vtkGeometrySliceRepresentation Class Reference
extends vtkGeometryRepresentation to add support for showing just specific slices from the dataset. More...
#include <vtkGeometrySliceRepresentation.h>
Inheritance diagram for vtkGeometrySliceRepresentation:
Collaboration diagram for vtkGeometrySliceRepresentation:
enum  { X_SLICE_ONLY, Y_SLICE_ONLY, Z_SLICE_ONLY, ALL_SLICES }
typedef vtkGeometryRepresentation Superclass
- Public Types inherited from vtkGeometryRepresentation
enum  RepresentationTypes { POINTS = VTK_POINTS, WIREFRAME = VTK_WIREFRAME, SURFACE = VTK_SURFACE, SURFACE_WITH_EDGES = 3 }
enum  DesiredOutputPrecision
virtual void SetMode (int)
virtual int GetMode ()
virtual void SetShowOutline (bool)
 Get/Set whether original data outline should be shown in the view. More...
virtual bool GetShowOutline ()
- Public Member Functions inherited from vtkGeometryRepresentation
void SetVisibility (bool val) override
virtual void SetSuppressLOD (bool suppress)
 Enable/Disable LOD;. More...
virtual void SetRepresentation (const char *)
 Overload to set representation type using string. More...
vtkDataObject * GetRenderedDataObject (int port) override
virtual void SetNormalArray (const char *val)
 Set the normal array used for smooth shading. More...
virtual void SetTCoordArray (const char *val)
 Set the texture coordinates array used for texture mapping. More...
virtual void SetTangentArray (const char *val)
 Set the tangent coordinates array used for normal mapping. More...
virtual void SetUseOutline (int)
void SetTriangulate (int)
void SetNonlinearSubdivisionLevel (int)
void SetMatchBoundariesIgnoringCellOrder (int)
virtual void SetGenerateFeatureEdges (bool)
virtual void SetAmbientColor (double r, double g, double b)
virtual void SetColor (double r, double g, double b)
virtual void SetDiffuseColor (double r, double g, double b)
virtual void SetEdgeColor (double r, double g, double b)
virtual void SetInteractiveSelectionColor (double r, double g, double b)
virtual void SetInterpolation (int val)
virtual void SetLineWidth (double val)
virtual void SetOpacity (double val)
virtual void SetEdgeOpacity (double val)
virtual void SetPointSize (double val)
virtual void SetSpecularColor (double r, double g, double b)
virtual void SetSpecularPower (double val)
virtual void SetLuminosity (double val)
virtual void SetRenderPointsAsSpheres (bool)
virtual void SetRenderLinesAsTubes (bool)
virtual void SetRoughness (double val)
virtual void SetMetallic (double val)
virtual void SetEdgeTint (double r, double g, double b)
virtual void SetAnisotropy (double val)
virtual void SetAnisotropyRotation (double val)
virtual void SetBaseIOR (double val)
virtual void SetCoatIOR (double val)
virtual void SetCoatStrength (double val)
virtual void SetCoatRoughness (double val)
virtual void SetCoatNormalScale (double val)
virtual void SetCoatColor (double r, double g, double b)
virtual void SetBaseColorTexture (vtkTexture *tex)
virtual void SetMaterialTexture (vtkTexture *tex)
virtual void SetAnisotropyTexture (vtkTexture *tex)
virtual void SetNormalTexture (vtkTexture *tex)
virtual void SetCoatNormalTexture (vtkTexture *tex)
virtual void SetEmissiveTexture (vtkTexture *tex)
virtual void SetNormalScale (double val)
virtual void SetOcclusionStrength (double val)
virtual void SetEmissiveFactor (double rval, double gval, double bval)
virtual void SetShowTexturesOnBackface (bool)
virtual void SetOrientation (double, double, double)
virtual void SetOrigin (double, double, double)
virtual void SetPickable (int val)
virtual void SetPosition (double, double, double)
virtual void SetScale (double, double, double)
virtual void SetTexture (vtkTexture *)
virtual void SetUserTransform (const double[16])
virtual void SetFlipTextures (bool)
virtual void SetRepeatTextures (bool)
virtual bool GetRepeatTextures ()
virtual void SetInterpolateTextures (bool)
virtual bool GetInterpolateTextures ()
virtual void SetUseMipmapTextures (bool)
virtual bool GetUseMipmapTextures ()
virtual void SetInterpolateScalarsBeforeMapping (int val)
virtual void SetLookupTable (vtkScalarsToColors *val)
virtual void SetColorMissingArraysWithNanColor (bool val)
virtual void SetSeamlessU (bool)
virtual void SetSeamlessV (bool)
virtual void SetSelection (vtkSelection *selection)
 Sets the selection used by the mapper. More...
