vtkSelectionRepresentation Class Reference
#include <vtkSelectionRepresentation.h>
Inheritance diagram for vtkSelectionRepresentation:
Collaboration diagram for vtkSelectionRepresentation:
enum  DesiredOutputPrecision
void SetLabelRepresentation (vtkDataLabelRepresentation *)
 One must change the internal representations only before the representation is added to a view, after that it should not be touched. More...
void MarkModified () override
 This needs to be called on all instances of vtkSelectionRepresentation when the input is modified. More...
void SetVisibility (bool val) override
unsigned int Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) override
 Override because of internal composite representations that need to be initialized as well. More...
void SetLogName (const std::string &) override
 Overridden to pass logname to internal GeometryRepresentation. More...
 Overridden to simply pass the input to the internal representations. More...
void SetInputConnection (vtkAlgorithmOutput *input) override
void AddInputConnection (vtkAlgorithmOutput *input) override
void RemoveInputConnection (int port, vtkAlgorithmOutput *input) override
void RemoveInputConnection (int port, int idx) override
void SetUpdateTime (double time) override
 Passed on to internal representations as well. More...
void SetForceUseCache (bool val) override
void SetForcedCacheKey (double val) override
void SetColor (double r, double g, double b)
 Forwarded to GeometryRepresentation. More...
void SetLineWidth (double val)
void SetOpacity (double val)
void SetPointSize (double val)
void SetRepresentation (int val)
void SetUseOutline (int)
void SetRenderPointsAsSpheres (bool)
void SetRenderLinesAsTubes (bool)
void SetOrientation (double, double, double)
 Forwarded to GeometryRepresentation and LabelRepresentation. More...
void SetOrigin (double, double, double)
void SetPosition (double, double, double)
void SetScale (double, double, double)
void SetUserTransform (const double[16])
virtual void SetPointFieldDataArrayName (const char *val)
 Forwarded to vtkDataLabelRepresentation. More...
virtual void SetCellFieldDataArrayName (const char *val)
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkSelectionRepresentation * New ()
static vtkSelectionRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkSelectionRepresentation ()
 ~vtkSelectionRepresentation () override
virtual void TriggerUpdateDataEvent ()
 Fires UpdateDataEvent. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkGeometryRepresentation * GeometryRepresentation
vtkDataLabelRepresentation * LabelRepresentation
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkSelectionRepresentation is a representation to show the extracted cells. It uses vtkGeometryRepresentation and vtkPVDataRepresentation internally.
The addition of a transformation matrix was supported by CEA/DIF Commissariat a l'Energie Atomique, Centre DAM Ile-De-France, Arpajon, France.
Definition at line 23 of file vtkSelectionRepresentation.h.
Definition at line 27 of file vtkSelectionRepresentation.h.
◆ vtkSelectionRepresentation()
vtkSelectionRepresentation::vtkSelectionRepresentation ( )
◆ ~vtkSelectionRepresentation()
vtkSelectionRepresentation::~vtkSelectionRepresentation ( )
static vtkSelectionRepresentation* vtkSelectionRepresentation::New ( )
virtual const char* vtkSelectionRepresentation::GetClassName ( )
static int vtkSelectionRepresentation::IsTypeOf ( const char *  type)
virtual int vtkSelectionRepresentation::IsA ( const char *  type)
static vtkSelectionRepresentation* vtkSelectionRepresentation::SafeDownCast ( vtkObject *  o)
void vtkSelectionRepresentation::PrintSelf ( ostream &  os,
◆ ProcessViewRequest()
int vtkSelectionRepresentation::ProcessViewRequest ( vtkInformationRequestKey *  request_type,
vtkInformation *  inInfo,
vtkInformation *  outInfo
Note
Starting with ParaView 5.8, this method is no longer called for hidden representation i.e. representations for which vtkDataRepresentation::GetVisibility() returns false.
◆ SetLabelRepresentation()
void vtkSelectionRepresentation::SetLabelRepresentation ( vtkDataLabelRepresentation *  )
◆ SetInputConnection() [1/2]
void vtkSelectionRepresentation::SetInputConnection ( int  port,
vtkAlgorithmOutput *  input
We won't need this if vtkPVDataRepresentation correctly respected in the arguments passed to it during ProcessRequest() etc.
