vtkPSciVizDescriptiveStats Class Reference
Provide access to VTK descriptive statistics. More...
#include <vtkPSciVizDescriptiveStats.h>
Inheritance diagram for vtkPSciVizDescriptiveStats:
Collaboration diagram for vtkPSciVizDescriptiveStats:
typedef vtkSciVizStatistics Superclass
- Public Types inherited from vtkSciVizStatistics
enum  Tasks { MODEL_INPUT, CREATE_MODEL, ASSESS_INPUT, MODEL_AND_ASSESS }
 Possible tasks the filter can perform. More...
typedef vtkTableAlgorithm Superclass
- Public Types inherited from vtkTableAlgorithm
enum  DesiredOutputPrecision
virtual void SetSignedDeviations (int)
virtual int GetSignedDeviations ()
- Public Member Functions inherited from vtkSciVizStatistics
int GetNumberOfAttributeArrays ()
 Return the number of columns available for the current value of AttributeMode. More...
const char * GetAttributeArrayName (int n)
 Get the name of the n-th array ffor the current value of AttributeMode. More...
int GetAttributeArrayStatus (const char *arrName)
 Get the status of the specified array (i.e., whether or not it is a column of interest). More...
vtkInformationIntegerKey * MULTIPLE_MODELS ()
 A key used to mark the output model data object (output port 0) when it is a multiblock of models (any of which may be multiblock dataset themselves) as opposed to a multiblock dataset containing a single model. More...
virtual int GetAttributeMode ()
 Set/get the type of field attribute (cell, point, field) More...
virtual void SetAttributeMode (int)
void EnableAttributeArray (const char *arrName)
 An alternate interface for preparing a selection of arrays in ParaView. More...
void ClearAttributeArrays ()
virtual void SetTrainingFraction (double)
 Set/get the amount of data to be used for training. More...
virtual double GetTrainingFraction ()
virtual void SetController (vtkMultiProcessController *)
 Get/Set the multiprocess controller. More...
virtual void SetTask (int)
 Set/get whether this filter should create a model of the input or assess the input or both. More...
virtual int GetTask ()
- Public Member Functions inherited from vtkTableAlgorithm
vtkTableAlgorithm * NewInstance () const
vtkTable * GetOutput ()
vtkTable * GetOutput (int index)
void SetInputData (vtkDataObject *obj)
void SetInputData (int index, vtkDataObject *obj)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPSciVizDescriptiveStats * New ()
static vtkPSciVizDescriptiveStats * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSciVizStatistics
static vtkSciVizStatistics * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkTableAlgorithm
static vtkTableAlgorithm * New ()
static vtkTableAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkPSciVizDescriptiveStats ()
 ~vtkPSciVizDescriptiveStats () override
int LearnAndDerive (vtkMultiBlockDataSet *model, vtkTable *inData) override
 Method subclasses must override to calculate a full model from the given input data. More...
int AssessData (vtkTable *observations, vtkDataObject *dataset, vtkMultiBlockDataSet *model) override
 Method subclasses must override to assess an input table given a model of the proper type. More...
- Protected Member Functions inherited from vtkSciVizStatistics
 vtkSciVizStatistics ()
 ~vtkSciVizStatistics () override
int ProcessRequest (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) override
virtual int RequestDataObject (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output)
int RequestData (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) override
virtual int RequestData (vtkCompositeDataSet *compDataOu, vtkCompositeDataSet *compModelOu, vtkCompositeDataSet *compDataIn, vtkCompositeDataSet *compModelIn, vtkDataObject *singleModel)
virtual int RequestData (vtkDataObject *observationsOut, vtkDataObject *modelOut, vtkDataObject *observationsIn, vtkDataObject *modelIn)
virtual int PrepareFullDataTable (vtkTable *table, vtkFieldData *dataAttrIn)
virtual int PrepareTrainingTable (vtkTable *trainingTable, vtkTable *fullDataTable, vtkIdType numObservations)
virtual vtkIdType GetNumberOfObservationsForTraining (vtkIdType N)
 Subclasses may (but need not) override this function to guarantee that some minimum number of observations are included in the training data. More...
void ShallowCopy (vtkDataObject *out, vtkDataObject *in)
 A variant of shallow copy that calls vtkDataObject::ShallowCopy() and then for composite datasets, creates clones for each leaf node that then shallow copies the fields and geometry. More...
- Protected Member Functions inherited from vtkTableAlgorithm
 vtkTableAlgorithm ()
 ~vtkTableAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
int SignedDeviations
- Protected Attributes inherited from vtkSciVizStatistics
int AttributeMode
int Task
double TrainingFraction
vtkSciVizStatisticsP * P
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
This filter provides access to the features of vtkDescriptiveStatistics. See VTK documentation for details
Thanks to David Thompson and Philippe Pebay from Sandia National Laboratories for implementing this class.
Definition at line 22 of file vtkPSciVizDescriptiveStats.h.
Definition at line 27 of file vtkPSciVizDescriptiveStats.h.
◆ vtkPSciVizDescriptiveStats()
vtkPSciVizDescriptiveStats::vtkPSciVizDescriptiveStats ( )
◆ ~vtkPSciVizDescriptiveStats()
vtkPSciVizDescriptiveStats::~vtkPSciVizDescriptiveStats ( )
static vtkPSciVizDescriptiveStats* vtkPSciVizDescriptiveStats::New ( )
virtual const char* vtkPSciVizDescriptiveStats::GetClassName ( )
Reimplemented from vtkSciVizStatistics.
static int vtkPSciVizDescriptiveStats::IsTypeOf ( const char *  type)
virtual int vtkPSciVizDescriptiveStats::IsA ( const char *  type)
static vtkPSciVizDescriptiveStats* vtkPSciVizDescriptiveStats::SafeDownCast ( vtkObject *  o)
void vtkPSciVizDescriptiveStats::PrintSelf ( ostream &  os,
Reimplemented from vtkTableAlgorithm.
◆ SetSignedDeviations()
virtual void vtkPSciVizDescriptiveStats::SetSignedDeviations ( int  )
◆ GetSignedDeviations()
virtual int vtkPSciVizDescriptiveStats::GetSignedDeviations ( )
◆ LearnAndDerive()
int vtkPSciVizDescriptiveStats::LearnAndDerive ( vtkMultiBlockDataSet *  model,
vtkTable *  inData
overrideprotectedvirtual
The model should be placed on the first output port of the passed vtkInformationVector as well as returned in the model parameter.
Implements vtkSciVizStatistics.
◆ AssessData()
int vtkPSciVizDescriptiveStats::AssessData ( vtkTable *  observations,
vtkDataObject *  dataset,
The dataset parameter contains a shallow copy of input port 0 and should be modified to include the assessment.
Adding new arrays to point/cell/vertex/edge data should not pose a problem, but any alterations to the dataset itself will probably require that you create a deep copy before modification.
Parameters
observations- a table containing the field data of the dataset converted to a table
dataset- a shallow copy of the input dataset that should be altered to include an assessment of the output.
model- the statistical model with which to assess the observations.
◆ SignedDeviations
int vtkPSciVizDescriptiveStats::SignedDeviations
Definition at line 41 of file vtkPSciVizDescriptiveStats.h.