vtkPVLODActor * GetActor ()
 Provides access to the actor used by this representation. More...
const char * GetColorArrayName ()
 Convenience method to get the array name used to scalar color with. More...
virtual void SetMaterial (const char *)
 For OSPRay, choose from among available materials. More...
virtual void SetShaderReplacements (const char *)
 Specify shader replacements using a Json string. More...
void SetArrayIdNames (const char *pointArray, const char *cellArray) override
void SetBlockColorsDistinctValues (int distinctValues)
 Determines the number of distinct values in vtkBlockColors See also vtkPVGeometryFilter. More...
int GetBlockColorsDistinctValues ()
virtual void SetAmbient (double)
 Set the lighting properties of the object. More...
virtual void SetDiffuse (double)
virtual void SetSpecular (double)
virtual double GetAmbient ()
virtual double GetDiffuse ()
virtual double GetSpecular ()
void SetCoordinateShiftScaleMethod (int val)
 Set the shift scale method for the point coordinates see vtkOpenGLVertexBufferObject.h for more information. More...
int GetCoordinateShiftScaleMethod ()
virtual void SetRepresentation (int)
 Set the representation type. More...
virtual int GetRepresentation ()
virtual void SetRequestGhostCellsIfNeeded (bool)
 Representations that use geometry representation as the internal representation should turn this flag off so that we don't end up requesting ghost cells twice. More...
virtual bool GetRequestGhostCellsIfNeeded ()
virtual void RequestGhostCellsIfNeededOn ()
virtual void RequestGhostCellsIfNeededOff ()
virtual void SetMapScalars (int val)
 Sets if scalars are mapped through a color-map or are used directly as colors. More...
virtual void SetStatic (int val)
virtual void SetActiveAssembly (const char *)
 Get/Set the name of the assembly to use for mapping block visibilities, colors and opacities. More...
virtual char * GetActiveAssembly ()
void AddBlockSelector (const char *)
 Update list of selectors that determine the selected blocks. More...
void RemoveAllBlockSelectors ()
void SetBlockColor (const char *, double, double, double)
 Set/get the color for a single block. More...
void RemoveAllBlockColors ()
void SetBlockOpacity (const char *, double)
 Set/get the opacityfor a single block. More...
void RemoveAllBlockOpacities ()
virtual void SetEnableScaling (int v)
 For OSPRay controls sizing of implicit spheres (points) and cylinders (lines) More...
virtual void SetScalingArrayName (const char *)
virtual void SetScalingFunction (vtkPiecewiseFunction *pwf)
virtual void SetUseDataPartitions (bool)
 Specify whether or not to redistribute the data. More...
virtual bool GetUseDataPartitions ()
virtual void SetUseShaderReplacements (bool)
 Specify whether or not to shader replacements string must be used. More...
virtual bool GetUseShaderReplacements ()
virtual void MarkModified ()
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkGeometrySliceRepresentation * New ()
static vtkGeometrySliceRepresentation * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkGeometryRepresentation
static vtkGeometryRepresentation * New ()
static vtkGeometryRepresentation * SafeDownCast (vtkObject *o)
static bool GetBounds (vtkDataObject *dataObject, double bounds[6], vtkCompositeDataDisplayAttributes *cdAttributes)
 Convenience method to get bounds from a dataset/composite dataset. More...
static vtkAlgorithm * New ()
 vtkGeometrySliceRepresentation ()
 ~vtkGeometrySliceRepresentation () override
void SetupDefaults () override
 This method is called in the constructor. More...
 Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
- Protected Member Functions inherited from vtkGeometryRepresentation
 vtkGeometryRepresentation ()
 ~vtkGeometryRepresentation () override
 Overridden to request correct ghost-level to avoid internal surfaces. More...
virtual void UpdateColoringParameters ()
 Passes on parameters to vtkProperty and vtkMapper. More...
virtual vtkPVLODActor * GetRenderedProp ()
 Used in ConvertSelection to locate the prop used for actual rendering. More...
void HandleGeometryRepresentationProgress (vtkObject *caller, unsigned long, void *)
void PopulateBlockAttributes (vtkCompositeDataDisplayAttributes *attrs, vtkDataObject *outputData)
 Block attributes in a mapper are referenced to each block through DataObject pointers. More...
void ComputeVisibleDataBounds ()
 Computes the bounds of the visible data based on the block visibilities in the composite data attributes of the mapper. More...
