vtkSMContextItemWidgetProxy Class Reference
proxy for a widget representation More...
#include <vtkSMContextItemWidgetProxy.h>
Inheritance diagram for vtkSMContextItemWidgetProxy:
Collaboration diagram for vtkSMContextItemWidgetProxy:
typedef vtkSMProxy Superclass
- Public Types inherited from vtkSMWidgetRepresentationProxy
void OnStartInteraction () override
 These method forward the representation state of the client side widget representation to the server. More...
- Public Member Functions inherited from vtkSMWidgetRepresentationProxy
virtual void OnEndInteraction ()
virtual void OnInteraction ()
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMContextItemWidgetProxy * New ()
static vtkSMContextItemWidgetProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMWidgetRepresentationProxy
static vtkSMWidgetRepresentationProxy * New ()
static vtkSMWidgetRepresentationProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMContextItemWidgetProxy ()=default
 ~vtkSMContextItemWidgetProxy () override=default
void SendRepresentation () override
 Overriden so it can call modified on the server-side widget on each interaction. More...
- Protected Member Functions inherited from vtkSMWidgetRepresentationProxy
 vtkSMWidgetRepresentationProxy ()
 ~vtkSMWidgetRepresentationProxy () override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMWidgetRepresentationProxy
int RepresentationState
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMContextItemWidgetProxy is a specialized proxy that represents VTK 2D widget representation. It adds the capability of syncing the appearance of server-side representation to the client-side context item widget.
Definition at line 19 of file vtkSMContextItemWidgetProxy.h.
Definition at line 23 of file vtkSMContextItemWidgetProxy.h.
◆ vtkSMContextItemWidgetProxy()
vtkSMContextItemWidgetProxy::vtkSMContextItemWidgetProxy ( )
protecteddefault
◆ ~vtkSMContextItemWidgetProxy()
vtkSMContextItemWidgetProxy::~vtkSMContextItemWidgetProxy ( )
overrideprotecteddefault
static vtkSMContextItemWidgetProxy* vtkSMContextItemWidgetProxy::New ( )
virtual const char* vtkSMContextItemWidgetProxy::GetClassName ( )
Reimplemented from vtkSMWidgetRepresentationProxy.
static int vtkSMContextItemWidgetProxy::IsTypeOf ( const char *  type)
virtual int vtkSMContextItemWidgetProxy::IsA ( const char *  type)
static vtkSMContextItemWidgetProxy* vtkSMContextItemWidgetProxy::SafeDownCast ( vtkObject *  o)
void vtkSMContextItemWidgetProxy::PrintSelf ( ostream &  os,
◆ OnStartInteraction()
void vtkSMContextItemWidgetProxy::OnStartInteraction ( )
inlineoverridevirtual
Definition at line 26 of file vtkSMContextItemWidgetProxy.h.
◆ SendRepresentation()
void vtkSMContextItemWidgetProxy::SendRepresentation ( )
overrideprotectedvirtual
This is necessary so both views (server side and client side) are being updated at the same time. Not doing that would result in a softlock because client view would wait infinitely for server side view.
