()
- Public Member Functions inherited from vtkSciVizStatistics
int GetNumberOfAttributeArrays ()
 Return the number of columns available for the current value of AttributeMode. More...
const char * GetAttributeArrayName (int n)
 Get the name of the n-th array ffor the current value of AttributeMode. More...
int GetAttributeArrayStatus (const char *arrName)
 Get the status of the specified array (i.e., whether or not it is a column of interest). More...
vtkInformationIntegerKey * MULTIPLE_MODELS ()
 A key used to mark the output model data object (output port 0) when it is a multiblock of models (any of which may be multiblock dataset themselves) as opposed to a multiblock dataset containing a single model. More...
virtual int GetAttributeMode ()
 Set/get the type of field attribute (cell, point, field) More...
virtual void SetAttributeMode (int)
void EnableAttributeArray (const char *arrName)
 An alternate interface for preparing a selection of arrays in ParaView. More...
void ClearAttributeArrays ()
virtual void SetTrainingFraction (double)
 Set/get the amount of data to be used for training. More...
virtual double GetTrainingFraction ()
virtual void SetController (vtkMultiProcessController *)
 Get/Set the multiprocess controller. More...
virtual void SetTask (int)
 Set/get whether this filter should create a model of the input or assess the input or both. More...
virtual int GetTask ()
- Public Member Functions inherited from vtkTableAlgorithm
vtkTableAlgorithm * NewInstance () const
vtkTable * GetOutput ()
vtkTable * GetOutput (int index)
void SetInputData (vtkDataObject *obj)
void SetInputData (int index, vtkDataObject *obj)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPSciVizPCAStats * New ()
static vtkPSciVizPCAStats * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSciVizStatistics
static vtkSciVizStatistics * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkTableAlgorithm
static vtkTableAlgorithm * New ()
static vtkTableAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkPSciVizPCAStats ()
 ~vtkPSciVizPCAStats () override
int LearnAndDerive (vtkMultiBlockDataSet *model, vtkTable *inData) override
 Method subclasses must override to calculate a full model from the given input data. More...
int AssessData (vtkTable *observations, vtkDataObject *dataset, vtkMultiBlockDataSet *model) override
 Method subclasses must override to assess an input table given a model of the proper type. More...
- Protected Member Functions inherited from vtkSciVizStatistics
 vtkSciVizStatistics ()
 ~vtkSciVizStatistics () override
int ProcessRequest (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) override
virtual int RequestDataObject (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output)
int RequestData (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) override
virtual int RequestData (vtkCompositeDataSet *compDataOu, vtkCompositeDataSet *compModelOu, vtkCompositeDataSet *compDataIn, vtkCompositeDataSet *compModelIn, vtkDataObject *singleModel)
virtual int RequestData (vtkDataObject *observationsOut, vtkDataObject *modelOut, vtkDataObject *observationsIn, vtkDataObject *modelIn)
virtual int PrepareFullDataTable (vtkTable *table, vtkFieldData *dataAttrIn)
virtual int PrepareTrainingTable (vtkTable *trainingTable, vtkTable *fullDataTable, vtkIdType numObservations)
virtual vtkIdType GetNumberOfObservationsForTraining (vtkIdType N)
 Subclasses may (but need not) override this function to guarantee that some minimum number of observations are included in the training data. More...
void ShallowCopy (vtkDataObject *out, vtkDataObject *in)
 A variant of shallow copy that calls vtkDataObject::ShallowCopy() and then for composite datasets, creates clones for each leaf node that then shallow copies the fields and geometry. More...
- Protected Member Functions inherited from vtkTableAlgorithm
 vtkTableAlgorithm ()
 ~vtkTableAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
int NormalizationScheme
int BasisScheme
int FixedBasisSize
double FixedBasisEnergy
bool RobustPCA
- Protected Attributes inherited from vtkSciVizStatistics
int AttributeMode
int Task
double TrainingFraction
vtkSciVizStatisticsP * P
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
This filter either computes a statistical model of a dataset or takes such a model as its second input. Then, the model (however it is obtained) may optionally be used to assess the input dataset.
This filter performs additional analysis above and beyond the vtkPSciVizMultiCorrelativeStats filter. It computes the eigenvalues and eigenvectors of the covariance matrix from the multicorrelative filter. Data is then assessed by projecting the original tuples into a possibly lower-dimensional space.
Since the PCA filter uses the multicorrelative filter's analysis, it shares the same raw covariance table specified in the multicorrelative documentation. The second table in the multiblock dataset comprising the model output is an expanded version of the multicorrelative version.