◆ SetInputConnection() [2/2]
void vtkSelectionRepresentation::SetInputConnection ( vtkAlgorithmOutput *  input)
◆ AddInputConnection() [1/2]
void vtkSelectionRepresentation::AddInputConnection ( int  port,
◆ AddInputConnection() [2/2]
void vtkSelectionRepresentation::AddInputConnection ( vtkAlgorithmOutput *  input)
◆ RemoveInputConnection() [1/2]
void vtkSelectionRepresentation::RemoveInputConnection ( int  port,
◆ RemoveInputConnection() [2/2]
int  idx
◆ MarkModified()
void vtkSelectionRepresentation::MarkModified ( )
This is essential since the geometry filter does not have any real-input on the client side which messes with the Update requests.
◆ SetUpdateTime()
void vtkSelectionRepresentation::SetUpdateTime ( double  time)
◆ SetForceUseCache()
void vtkSelectionRepresentation::SetForceUseCache ( bool  val)
◆ SetForcedCacheKey()
void vtkSelectionRepresentation::SetForcedCacheKey ( double  val)
◆ SetVisibility()
void vtkSelectionRepresentation::SetVisibility ( bool  val)
When the visibility of representation of false, all view passes are ignored. Overridden to propagate to the active representation.
◆ SetColor()
void vtkSelectionRepresentation::SetColor ( double  r,
double  g,
double  b
◆ SetLineWidth()
void vtkSelectionRepresentation::SetLineWidth ( double  val)
◆ SetOpacity()
void vtkSelectionRepresentation::SetOpacity ( double  val)
◆ SetPointSize()
void vtkSelectionRepresentation::SetPointSize ( double  val)
◆ SetRepresentation()
void vtkSelectionRepresentation::SetRepresentation ( int  val)
◆ SetUseOutline()
void vtkSelectionRepresentation::SetUseOutline ( int  )
◆ SetRenderPointsAsSpheres()
void vtkSelectionRepresentation::SetRenderPointsAsSpheres ( bool  )
◆ SetRenderLinesAsTubes()
void vtkSelectionRepresentation::SetRenderLinesAsTubes ( bool  )
◆ SetOrientation()
void vtkSelectionRepresentation::SetOrientation ( double  ,
double  ,
double
◆ SetOrigin()
void vtkSelectionRepresentation::SetOrigin ( double  ,
double  ,
double
◆ SetPosition()
void vtkSelectionRepresentation::SetPosition ( double  ,
double  ,
double
◆ SetScale()
void vtkSelectionRepresentation::SetScale ( double  ,
double  ,
double
◆ SetUserTransform()
void vtkSelectionRepresentation::SetUserTransform ( const double  [16])
◆ SetPointFieldDataArrayName()
virtual void vtkSelectionRepresentation::SetPointFieldDataArrayName ( const char *  val)
◆ SetCellFieldDataArrayName()
virtual void vtkSelectionRepresentation::SetCellFieldDataArrayName ( const char *  val)
◆ Initialize()
unsigned int vtkSelectionRepresentation::Initialize ( unsigned int  minIdAvailable,
◆ SetLogName()
void vtkSelectionRepresentation::SetLogName ( const std::string &  )
◆ FillInputPortInformation()
int vtkSelectionRepresentation::FillInputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
◆ AddToView()
bool vtkSelectionRepresentation::AddToView ( vtkView *  view)
◆ RemoveFromView()
bool vtkSelectionRepresentation::RemoveFromView ( vtkView *  view)
◆ TriggerUpdateDataEvent()
virtual void vtkSelectionRepresentation::TriggerUpdateDataEvent ( )
protectedvirtual
◆ GeometryRepresentation
vtkGeometryRepresentation* vtkSelectionRepresentation::GeometryRepresentation
Definition at line 146 of file vtkSelectionRepresentation.h.
◆ LabelRepresentation
vtkDataLabelRepresentation* vtkSelectionRepresentation::LabelRepresentation
Definition at line 147 of file vtkSelectionRepresentation.h.