void UpdateShaderReplacements ()
 Update the mapper with the shader replacement strings if feature is enabled. More...
virtual bool NeedsOrderedCompositing ()
 Returns true if this representation has translucent geometry. More...
virtual void SetPointArrayToProcess (int p, const char *val)
 Used by SetNormalArray, SetTCoordArray and SetTangentArray. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Protected Attributes inherited from vtkGeometryRepresentation
vtkAlgorithm * GeometryFilter
vtkAlgorithm * MultiBlockMaker
vtkGeometryRepresentation_detail::DecimationFilterType * Decimator
vtkPVGeometryFilter * LODOutlineFilter
vtkMapper * Mapper
vtkMapper * LODMapper
vtkPVLODActor * Actor
vtkProperty * Property
char * ActiveAssembly = nullptr
bool RepeatTextures
bool InterpolateTextures
bool UseMipmapTextures
double Ambient
double Specular
double Diffuse
int Representation
bool SuppressLOD
bool RequestGhostCellsIfNeeded
double VisibleDataBounds [6]
vtkTimeStamp VisibleDataBoundsTime
vtkPiecewiseFunction * PWF
bool UseDataPartitions
bool UseShaderReplacements
std::string ShaderReplacementsString
bool BlockAttrChanged = false
vtkTimeStamp BlockAttributeTime
bool UpdateBlockAttrLOD = false
std::set< std::string > BlockSelectors
std::unordered_map< std::string, double > BlockOpacities
std::unordered_map< std::string, vtkVector3d > BlockColors
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
vtkGeometrySliceRepresentation extends vtkGeometryRepresentation to show slices from the dataset. This is used for vtkPVMultiSliceView and vtkPVOrthographicSliceView.
Definition at line 18 of file vtkGeometrySliceRepresentation.h.
Definition at line 22 of file vtkGeometrySliceRepresentation.h.
◆ anonymous enum
anonymous enum
Enumerator
X_SLICE_ONLY
Y_SLICE_ONLY
Z_SLICE_ONLY
ALL_SLICES
Definition at line 28 of file vtkGeometrySliceRepresentation.h.
◆ vtkGeometrySliceRepresentation()
vtkGeometrySliceRepresentation::vtkGeometrySliceRepresentation ( )
◆ ~vtkGeometrySliceRepresentation()
vtkGeometrySliceRepresentation::~vtkGeometrySliceRepresentation ( )
static vtkGeometrySliceRepresentation* vtkGeometrySliceRepresentation::New ( )
virtual const char* vtkGeometrySliceRepresentation::GetClassName ( )
Reimplemented from vtkGeometryRepresentation.
static int vtkGeometrySliceRepresentation::IsTypeOf ( const char *  type)
virtual int vtkGeometrySliceRepresentation::IsA ( const char *  type)
static vtkGeometrySliceRepresentation* vtkGeometrySliceRepresentation::SafeDownCast ( vtkObject *  o)
void vtkGeometrySliceRepresentation::PrintSelf ( ostream &  os,
◆ ProcessViewRequest()
int vtkGeometrySliceRepresentation::ProcessViewRequest ( vtkInformationRequestKey *  request_type,
vtkInformation *  inInfo,
vtkInformation *  outInfo
◆ SetMode()
virtual void vtkGeometrySliceRepresentation::SetMode ( int  )
◆ GetMode()
virtual int vtkGeometrySliceRepresentation::GetMode ( )
◆ SetShowOutline()
virtual void vtkGeometrySliceRepresentation::SetShowOutline ( bool  )
◆ GetShowOutline()
virtual bool vtkGeometrySliceRepresentation::GetShowOutline ( )
◆ SetupDefaults()
void vtkGeometrySliceRepresentation::SetupDefaults ( )
overrideprotectedvirtual
If the subclasses override any of the iVar vtkObject's of this class e.g. the Mappers, GeometryFilter etc., they should call this method again in their constructor. It must be totally safe to call this method repeatedly.
◆ RequestData()
int vtkGeometrySliceRepresentation::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
Since most representations are "meta-filters" (i.e. filters containing other filters), you should create shallow copies of your input before connecting to the internal pipeline. The convenience method GetInternalOutputPort will create a cached shallow copy of a specified input for you. The related helper functions GetInternalAnnotationOutputPort, GetInternalSelectionOutputPort should be used to obtain a selection or annotation port whose selections are localized for a particular input data object.
◆ AddToView()
bool vtkGeometrySliceRepresentation::AddToView ( vtkView *  view)
◆ RemoveFromView()
bool vtkGeometrySliceRepresentation::RemoveFromView ( vtkView *  view)
