vtkPSciVizKMeans Class Reference
Find k cluster centers and/or assess the closest center and distance to it for each datum. More...
#include <vtkPSciVizKMeans.h>
Inheritance diagram for vtkPSciVizKMeans:
Collaboration diagram for vtkPSciVizKMeans:
typedef vtkSciVizStatistics Superclass
- Public Types inherited from vtkSciVizStatistics
enum  Tasks { MODEL_INPUT, CREATE_MODEL, ASSESS_INPUT, MODEL_AND_ASSESS }
 Possible tasks the filter can perform. More...
typedef vtkTableAlgorithm Superclass
- Public Types inherited from vtkTableAlgorithm
enum  DesiredOutputPrecision
virtual void SetK (int)
 The number of cluster centers. More...
virtual int GetK ()
virtual void SetMaxNumIterations (int)
 The maximum number of iterations to perform when converging on cluster centers. More...
virtual int GetMaxNumIterations ()
virtual void SetTolerance (double)
 The relative tolerance on cluster centers that will cause early termination of the algorithm. More...
virtual double GetTolerance ()
- Public Member Functions inherited from vtkSciVizStatistics
int GetNumberOfAttributeArrays ()
 Return the number of columns available for the current value of AttributeMode. More...
const char * GetAttributeArrayName (int n)
 Get the name of the n-th array ffor the current value of AttributeMode. More...
int GetAttributeArrayStatus (const char *arrName)
 Get the status of the specified array (i.e., whether or not it is a column of interest). More...
vtkInformationIntegerKey * MULTIPLE_MODELS ()
 A key used to mark the output model data object (output port 0) when it is a multiblock of models (any of which may be multiblock dataset themselves) as opposed to a multiblock dataset containing a single model. More...
virtual int GetAttributeMode ()
 Set/get the type of field attribute (cell, point, field) More...
virtual void SetAttributeMode (int)
void EnableAttributeArray (const char *arrName)
 An alternate interface for preparing a selection of arrays in ParaView. More...
void ClearAttributeArrays ()
virtual void SetTrainingFraction (double)
 Set/get the amount of data to be used for training. More...
virtual double GetTrainingFraction ()
virtual void SetController (vtkMultiProcessController *)
 Get/Set the multiprocess controller. More...
virtual void SetTask (int)
 Set/get whether this filter should create a model of the input or assess the input or both. More...
virtual int GetTask ()
- Public Member Functions inherited from vtkTableAlgorithm
vtkTableAlgorithm * NewInstance () const
vtkTable * GetOutput ()
vtkTable * GetOutput (int index)
void SetInputData (vtkDataObject *obj)
void SetInputData (int index, vtkDataObject *obj)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPSciVizKMeans * New ()
static vtkPSciVizKMeans * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSciVizStatistics
static vtkSciVizStatistics * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkTableAlgorithm
static vtkTableAlgorithm * New ()
static vtkTableAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkPSciVizKMeans ()
 ~vtkPSciVizKMeans () override
int LearnAndDerive (vtkMultiBlockDataSet *model, vtkTable *inData) override
 Method subclasses must override to calculate a full model from the given input data. More...
int AssessData (vtkTable *observations, vtkDataObject *dataset, vtkMultiBlockDataSet *model) override
 Method subclasses must override to assess an input table given a model of the proper type. More...
- Protected Member Functions inherited from vtkSciVizStatistics
 vtkSciVizStatistics ()
 ~vtkSciVizStatistics () override
int ProcessRequest (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) override
virtual int RequestDataObject (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output)
int RequestData (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) override
virtual int RequestData (vtkCompositeDataSet *compDataOu, vtkCompositeDataSet *compModelOu, vtkCompositeDataSet *compDataIn, vtkCompositeDataSet *compModelIn, vtkDataObject *singleModel)
virtual int RequestData (vtkDataObject *observationsOut, vtkDataObject *modelOut, vtkDataObject *observationsIn, vtkDataObject *modelIn)
virtual int PrepareFullDataTable (vtkTable *table, vtkFieldData *dataAttrIn)
virtual int PrepareTrainingTable (vtkTable *trainingTable, vtkTable *fullDataTable, vtkIdType numObservations)
virtual vtkIdType GetNumberOfObservationsForTraining (vtkIdType N)
 Subclasses may (but need not) override this function to guarantee that some minimum number of observations are included in the training data. More...
void ShallowCopy (vtkDataObject *out, vtkDataObject *in)
 A variant of shallow copy that calls vtkDataObject::ShallowCopy() and then for composite datasets, creates clones for each leaf node that then shallow copies the fields and geometry. More...
