vtkSMAnimationSceneProxy Class Reference
#include <vtkSMAnimationSceneProxy.h>
Inheritance diagram for vtkSMAnimationSceneProxy:
Collaboration diagram for vtkSMAnimationSceneProxy:
typedef vtkSMProxy Superclass
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMAnimationSceneProxy * New ()
static vtkSMAnimationSceneProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMAnimationSceneProxy ()
 ~vtkSMAnimationSceneProxy () override
int LoadXMLState (vtkPVXMLElement *element, vtkSMProxyLocator *locator) override
 Overridden to prune start/end time properties if not applicable to the state being loaded. More...
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
static bool UpdateAnimationUsingDataTimeSteps (vtkSMProxy *scene)
 Setups the animation scene's playback mode and time-ranges based on the timesteps available on the time-keeper proxy set on the animation scene. More...
virtual bool UpdateAnimationUsingDataTimeSteps ()
static vtkSMProxy * FindAnimationCue (vtkSMProxy *scene, vtkSMProxy *animatedProxy, const char *animatedPropertyName)
 Returns the first animation cue (enabled or otherwise) that animates the given property on the proxy. More...
virtual vtkSMProxy * FindAnimationCue (vtkSMProxy *animatedProxy, const char *animatedPropertyName)
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMAnimationSceneProxy observe vtkCommand::ModifiedEvent on the client-side VTK-object to call UpdatePropertyInformation() every time that happens.
Definition at line 17 of file vtkSMAnimationSceneProxy.h.
Definition at line 21 of file vtkSMAnimationSceneProxy.h.
◆ vtkSMAnimationSceneProxy()
vtkSMAnimationSceneProxy::vtkSMAnimationSceneProxy ( )
◆ ~vtkSMAnimationSceneProxy()
vtkSMAnimationSceneProxy::~vtkSMAnimationSceneProxy ( )
static vtkSMAnimationSceneProxy* vtkSMAnimationSceneProxy::New ( )
virtual const char* vtkSMAnimationSceneProxy::GetClassName ( )
static int vtkSMAnimationSceneProxy::IsTypeOf ( const char *  type)
virtual int vtkSMAnimationSceneProxy::IsA ( const char *  type)
static vtkSMAnimationSceneProxy* vtkSMAnimationSceneProxy::SafeDownCast ( vtkObject *  o)
void vtkSMAnimationSceneProxy::PrintSelf ( ostream &  os,
◆ UpdateAnimationUsingDataTimeSteps() [1/2]
virtual bool vtkSMAnimationSceneProxy::UpdateAnimationUsingDataTimeSteps ( )
◆ UpdateAnimationUsingDataTimeSteps() [2/2]
static bool vtkSMAnimationSceneProxy::UpdateAnimationUsingDataTimeSteps ( vtkSMProxy *  scene)
inlinestatic
Definition at line 30 of file vtkSMAnimationSceneProxy.h.
◆ FindAnimationCue() [1/2]
virtual vtkSMProxy* vtkSMAnimationSceneProxy::FindAnimationCue ( vtkSMProxy *  animatedProxy,
const char *  animatedPropertyName
This will return nullptr if none such cue exists.
◆ FindAnimationCue() [2/2]
static vtkSMProxy* vtkSMAnimationSceneProxy::FindAnimationCue ( vtkSMProxy *  scene,
inlinestatic
Definition at line 43 of file vtkSMAnimationSceneProxy.h.
◆ LoadXMLState()
int vtkSMAnimationSceneProxy::LoadXMLState ( vtkPVXMLElement *  element,
vtkSMProxyLocator *  locator
overrideprotectedvirtual
◆ CreateVTKObjects()
void vtkSMAnimationSceneProxy::CreateVTKObjects ( )
Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s)
