vtkPVCompositeOrthographicSliceRepresentation Class Reference
#include <vtkPVCompositeOrthographicSliceRepresentation.h>
Inheritance diagram for vtkPVCompositeOrthographicSliceRepresentation:
Collaboration diagram for vtkPVCompositeOrthographicSliceRepresentation:
typedef vtkPVCompositeRepresentation Superclass
- Public Types inherited from vtkPVCompositeRepresentation
typedef vtkCompositeRepresentation Superclass
- Public Types inherited from vtkCompositeRepresentation
enum  DesiredOutputPrecision
void SetSliceRepresentation (int index, vtkGeometrySliceRepresentation *)
void SetSliceRepresentation0 (vtkGeometrySliceRepresentation *repr)
void SetSliceRepresentation1 (vtkGeometrySliceRepresentation *repr)
void SetSliceRepresentation2 (vtkGeometrySliceRepresentation *repr)
void SetVisibility (bool visible) override
 Set visibility of the representation. More...
void MarkModified () override
 Propagate the modification to all internal representations. More...
unsigned int Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) override
 Override because of internal composite representations that need to be initialized as well. More...
 Overridden to simply pass the input to the internal representations. More...
void SetInputConnection (vtkAlgorithmOutput *input) override
void AddInputConnection (vtkAlgorithmOutput *input) override
void RemoveInputConnection (int port, vtkAlgorithmOutput *input) override
void RemoveInputConnection (int port, int index) override
- Public Member Functions inherited from vtkPVCompositeRepresentation
void SetSelectionRepresentation (vtkSelectionRepresentation *)
 These must only be set during initialization before adding the representation to any views or calling Update(). More...
void SetGridAxesRepresentation (vtkPVGridAxes3DRepresentation *)
void SetPolarAxesRepresentation (vtkPolarAxesRepresentation *)
 This must only be set during initialization before adding the representation to any views or calling Update(). More...
virtual void SetSelectionVisibility (bool visible)
 Set the selection visibility. More...
virtual void SetPolarAxesVisibility (bool visible)
 Set the polar axes visibility. More...
void SetUpdateTime (double time) override
 Passed on to internal representations as well. More...
void SetForceUseCache (bool val) override
void SetForcedCacheKey (double val) override
void RemoveInputConnection (int port, int idx) override
virtual void SetPointFieldDataArrayName (const char *)
 Forwarded to vtkSelectionRepresentation. More...
virtual void SetCellFieldDataArrayName (const char *)
- Public Member Functions inherited from vtkCompositeRepresentation
vtkPVDataRepresentation * GetActiveRepresentation ()
 Returns the active representation if valid. More...
void SetSelectionConnection (vtkAlgorithmOutput *input)
 Set the selection connection. More...
vtkDataObject * GetRenderedDataObject (int port) override
vtkStringArray * GetRepresentationTypes ()
 Returns the list of available representation types as a string array. More...
virtual void AddRepresentation (const char *key, vtkPVDataRepresentation *repr)
 Add/Remove representations. More...
virtual void RemoveRepresentation (vtkPVDataRepresentation *repr)
virtual void RemoveRepresentation (const char *key)
void SetActiveRepresentation (const char *key)
 Set the active key. More...
const char * GetActiveRepresentationKey ()
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVCompositeOrthographicSliceRepresentation * New ()
static vtkPVCompositeOrthographicSliceRepresentation * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVCompositeRepresentation
static vtkPVCompositeRepresentation * New ()
static vtkPVCompositeRepresentation * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkCompositeRepresentation
static vtkCompositeRepresentation * New ()
static vtkCompositeRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkPVCompositeOrthographicSliceRepresentation ()
 ~vtkPVCompositeOrthographicSliceRepresentation () override
- Protected Member Functions inherited from vtkPVCompositeRepresentation
 vtkPVCompositeRepresentation ()
 ~vtkPVCompositeRepresentation () override
- Protected Member Functions inherited from vtkCompositeRepresentation
 vtkCompositeRepresentation ()
 ~vtkCompositeRepresentation () override
int FillInputPortInformation (int, vtkInformation *info) override
void TriggerUpdateDataEvent ()
 Fires UpdateDataEvent. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkSmartPointer< vtkGeometrySliceRepresentation > SliceRepresentations [3]
- Protected Attributes inherited from vtkPVCompositeRepresentation
vtkSelectionRepresentation * SelectionRepresentation
vtkPVGridAxes3DRepresentation * GridAxesRepresentation
vtkPolarAxesRepresentation * PolarAxesRepresentation
bool SelectionVisibility
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkPVCompositeOrthographicSliceRepresentation is designed for use with vtkPVOrthographicSliceView. We add 3 vtkGeometrySliceRepresentation instances to render the 3 slices in vtkPVOrthographicSliceView's orthographic views.
