vtkSMLoadStateOptionsProxy Class Reference
proxy for state loading options More...
#include <vtkSMLoadStateOptionsProxy.h>
Inheritance diagram for vtkSMLoadStateOptionsProxy:
Collaboration diagram for vtkSMLoadStateOptionsProxy:
enum  { USE_FILES_FROM_STATE = 0, USE_DATA_DIRECTORY = 1, CHOOSE_FILES_EXPLICITLY = 2 }
typedef vtkSMProxy Superclass
virtual bool PrepareToLoad (const char *statefilename, vtkTypeUInt32 location=0x10)
 Set the state file to load. More...
virtual bool HasDataFiles ()
 Check if state file has any data files. More...
virtual bool Load ()
 Do the state loading using the values for properties on this proxy to configure the state loading i.e. More...
vtkSMProperty * FindProperty (const char *name, int id, const char *pname)
 Helper for Python API. More...
vtkSMProperty * FindLegacyProperty (const char *sanitizedName)
 Helper for Python API to return a property using its named used in old traces (pre 5.9) More...
bool IsPropertyModified (int id, const char *pname)
 Returns true if the property has been modified. More...
std::string GetReaderName (int id) const
 Helper for Python trace generating code to get an name for a proxy given its id. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMLoadStateOptionsProxy * New ()
static vtkSMLoadStateOptionsProxy * SafeDownCast (vtkObject *o)
static bool PNGHasStateFile (const char *statefilename, std::string &contents, vtkTypeUInt32 location=0x10)
 Check if a PNG has a paraview state embedded in it. More...
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMLoadStateOptionsProxy ()
 ~vtkSMLoadStateOptionsProxy () override
bool LocateFilesInDirectory (std::vector< std::string > &filepaths, int path, bool clearFilenameIfNotFound)
 Locates the files in the user specified directory and updates the paths in the state file XML. More...
virtual void SetStateFileName (const char *)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
char * StateFileName
int DataFileOptions
 The three options for how to specify the data file locations. More...
int PathMatchingThreshold
 When the number of parent directories for a file series reaches this number assume it will match for the rest of the file series. More...
bool OnlyUseFilesInDataDirectory
 When this is set to true, USE_DATA_DIRECTORY mode will fail when a file is not in the data directory rather than defaulting back to the absolute path in the state file. More...
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMLoadStateOptionsProxy is the proxy used to setup options when loading a state file. These including choosing how to handle data files referenced in the state. This proxy supports multiple ways to let the user update the files being loaded in the state file.
To use this, create the ("options", "LoadStateOptions") proxy using the session's proxy manager and call PrepareToLoad with the state file to load. This will parse the state file and setup internal data structures. At this point, you can call HasDataFiles method to determine if the state file has any data files. This can be used to determine if the application should prompt the user with options, for example. One can change options using properties on the options proxy itself. Following PrepareToLoad, the proxy will present additional properties that allows the user to pick filenames for readers in the state file. Call Load to load the state file.
This proxy is not intended for reuse. Simply create a new one for each state to load.
Definition at line 36 of file vtkSMLoadStateOptionsProxy.h.
Definition at line 40 of file vtkSMLoadStateOptionsProxy.h.
◆ anonymous enum
anonymous enum
Enumerator
USE_DATA_DIRECTORY
Definition at line 70 of file vtkSMLoadStateOptionsProxy.h.
◆ vtkSMLoadStateOptionsProxy()
vtkSMLoadStateOptionsProxy::vtkSMLoadStateOptionsProxy ( )
◆ ~vtkSMLoadStateOptionsProxy()
vtkSMLoadStateOptionsProxy::~vtkSMLoadStateOptionsProxy ( )
static vtkSMLoadStateOptionsProxy* vtkSMLoadStateOptionsProxy::New ( )
virtual const char* vtkSMLoadStateOptionsProxy::GetClassName ( )
static int vtkSMLoadStateOptionsProxy::IsTypeOf ( const char *  type)
virtual int vtkSMLoadStateOptionsProxy::IsA ( const char *  type)
static vtkSMLoadStateOptionsProxy* vtkSMLoadStateOptionsProxy::SafeDownCast ( vtkObject *  o)
void vtkSMLoadStateOptionsProxy::PrintSelf ( ostream &  os,
◆ PNGHasStateFile()
static bool vtkSMLoadStateOptionsProxy::PNGHasStateFile ( const char *  statefilename,
std::string &  contents,
vtkTypeUInt32  location = 0x10
Contents will include the state if present.
◆ PrepareToLoad()
virtual bool vtkSMLoadStateOptionsProxy::PrepareToLoad ( const char *  statefilename,
This may read the file and collect information about the file. Returns false if the filename is invalid or cannot be read.
◆ HasDataFiles()
virtual bool vtkSMLoadStateOptionsProxy::HasDataFiles ( )
Returns
whether the state file refers to any data files to be loaded.
◆ Load()
virtual bool vtkSMLoadStateOptionsProxy::Load ( )
update data files, etc.
◆ FindProperty()
vtkSMProperty* vtkSMLoadStateOptionsProxy::FindProperty ( const char *  name,
int  id,
const char *  pname
Returns vtkSMProperty for the chosen name/id.
◆ FindLegacyProperty()
vtkSMProperty* vtkSMLoadStateOptionsProxy::FindLegacyProperty ( const char *  sanitizedName)
◆ IsPropertyModified()
bool vtkSMLoadStateOptionsProxy::IsPropertyModified ( int  id,
const char *  pname
◆ GetReaderName()
std::string vtkSMLoadStateOptionsProxy::GetReaderName ( int  id) const
◆ LocateFilesInDirectory()
bool vtkSMLoadStateOptionsProxy::LocateFilesInDirectory ( std::vector< std::string > &  filepaths,
int  path,
Set the isPath parameter to 1 for file paths that are prefixes, 0 otherwise. If the clearFilenameIfNotFound option is set to true it will set the filenames that are not in the directory to empty string rather than leave them as the filenames from the state file XML.
Returns
false if any of the files were not found
◆ SetStateFileName()
virtual void vtkSMLoadStateOptionsProxy::SetStateFileName ( const char *  )
protectedvirtual
◆ StateFileName
char* vtkSMLoadStateOptionsProxy::StateFileName
Definition at line 116 of file vtkSMLoadStateOptionsProxy.h.
◆ DataFileOptions
int vtkSMLoadStateOptionsProxy::DataFileOptions
Definition at line 122 of file vtkSMLoadStateOptionsProxy.h.
◆ PathMatchingThreshold
int vtkSMLoadStateOptionsProxy::PathMatchingThreshold
Definition at line 128 of file vtkSMLoadStateOptionsProxy.h.
◆ OnlyUseFilesInDataDirectory
bool vtkSMLoadStateOptionsProxy::OnlyUseFilesInDataDirectory
Definition at line 134 of file vtkSMLoadStateOptionsProxy.h.
