vtkAMRStreamingVolumeRepresentation Class Reference
representation used for volume rendering AMR datasets with ability to stream blocks. More...
#include <vtkAMRStreamingVolumeRepresentation.h>
Inheritance diagram for vtkAMRStreamingVolumeRepresentation:
Collaboration diagram for vtkAMRStreamingVolumeRepresentation:
enum  ResamplingModes { RESAMPLE_OVER_DATA_BOUNDS = 0, RESAMPLE_USING_VIEW_FRUSTUM = 1 }
enum  DesiredOutputPrecision
void SetVisibility (bool val) override
void SetNumberOfSamples (int x, int y, int z)
 Get/Set the resample buffer size. More...
void SetOrientation (double, double, double)
void SetOrigin (double, double, double)
void SetPickable (int val)
void SetPosition (double, double, double)
void SetScale (double, double, double)
void SetInterpolationType (int val)
void SetColor (vtkColorTransferFunction *lut)
void SetScalarOpacity (vtkPiecewiseFunction *pwf)
void SetScalarOpacityUnitDistance (double val)
void SetAmbient (double)
void SetDiffuse (double)
void SetSpecular (double)
void SetSpecularPower (double)
void SetShade (bool)
void SetIndependantComponents (bool)
void SetRequestedRenderMode (int)
void SetResamplingMode (int val)
 This control the logic used to determine how to place the resampling grid within the AMR bounds. More...
virtual int GetResamplingMode ()
virtual void SetStreamingRequestSize (int)
 Set the number of blocks to request at a given time on a single process when streaming. More...
virtual int GetStreamingRequestSize ()
void SetInputArrayToProcess (int idx, int port, int connection, int fieldAssociation, const char *name) override
 Set the input data arrays that this algorithm will process. More...
void SetInputArrayToProcess (int idx, int port, int connection, int fieldAssociation, int fieldAttributeType) override
void SetInputArrayToProcess (int idx, vtkInformation *info) override
void SetInputArrayToProcess (int idx, int port, int connection, const char *fieldAssociation, const char *attributeTypeorName) override
virtual void MarkModified ()
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkAMRStreamingVolumeRepresentation * New ()
static vtkAMRStreamingVolumeRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkAMRStreamingVolumeRepresentation ()
 ~vtkAMRStreamingVolumeRepresentation () override
int RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
 Overridden to check if the input pipeline is streaming capable. More...
 Setup the block request. More...
 Process the current input for volume rendering (if anything). More...
bool StreamingUpdate (vtkPVRenderView *view, const double view_planes[24])
 Returns true if this representation has a "next piece" that it streamed. More...
virtual bool GetStreamingCapablePipeline ()
 Returns true when the input pipeline supports streaming. More...
virtual bool GetInStreamingUpdate ()
 Returns true when StreamingUpdate() is being processed. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkSmartPointer< vtkDataObject > ProcessedData
 This is the data object generated processed by the most recent call to RequestData() while not streaming. More...
vtkSmartPointer< vtkDataObject > ProcessedPiece
 This is the data object generated processed by the most recent call to RequestData() while streaming. More...
vtkSmartPointer< vtkAMRStreamingPriorityQueue > PriorityQueue
 vtkAMRStreamingPriorityQueue is a helper class we used to compute the order in which to request blocks from the input pipeline. More...
vtkSmartPointer< vtkResampledAMRImageSource > Resampler
 vtkImageData source used to resample an AMR dataset into a uniform grid suitable for volume rendering. More...
vtkBoundingBox DataBounds
 Used to keep track of data bounds. More...
int ResamplingMode
int StreamingRequestSize
vtkSmartPointer< vtkSmartVolumeMapper > VolumeMapper
 Rendering components. More...
vtkSmartPointer< vtkAMRVolumeMapper > AMRVolumeMapper
vtkSmartPointer< vtkVolumeProperty > Property
vtkSmartPointer< vtkPVLODVolume > Actor
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkAMRStreamingVolumeRepresentation is a representation used for volume rendering AMR datasets with ability to stream blocks from the input pipeline.
Definition at line 32 of file vtkAMRStreamingVolumeRepresentation.h.
Definition at line 36 of file vtkAMRStreamingVolumeRepresentation.h.
◆ ResamplingModes
Enumerator
Definition at line 39 of file vtkAMRStreamingVolumeRepresentation.h.