Definition at line 20 of file vtkPVCompositeOrthographicSliceRepresentation.h.
◆ vtkPVCompositeOrthographicSliceRepresentation()
vtkPVCompositeOrthographicSliceRepresentation::vtkPVCompositeOrthographicSliceRepresentation ( )
◆ ~vtkPVCompositeOrthographicSliceRepresentation()
vtkPVCompositeOrthographicSliceRepresentation::~vtkPVCompositeOrthographicSliceRepresentation ( )
static vtkPVCompositeOrthographicSliceRepresentation* vtkPVCompositeOrthographicSliceRepresentation::New ( )
virtual const char* vtkPVCompositeOrthographicSliceRepresentation::GetClassName ( )
Reimplemented from vtkPVCompositeRepresentation.
static int vtkPVCompositeOrthographicSliceRepresentation::IsTypeOf ( const char *  type)
virtual int vtkPVCompositeOrthographicSliceRepresentation::IsA ( const char *  type)
static vtkPVCompositeOrthographicSliceRepresentation* vtkPVCompositeOrthographicSliceRepresentation::SafeDownCast ( vtkObject *  o)
void vtkPVCompositeOrthographicSliceRepresentation::PrintSelf ( ostream &  os,
Reimplemented from vtkCompositeRepresentation.
◆ SetSliceRepresentation()
void vtkPVCompositeOrthographicSliceRepresentation::SetSliceRepresentation ( int  index,
◆ SetSliceRepresentation0()
void vtkPVCompositeOrthographicSliceRepresentation::SetSliceRepresentation0 ( vtkGeometrySliceRepresentation *  repr)
inline
◆ SetSliceRepresentation1()
void vtkPVCompositeOrthographicSliceRepresentation::SetSliceRepresentation1 ( vtkGeometrySliceRepresentation *  repr)
inline
◆ SetSliceRepresentation2()
void vtkPVCompositeOrthographicSliceRepresentation::SetSliceRepresentation2 ( vtkGeometrySliceRepresentation *  repr)
inline
◆ SetVisibility()
void vtkPVCompositeOrthographicSliceRepresentation::SetVisibility ( bool  visible)
Overridden to update the cube-axes and selection visibilities.
◆ SetInputConnection() [1/2]
void vtkPVCompositeOrthographicSliceRepresentation::SetInputConnection ( int  port,
vtkAlgorithmOutput *  input
We won't need this if vtkDataRepresentation correctly respected in the arguments passed to it during ProcessRequest() etc.
◆ SetInputConnection() [2/2]
void vtkPVCompositeOrthographicSliceRepresentation::SetInputConnection ( vtkAlgorithmOutput *  input)
◆ AddInputConnection() [1/2]
void vtkPVCompositeOrthographicSliceRepresentation::AddInputConnection ( int  port,
◆ AddInputConnection() [2/2]
void vtkPVCompositeOrthographicSliceRepresentation::AddInputConnection ( vtkAlgorithmOutput *  input)
◆ RemoveInputConnection() [1/2]
void vtkPVCompositeOrthographicSliceRepresentation::RemoveInputConnection ( int  port,
◆ RemoveInputConnection() [2/2]
int  index
◆ MarkModified()
void vtkPVCompositeOrthographicSliceRepresentation::MarkModified ( )
◆ Initialize()
unsigned int vtkPVCompositeOrthographicSliceRepresentation::Initialize ( unsigned int  minIdAvailable,
◆ AddToView()
bool vtkPVCompositeOrthographicSliceRepresentation::AddToView ( vtkView *  view)
◆ RemoveFromView()
bool vtkPVCompositeOrthographicSliceRepresentation::RemoveFromView ( vtkView *  view)
◆ SliceRepresentations
vtkSmartPointer<vtkGeometrySliceRepresentation> vtkPVCompositeOrthographicSliceRepresentation::SliceRepresentations[3]
