vtkSMSaveAnimationExtractsProxy Class Reference
generate extracts using animation scene More...
#include <vtkSMSaveAnimationExtractsProxy.h>
Inheritance diagram for vtkSMSaveAnimationExtractsProxy:
Collaboration diagram for vtkSMSaveAnimationExtractsProxy:
typedef vtkSMProxy Superclass
bool SaveExtracts ()
 Generates extracts. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMSaveAnimationExtractsProxy * New ()
static vtkSMSaveAnimationExtractsProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMSaveAnimationExtractsProxy ()
 ~vtkSMSaveAnimationExtractsProxy () override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMSaveAnimationExtractsProxy is used to generate extracts by using the animation scene to drive the pipeline updates. Essentially, this will play through the animation scene associated with the session for this proxy and for each frame in the animation, generate extracts based on the extract generators defined.
As with any other vtkSMProxy and subclass, one does not directly instantiate this class instead use vtkSMSessionProxyManager::NewProxy. One definition for this proxy is under proxy-group "misc" and proxy-name "SaveAnimationExtracts".
Definition at line 25 of file vtkSMSaveAnimationExtractsProxy.h.
Definition at line 29 of file vtkSMSaveAnimationExtractsProxy.h.
◆ vtkSMSaveAnimationExtractsProxy()
vtkSMSaveAnimationExtractsProxy::vtkSMSaveAnimationExtractsProxy ( )
◆ ~vtkSMSaveAnimationExtractsProxy()
vtkSMSaveAnimationExtractsProxy::~vtkSMSaveAnimationExtractsProxy ( )
static vtkSMSaveAnimationExtractsProxy* vtkSMSaveAnimationExtractsProxy::New ( )
virtual const char* vtkSMSaveAnimationExtractsProxy::GetClassName ( )
static int vtkSMSaveAnimationExtractsProxy::IsTypeOf ( const char *  type)
virtual int vtkSMSaveAnimationExtractsProxy::IsA ( const char *  type)
static vtkSMSaveAnimationExtractsProxy* vtkSMSaveAnimationExtractsProxy::SafeDownCast ( vtkObject *  o)
void vtkSMSaveAnimationExtractsProxy::PrintSelf ( ostream &  os,
◆ SaveExtracts()
bool vtkSMSaveAnimationExtractsProxy::SaveExtracts ( )
Generates extracts.
