vtkPSciVizContingencyStats Class Reference
Derive contingency tables and use them to assess the likelihood of associations. More...
#include <vtkPSciVizContingencyStats.h>
Inheritance diagram for vtkPSciVizContingencyStats:
Collaboration diagram for vtkPSciVizContingencyStats:
typedef vtkSciVizStatistics Superclass
- Public Types inherited from vtkSciVizStatistics
enum  Tasks { MODEL_INPUT, CREATE_MODEL, ASSESS_INPUT, MODEL_AND_ASSESS }
 Possible tasks the filter can perform. More...
typedef vtkTableAlgorithm Superclass
- Public Types inherited from vtkTableAlgorithm
enum  DesiredOutputPrecision
- Public Member Functions inherited from vtkSciVizStatistics
int GetNumberOfAttributeArrays ()
 Return the number of columns available for the current value of AttributeMode. More...
const char * GetAttributeArrayName (int n)
 Get the name of the n-th array ffor the current value of AttributeMode. More...
int GetAttributeArrayStatus (const char *arrName)
 Get the status of the specified array (i.e., whether or not it is a column of interest). More...
vtkInformationIntegerKey * MULTIPLE_MODELS ()
 A key used to mark the output model data object (output port 0) when it is a multiblock of models (any of which may be multiblock dataset themselves) as opposed to a multiblock dataset containing a single model. More...
virtual int GetAttributeMode ()
 Set/get the type of field attribute (cell, point, field) More...
virtual void SetAttributeMode (int)
void EnableAttributeArray (const char *arrName)
 An alternate interface for preparing a selection of arrays in ParaView. More...
void ClearAttributeArrays ()
virtual void SetTrainingFraction (double)
 Set/get the amount of data to be used for training. More...
virtual double GetTrainingFraction ()
virtual void SetController (vtkMultiProcessController *)
 Get/Set the multiprocess controller. More...
virtual void SetTask (int)
 Set/get whether this filter should create a model of the input or assess the input or both. More...
virtual int GetTask ()
- Public Member Functions inherited from vtkTableAlgorithm
vtkTableAlgorithm * NewInstance () const
vtkTable * GetOutput ()
vtkTable * GetOutput (int index)
void SetInputData (vtkDataObject *obj)
void SetInputData (int index, vtkDataObject *obj)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPSciVizContingencyStats * New ()
static vtkPSciVizContingencyStats * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSciVizStatistics
static vtkSciVizStatistics * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkTableAlgorithm
static vtkTableAlgorithm * New ()
static vtkTableAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkPSciVizContingencyStats ()
 ~vtkPSciVizContingencyStats () override
int LearnAndDerive (vtkMultiBlockDataSet *model, vtkTable *inData) override
 Method subclasses must override to calculate a full model from the given input data. More...
int AssessData (vtkTable *observations, vtkDataObject *dataset, vtkMultiBlockDataSet *model) override
 Method subclasses must override to assess an input table given a model of the proper type. More...
- Protected Member Functions inherited from vtkSciVizStatistics
 vtkSciVizStatistics ()
 ~vtkSciVizStatistics () override
int ProcessRequest (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) override
virtual int RequestDataObject (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output)
int RequestData (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) override
virtual int RequestData (vtkCompositeDataSet *compDataOu, vtkCompositeDataSet *compModelOu, vtkCompositeDataSet *compDataIn, vtkCompositeDataSet *compModelIn, vtkDataObject *singleModel)
virtual int RequestData (vtkDataObject *observationsOut, vtkDataObject *modelOut, vtkDataObject *observationsIn, vtkDataObject *modelIn)
virtual int PrepareFullDataTable (vtkTable *table, vtkFieldData *dataAttrIn)
virtual int PrepareTrainingTable (vtkTable *trainingTable, vtkTable *fullDataTable, vtkIdType numObservations)
virtual vtkIdType GetNumberOfObservationsForTraining (vtkIdType N)
 Subclasses may (but need not) override this function to guarantee that some minimum number of observations are included in the training data. More...
void ShallowCopy (vtkDataObject *out, vtkDataObject *in)
 A variant of shallow copy that calls vtkDataObject::ShallowCopy() and then for composite datasets, creates clones for each leaf node that then shallow copies the fields and geometry. More...
- Protected Member Functions inherited from vtkTableAlgorithm
 vtkTableAlgorithm ()
 ~vtkTableAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Protected Attributes inherited from vtkSciVizStatistics
int AttributeMode
int Task
double TrainingFraction
vtkSciVizStatisticsP * P
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
This filter either computes a statistical model of a dataset or takes such a model as its second input. Then, the model (however it is obtained) may optionally be used to assess the input dataset.
This filter computes contingency tables between pairs of attributes. This result is a tabular bivariate probability distribution which serves as a Bayesian-style prior model. Data is assessed by computing
Finally, the summary statistics include the information entropy of the observations.
Definition at line 32 of file vtkPSciVizContingencyStats.h.
Definition at line 37 of file vtkPSciVizContingencyStats.h.
◆ vtkPSciVizContingencyStats()
vtkPSciVizContingencyStats::vtkPSciVizContingencyStats ( )
◆ ~vtkPSciVizContingencyStats()
vtkPSciVizContingencyStats::~vtkPSciVizContingencyStats ( )
static vtkPSciVizContingencyStats* vtkPSciVizContingencyStats::New ( )
virtual const char* vtkPSciVizContingencyStats::GetClassName ( )
Reimplemented from vtkSciVizStatistics.
static int vtkPSciVizContingencyStats::IsTypeOf ( const char *  type)
virtual int vtkPSciVizContingencyStats::IsA ( const char *  type)
static vtkPSciVizContingencyStats* vtkPSciVizContingencyStats::SafeDownCast ( vtkObject *  o)
void vtkPSciVizContingencyStats::PrintSelf ( ostream &  os,
Reimplemented from vtkTableAlgorithm.
◆ LearnAndDerive()
int vtkPSciVizContingencyStats::LearnAndDerive ( vtkMultiBlockDataSet *  model,
vtkTable *  inData
overrideprotectedvirtual
The model should be placed on the first output port of the passed vtkInformationVector as well as returned in the model parameter.
Implements vtkSciVizStatistics.
◆ AssessData()
int vtkPSciVizContingencyStats::AssessData ( vtkTable *  observations,
vtkDataObject *  dataset,
The dataset parameter contains a shallow copy of input port 0 and should be modified to include the assessment.
Adding new arrays to point/cell/vertex/edge data should not pose a problem, but any alterations to the dataset itself will probably require that you create a deep copy before modification.
Parameters
observations- a table containing the field data of the dataset converted to a table
dataset- a shallow copy of the input dataset that should be altered to include an assessment of the output.
model- the statistical model with which to assess the observations.