As with the multicorrlative filter, the second model table contains the mean values, the upper-triangular portion of the symmetric covariance matrix, and the non-zero lower-triangular portion of the Cholesky decomposition of the covariance matrix. Below these entries are the eigenvalues of the covariance matrix (in the column labeled "Mean") and the eigenvectors (as row vectors) in an additional NxN matrix.
Definition at line 40 of file vtkPSciVizPCAStats.h.
Definition at line 44 of file vtkPSciVizPCAStats.h.
◆ vtkPSciVizPCAStats()
vtkPSciVizPCAStats::vtkPSciVizPCAStats ( )
◆ ~vtkPSciVizPCAStats()
vtkPSciVizPCAStats::~vtkPSciVizPCAStats ( )
static vtkPSciVizPCAStats* vtkPSciVizPCAStats::New ( )
virtual const char* vtkPSciVizPCAStats::GetClassName ( )
Reimplemented from vtkSciVizStatistics.
static int vtkPSciVizPCAStats::IsTypeOf ( const char *  type)
virtual int vtkPSciVizPCAStats::IsA ( const char *  type)
static vtkPSciVizPCAStats* vtkPSciVizPCAStats::SafeDownCast ( vtkObject *  o)
void vtkPSciVizPCAStats::PrintSelf ( ostream &  os,
Reimplemented from vtkTableAlgorithm.
◆ SetNormalizationScheme()
virtual void vtkPSciVizPCAStats::SetNormalizationScheme ( int  )
◆ GetNormalizationScheme()
virtual int vtkPSciVizPCAStats::GetNormalizationScheme ( )
◆ SetBasisScheme()
virtual void vtkPSciVizPCAStats::SetBasisScheme ( int  )
◆ GetBasisScheme()
virtual int vtkPSciVizPCAStats::GetBasisScheme ( )
◆ SetFixedBasisSize()
virtual void vtkPSciVizPCAStats::SetFixedBasisSize ( int  )
◆ GetFixedBasisSize()
virtual int vtkPSciVizPCAStats::GetFixedBasisSize ( )
◆ SetFixedBasisEnergy()
virtual void vtkPSciVizPCAStats::SetFixedBasisEnergy ( double  )
◆ GetFixedBasisEnergy()
virtual double vtkPSciVizPCAStats::GetFixedBasisEnergy ( )
◆ SetRobustPCA()
virtual void vtkPSciVizPCAStats::SetRobustPCA ( bool  )
◆ GetRobustPCA()
virtual bool vtkPSciVizPCAStats::GetRobustPCA ( )
◆ RobustPCAOn()
virtual void vtkPSciVizPCAStats::RobustPCAOn ( )
◆ RobustPCAOff()
virtual void vtkPSciVizPCAStats::RobustPCAOff ( )
◆ LearnAndDerive()
int vtkPSciVizPCAStats::LearnAndDerive ( vtkMultiBlockDataSet *  model,
vtkTable *  inData
overrideprotectedvirtual
The model should be placed on the first output port of the passed vtkInformationVector as well as returned in the model parameter.
Implements vtkSciVizStatistics.
◆ AssessData()
int vtkPSciVizPCAStats::AssessData ( vtkTable *  observations,
vtkDataObject *  dataset,
The dataset parameter contains a shallow copy of input port 0 and should be modified to include the assessment.
Adding new arrays to point/cell/vertex/edge data should not pose a problem, but any alterations to the dataset itself will probably require that you create a deep copy before modification.
Parameters
observations- a table containing the field data of the dataset converted to a table
dataset- a shallow copy of the input dataset that should be altered to include an assessment of the output.
model- the statistical model with which to assess the observations.
◆ NormalizationScheme
int vtkPSciVizPCAStats::NormalizationScheme
Definition at line 71 of file vtkPSciVizPCAStats.h.
◆ BasisScheme
int vtkPSciVizPCAStats::BasisScheme
Definition at line 72 of file vtkPSciVizPCAStats.h.
◆ FixedBasisSize
int vtkPSciVizPCAStats::FixedBasisSize
Definition at line 73 of file vtkPSciVizPCAStats.h.
◆ FixedBasisEnergy
double vtkPSciVizPCAStats::FixedBasisEnergy
Definition at line 74 of file vtkPSciVizPCAStats.h.
◆ RobustPCA
bool vtkPSciVizPCAStats::RobustPCA
Definition at line 75 of file vtkPSciVizPCAStats.h.
