vtkSMDirectoryProxy Class Reference
#include <vtkSMDirectoryProxy.h>
Inheritance diagram for vtkSMDirectoryProxy:
Collaboration diagram for vtkSMDirectoryProxy:
typedef vtkSMProxy Superclass
bool MakeDirectory (const char *dir)
 Create directory. More...
bool DeleteDirectory (const char *dir)
 Remove a directory. More...
bool Rename (const char *oldname, const char *newname)
 Rename a file or directory. More...
bool List (const char *dir)
 List server side directory NEVER USED IN PARAVIEW, TODO ? More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMDirectoryProxy * New ()
static vtkSMDirectoryProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMDirectoryProxy ()
 ~vtkSMDirectoryProxy () override
bool CallDirectoryMethod (const char *method, const char *path, const char *secondaryPath=nullptr)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Is a utility proxy to create/delete/rename directories.
See also
vtkSMFileUtilities. Using vtkSMFileUtilities is recommended over directly using this class since vtkSMFileUtilities handles MPI and parallel file systems better.
Definition at line 19 of file vtkSMDirectoryProxy.h.
Definition at line 23 of file vtkSMDirectoryProxy.h.
◆ vtkSMDirectoryProxy()
vtkSMDirectoryProxy::vtkSMDirectoryProxy ( )
◆ ~vtkSMDirectoryProxy()
vtkSMDirectoryProxy::~vtkSMDirectoryProxy ( )
static vtkSMDirectoryProxy* vtkSMDirectoryProxy::New ( )
virtual const char* vtkSMDirectoryProxy::GetClassName ( )
static int vtkSMDirectoryProxy::IsTypeOf ( const char *  type)
virtual int vtkSMDirectoryProxy::IsA ( const char *  type)
static vtkSMDirectoryProxy* vtkSMDirectoryProxy::SafeDownCast ( vtkObject *  o)
void vtkSMDirectoryProxy::PrintSelf ( ostream &  os,
◆ MakeDirectory()
bool vtkSMDirectoryProxy::MakeDirectory ( const char *  dir)
Create directory.
◆ DeleteDirectory()
bool vtkSMDirectoryProxy::DeleteDirectory ( const char *  dir)
Remove a directory.
◆ Rename()
bool vtkSMDirectoryProxy::Rename ( const char *  oldname,
const char *  newname
◆ List()
bool vtkSMDirectoryProxy::List ( const char *  dir)
◆ CallDirectoryMethod()
bool vtkSMDirectoryProxy::CallDirectoryMethod ( const char *  method,
const char *  path,
const char *  secondaryPath = nullptr
