vtkSMProxyGroupDomain Class Reference
union of proxy groups More...
#include <vtkSMProxyGroupDomain.h>
Inheritance diagram for vtkSMProxyGroupDomain:
Collaboration diagram for vtkSMProxyGroupDomain:
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
void AddGroup (const char *group)
 Add a group to the domain. More...
int IsInDomain (vtkSMProperty *property) override
 Returns true if the value of the property is in the domain. More...
int IsInDomain (vtkSMProxy *proxy)
 Returns true if the proxy is in the domain. More...
unsigned int GetNumberOfGroups ()
 Returns the number of groups. More...
const char * GetGroup (unsigned int idx)
 Returns group with give id. More...
unsigned int GetNumberOfProxies ()
 Returns the total number of proxies in the domain. More...
vtkSMProxy * GetProxy (const char *name)
 Given a name, returns a proxy. More...
const char * GetProxyName (unsigned int idx)
 Returns the name (in the group) of a proxy. More...
vtkSMProxy * GetProxy (unsigned int idx)
 Given an index, returns a proxy. More...
const char * GetProxyName (vtkSMProxy *proxy)
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void Update (vtkSMProperty *requestingProperty)
 Update self based on the "unchecked" values of all required properties. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMProxyGroupDomain * New ()
static vtkSMProxyGroupDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMProxyGroupDomain ()
 ~vtkSMProxyGroupDomain () override
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void ChildSaveState (vtkPVXMLElement *domainElement)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkSMProxyGroupDomainInternals * PGInternals
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
The proxy group domain consists of all proxies in a list of groups. This domain is commonly used together with vtkSMProxyproperty Valid XML elements are:
* * <Group name=""> where name is the groupname used by the proxy
* manager to refer to a group of proxies.
// .SECTION See Also vtkSMDomain vtkSMProxyproperty
Definition at line 28 of file vtkSMProxyGroupDomain.h.
Definition at line 32 of file vtkSMProxyGroupDomain.h.
◆ vtkSMProxyGroupDomain()
vtkSMProxyGroupDomain::vtkSMProxyGroupDomain ( )
◆ ~vtkSMProxyGroupDomain()
vtkSMProxyGroupDomain::~vtkSMProxyGroupDomain ( )
static vtkSMProxyGroupDomain* vtkSMProxyGroupDomain::New ( )
virtual const char* vtkSMProxyGroupDomain::GetClassName ( )
static int vtkSMProxyGroupDomain::IsTypeOf ( const char *  type)
virtual int vtkSMProxyGroupDomain::IsA ( const char *  type)
static vtkSMProxyGroupDomain* vtkSMProxyGroupDomain::SafeDownCast ( vtkObject *  o)
void vtkSMProxyGroupDomain::PrintSelf ( ostream &  os,
◆ AddGroup()
void vtkSMProxyGroupDomain::AddGroup ( const char *  group)
The domain is the union of all groups.
◆ IsInDomain() [1/2]
int vtkSMProxyGroupDomain::IsInDomain ( vtkSMProperty *  property)
override
The property has to be a vtkSMProxyproperty or a sub-class. All proxies pointed by the property have to be in the domain.
◆ IsInDomain() [2/2]
int vtkSMProxyGroupDomain::IsInDomain ( vtkSMProxy *  proxy)
◆ GetNumberOfGroups()
unsigned int vtkSMProxyGroupDomain::GetNumberOfGroups ( )
◆ GetGroup()
const char* vtkSMProxyGroupDomain::GetGroup ( unsigned int  idx)
Does not perform bounds check.
◆ GetNumberOfProxies()
unsigned int vtkSMProxyGroupDomain::GetNumberOfProxies ( )
◆ GetProxy() [1/2]
vtkSMProxy* vtkSMProxyGroupDomain::GetProxy ( const char *  name)
◆ GetProxyName() [1/2]
const char* vtkSMProxyGroupDomain::GetProxyName ( unsigned int  idx)
◆ GetProxy() [2/2]
vtkSMProxy* vtkSMProxyGroupDomain::GetProxy ( unsigned int  idx)
◆ GetProxyName() [2/2]
const char* vtkSMProxyGroupDomain::GetProxyName ( vtkSMProxy *  proxy)
◆ ReadXMLAttributes()
int vtkSMProxyGroupDomain::ReadXMLAttributes ( vtkSMProperty *  prop,
vtkPVXMLElement *  element
overrideprotectedvirtual
◆ PGInternals
vtkSMProxyGroupDomainInternals* vtkSMProxyGroupDomain::PGInternals
Definition at line 98 of file vtkSMProxyGroupDomain.h.
