vtkCompositeRepresentation Class Reference
combine multiple representations into one with only 1 representation active at a time. More...
#include <vtkCompositeRepresentation.h>
Inheritance diagram for vtkCompositeRepresentation:
Collaboration diagram for vtkCompositeRepresentation:
enum  DesiredOutputPrecision
void SetVisibility (bool val) override
 Methods overridden to propagate to the active representation. More...
vtkPVDataRepresentation * GetActiveRepresentation ()
 Returns the active representation if valid. More...
void SetSelectionConnection (vtkAlgorithmOutput *input)
 Set the selection connection. More...
void MarkModified () override
 Propagate the modification to all internal representations. More...
vtkDataObject * GetRenderedDataObject (int port) override
vtkStringArray * GetRepresentationTypes ()
 Returns the list of available representation types as a string array. More...
virtual void AddRepresentation (const char *key, vtkPVDataRepresentation *repr)
 Add/Remove representations. More...
virtual void RemoveRepresentation (vtkPVDataRepresentation *repr)
virtual void RemoveRepresentation (const char *key)
void SetActiveRepresentation (const char *key)
 Set the active key. More...
const char * GetActiveRepresentationKey ()
 Overridden to simply pass the input to the internal representations. More...
void SetInputConnection (vtkAlgorithmOutput *input) override
void AddInputConnection (vtkAlgorithmOutput *input) override
void RemoveInputConnection (int port, vtkAlgorithmOutput *input) override
void RemoveInputConnection (int port, int idx) override
void SetUpdateTime (double time) override
 Passed on to internal representations as well. More...
void SetForceUseCache (bool val) override
void SetForcedCacheKey (double val) override
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkCompositeRepresentation * New ()
static vtkCompositeRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkCompositeRepresentation ()
 ~vtkCompositeRepresentation () override
int FillInputPortInformation (int, vtkInformation *info) override
void TriggerUpdateDataEvent ()
 Fires UpdateDataEvent. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
vtkCompositeRepresentation makes is possible to combine multiple representations into one. Only one representation can be active at a give time. vtkCompositeRepresentation provides API to add the representations that form the composite and to pick the active representation.
vtkCompositeRepresentation relies on call AddToView and RemoveFromView on the internal representations whenever it needs to change the active representation. So it is essential that representations handle those methods correctly and don't suffer from uncanny side effects when that's done repeatedly.
Definition at line 28 of file vtkCompositeRepresentation.h.
Definition at line 32 of file vtkCompositeRepresentation.h.
◆ vtkCompositeRepresentation()
vtkCompositeRepresentation::vtkCompositeRepresentation ( )
◆ ~vtkCompositeRepresentation()
vtkCompositeRepresentation::~vtkCompositeRepresentation ( )
static vtkCompositeRepresentation* vtkCompositeRepresentation::New ( )
virtual const char* vtkCompositeRepresentation::GetClassName ( )
static int vtkCompositeRepresentation::IsTypeOf ( const char *  type)
virtual int vtkCompositeRepresentation::IsA ( const char *  type)
static vtkCompositeRepresentation* vtkCompositeRepresentation::SafeDownCast ( vtkObject *  o)
void vtkCompositeRepresentation::PrintSelf ( ostream &  os,
◆ ProcessViewRequest()
int vtkCompositeRepresentation::ProcessViewRequest ( vtkInformationRequestKey *  request_type,
vtkInformation *  inInfo,
vtkInformation *  outInfo
Note
Starting with ParaView 5.8, this method is no longer called for hidden representation i.e. representations for which vtkDataRepresentation::GetVisibility() returns false.
◆ SetVisibility()
void vtkCompositeRepresentation::SetVisibility ( bool  val)
Reimplemented in vtkPVCompositeRepresentation, and vtkPVCompositeOrthographicSliceRepresentation.
◆ AddRepresentation()
virtual void vtkCompositeRepresentation::AddRepresentation ( const char *  key,
vtkPVDataRepresentation *  repr
key is a unique string used to identify that representation.
◆ RemoveRepresentation() [1/2]
virtual void vtkCompositeRepresentation::RemoveRepresentation ( vtkPVDataRepresentation *  repr)
◆ RemoveRepresentation() [2/2]
virtual void vtkCompositeRepresentation::RemoveRepresentation ( const char *  key)
◆ SetActiveRepresentation()
void vtkCompositeRepresentation::SetActiveRepresentation ( const char *  key)
Set the active key.
If a valid key is not specified, then none of the representations is treated as active.
◆ GetActiveRepresentationKey()
const char* vtkCompositeRepresentation::GetActiveRepresentationKey ( )
Set the active key.
◆ GetActiveRepresentation()
vtkPVDataRepresentation* vtkCompositeRepresentation::GetActiveRepresentation ( )
◆ SetInputConnection() [1/2]
void vtkCompositeRepresentation::SetInputConnection ( int  port,
vtkAlgorithmOutput *  input
We won't need this if vtkPVDataRepresentation correctly respected in the arguments passed to it during ProcessRequest() etc.
◆ SetInputConnection() [2/2]
void vtkCompositeRepresentation::SetInputConnection ( vtkAlgorithmOutput *  input)
◆ AddInputConnection() [1/2]
void vtkCompositeRepresentation::AddInputConnection ( int  port,
◆ AddInputConnection() [2/2]
void vtkCompositeRepresentation::AddInputConnection ( vtkAlgorithmOutput *  input)
◆ RemoveInputConnection() [1/2]
void vtkCompositeRepresentation::RemoveInputConnection ( int  port,
◆ RemoveInputConnection() [2/2]
int  idx
Reimplemented in vtkPVCompositeOrthographicSliceRepresentation, and vtkPVCompositeRepresentation.
◆ SetSelectionConnection()
void vtkCompositeRepresentation::SetSelectionConnection ( vtkAlgorithmOutput *  input)
This is used to pass a selection source output to the mapper in order to display the selection content.
◆ MarkModified()
void vtkCompositeRepresentation::MarkModified ( )
◆ GetRenderedDataObject()
vtkDataObject* vtkCompositeRepresentation::GetRenderedDataObject ( int  port)
override
Returns the data object that is rendered from the given input port.
◆ GetRepresentationTypes()
vtkStringArray* vtkCompositeRepresentation::GetRepresentationTypes ( )
◆ SetUpdateTime()
void vtkCompositeRepresentation::SetUpdateTime ( double  time)
Reimplemented in vtkPVCompositeRepresentation.
◆ SetForceUseCache()
void vtkCompositeRepresentation::SetForceUseCache ( bool  val)
◆ SetForcedCacheKey()
void vtkCompositeRepresentation::SetForcedCacheKey ( double  val)
◆ FillInputPortInformation()
int vtkCompositeRepresentation::FillInputPortInformation ( int  ,
vtkInformation *  info
overrideprotectedvirtual
◆ AddToView()
bool vtkCompositeRepresentation::AddToView ( vtkView *  view)
◆ RemoveFromView()
bool vtkCompositeRepresentation::RemoveFromView ( vtkView *  view)
◆ TriggerUpdateDataEvent()
void vtkCompositeRepresentation::TriggerUpdateDataEvent ( )
