vtkSMRegistrationNamesDomain Class Reference
domain to set default value for a property using proxy registration names More...
#include <vtkSMRegistrationNamesDomain.h>
Inheritance diagram for vtkSMRegistrationNamesDomain:
Collaboration diagram for vtkSMRegistrationNamesDomain:
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
int SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void Update (vtkSMProperty *requestingProperty)
 Update self based on the "unchecked" values of all required properties. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMRegistrationNamesDomain * New ()
static vtkSMRegistrationNamesDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMRegistrationNamesDomain ()
 ~vtkSMRegistrationNamesDomain () override
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void ChildSaveState (vtkPVXMLElement *domainElement)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMRegistrationNamesDomain can be used for string-vector property to initialize it with registration names for proxies in the required property named "Proxies".
For example
<SourceProxy name="GroupDataSets" ...>
<InputProperty clean_command="RemoveAllInputs"
command="AddInputConnection"
multiple_input="1"
name="Input">
</InputProperty>
<StringVectorProperty name="BlockNames"
command="SetInputName"
number_of_elements_per_command="1"
repeat_command="1"
use_index="1"
clean_command="ClearInputNames">
<Documentation>
Specify names to use for each input.
</Documentation>
<RegistrationNamesDomain name="names_list" registration_group="sources">
<RequiredProperties>
<Property name="Input" function="Proxies" />
</RequiredProperties>
</RegistrationNamesDomain>
</StringVectorProperty>
</SourceProxy>
Definition at line 48 of file vtkSMRegistrationNamesDomain.h.
Definition at line 52 of file vtkSMRegistrationNamesDomain.h.
◆ vtkSMRegistrationNamesDomain()
vtkSMRegistrationNamesDomain::vtkSMRegistrationNamesDomain ( )
◆ ~vtkSMRegistrationNamesDomain()
vtkSMRegistrationNamesDomain::~vtkSMRegistrationNamesDomain ( )
static vtkSMRegistrationNamesDomain* vtkSMRegistrationNamesDomain::New ( )
virtual const char* vtkSMRegistrationNamesDomain::GetClassName ( )
static int vtkSMRegistrationNamesDomain::IsTypeOf ( const char *  type)
virtual int vtkSMRegistrationNamesDomain::IsA ( const char *  type)
static vtkSMRegistrationNamesDomain* vtkSMRegistrationNamesDomain::SafeDownCast ( vtkObject *  o)
void vtkSMRegistrationNamesDomain::PrintSelf ( ostream &  os,
◆ SetDefaultValues()
int vtkSMRegistrationNamesDomain::SetDefaultValues ( vtkSMProperty *  ,
override
◆ ReadXMLAttributes()
int vtkSMRegistrationNamesDomain::ReadXMLAttributes ( vtkSMProperty *  prop,
vtkPVXMLElement *  elem
overrideprotectedvirtual