- Protected Member Functions inherited from vtkTableAlgorithm
 vtkTableAlgorithm ()
 ~vtkTableAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
int K
int MaxNumIterations
double Tolerance
- Protected Attributes inherited from vtkSciVizStatistics
int AttributeMode
int Task
double TrainingFraction
vtkSciVizStatisticsP * P
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
This filter either computes a statistical model of a dataset or takes such a model as its second input. Then, the model (however it is obtained) may optionally be used to assess the input dataset.
This filter iteratively computes the center of k clusters in a space whose coordinates are specified by the arrays you select. The clusters are chosen as local minima of the sum of square Euclidean distances from each point to its nearest cluster center. The model is then a set of cluster centers. Data is assessed by assigning a cluster center and distance to the cluster to each point in the input data set.
Definition at line 28 of file vtkPSciVizKMeans.h.
Definition at line 32 of file vtkPSciVizKMeans.h.
◆ vtkPSciVizKMeans()
vtkPSciVizKMeans::vtkPSciVizKMeans ( )
◆ ~vtkPSciVizKMeans()
vtkPSciVizKMeans::~vtkPSciVizKMeans ( )
static vtkPSciVizKMeans* vtkPSciVizKMeans::New ( )
virtual const char* vtkPSciVizKMeans::GetClassName ( )
Reimplemented from vtkSciVizStatistics.
static int vtkPSciVizKMeans::IsTypeOf ( const char *  type)
virtual int vtkPSciVizKMeans::IsA ( const char *  type)
static vtkPSciVizKMeans* vtkPSciVizKMeans::SafeDownCast ( vtkObject *  o)
void vtkPSciVizKMeans::PrintSelf ( ostream &  os,
Reimplemented from vtkTableAlgorithm.
◆ SetK()
virtual void vtkPSciVizKMeans::SetK ( int  )
The initial centers will be chosen randomly. In the future the filter will accept an input table of initial cluster positions. The default value of K is 5.
◆ GetK()
virtual int vtkPSciVizKMeans::GetK ( )
◆ SetMaxNumIterations()
virtual void vtkPSciVizKMeans::SetMaxNumIterations ( int  )
The default value is 50 iterations.
◆ GetMaxNumIterations()
virtual int vtkPSciVizKMeans::GetMaxNumIterations ( )
◆ SetTolerance()
virtual void vtkPSciVizKMeans::SetTolerance ( double  )
The default value is 0.01: a 1 percent change in cluster coordinates.
◆ GetTolerance()
virtual double vtkPSciVizKMeans::GetTolerance ( )
◆ LearnAndDerive()
int vtkPSciVizKMeans::LearnAndDerive ( vtkMultiBlockDataSet *  model,
vtkTable *  inData
overrideprotectedvirtual
The model should be placed on the first output port of the passed vtkInformationVector as well as returned in the model parameter.
Implements vtkSciVizStatistics.
◆ AssessData()
int vtkPSciVizKMeans::AssessData ( vtkTable *  observations,
vtkDataObject *  dataset,
The dataset parameter contains a shallow copy of input port 0 and should be modified to include the assessment.
Adding new arrays to point/cell/vertex/edge data should not pose a problem, but any alterations to the dataset itself will probably require that you create a deep copy before modification.
Parameters
observations- a table containing the field data of the dataset converted to a table
dataset- a shallow copy of the input dataset that should be altered to include an assessment of the output.
model- the statistical model with which to assess the observations.
◆ K
int vtkPSciVizKMeans::K
Definition at line 72 of file vtkPSciVizKMeans.h.
◆ MaxNumIterations
int vtkPSciVizKMeans::MaxNumIterations
Definition at line 73 of file vtkPSciVizKMeans.h.
◆ Tolerance
double vtkPSciVizKMeans::Tolerance
Definition at line 74 of file vtkPSciVizKMeans.h.