◆ vtkAMRStreamingVolumeRepresentation()
vtkAMRStreamingVolumeRepresentation::vtkAMRStreamingVolumeRepresentation ( )
◆ ~vtkAMRStreamingVolumeRepresentation()
vtkAMRStreamingVolumeRepresentation::~vtkAMRStreamingVolumeRepresentation ( )
static vtkAMRStreamingVolumeRepresentation* vtkAMRStreamingVolumeRepresentation::New ( )
virtual const char* vtkAMRStreamingVolumeRepresentation::GetClassName ( )
static int vtkAMRStreamingVolumeRepresentation::IsTypeOf ( const char *  type)
virtual int vtkAMRStreamingVolumeRepresentation::IsA ( const char *  type)
static vtkAMRStreamingVolumeRepresentation* vtkAMRStreamingVolumeRepresentation::SafeDownCast ( vtkObject *  o)
void vtkAMRStreamingVolumeRepresentation::PrintSelf ( ostream &  os,
◆ SetResamplingMode()
void vtkAMRStreamingVolumeRepresentation::SetResamplingMode ( int  val)
  • RESAMPLE_OVER_DATA_BOUNDS implies that the amr volume is set to the data bounds and is not updated as the user interacts.
  • RESAMPLE_USING_VIEW_FRUSTUM indicates that the uniform grid must be repositioned when the camera changes using the current view frustum.
◆ GetResamplingMode()
virtual int vtkAMRStreamingVolumeRepresentation::GetResamplingMode ( )
◆ ProcessViewRequest()
int vtkAMRStreamingVolumeRepresentation::ProcessViewRequest ( vtkInformationRequestKey *  request_type,
vtkInformation *  inInfo,
vtkInformation *  outInfo
This is typically called by the vtkView to request meta-data from the representations or ask them to perform certain tasks e.g. PrepareForRendering. Overridden to skip processing when visibility if off.
◆ SetVisibility()
void vtkAMRStreamingVolumeRepresentation::SetVisibility ( bool  val)
When the visibility of representation of false, all view passes are ignored.
◆ SetNumberOfSamples()
void vtkAMRStreamingVolumeRepresentation::SetNumberOfSamples ( int  x,
int  y,
int  z
This controls the resolution at which the data is resampled.
◆ SetStreamingRequestSize()
virtual void vtkAMRStreamingVolumeRepresentation::SetStreamingRequestSize ( int  )
◆ GetStreamingRequestSize()
virtual int vtkAMRStreamingVolumeRepresentation::GetStreamingRequestSize ( )
◆ SetInputArrayToProcess() [1/4]
void vtkAMRStreamingVolumeRepresentation::SetInputArrayToProcess ( int  idx,
int  port,
int  connection,
const char *  name
◆ SetInputArrayToProcess() [2/4]
int  port,
int  connection,
inlineoverridevirtual
Definition at line 95 of file vtkAMRStreamingVolumeRepresentation.h.
◆ SetInputArrayToProcess() [3/4]
vtkInformation *  info
Definition at line 101 of file vtkAMRStreamingVolumeRepresentation.h.
◆ SetInputArrayToProcess() [4/4]
int  port,
int  connection,
const char *  fieldAssociation,
const char *  attributeTypeorName
Definition at line 105 of file vtkAMRStreamingVolumeRepresentation.h.
◆ SetOrientation()
void vtkAMRStreamingVolumeRepresentation::SetOrientation ( double  ,
double  ,
double
◆ SetOrigin()
void vtkAMRStreamingVolumeRepresentation::SetOrigin ( double  ,
double  ,
double
◆ SetPickable()
void vtkAMRStreamingVolumeRepresentation::SetPickable ( int  val)
◆ SetPosition()
void vtkAMRStreamingVolumeRepresentation::SetPosition ( double  ,
double  ,
double
◆ SetScale()
void vtkAMRStreamingVolumeRepresentation::SetScale ( double  ,
double  ,
double
◆ SetInterpolationType()
void vtkAMRStreamingVolumeRepresentation::SetInterpolationType ( int  val)
◆ SetColor()
void vtkAMRStreamingVolumeRepresentation::SetColor ( vtkColorTransferFunction *  lut)
◆ SetScalarOpacity()
void vtkAMRStreamingVolumeRepresentation::SetScalarOpacity ( vtkPiecewiseFunction *  pwf)
◆ SetScalarOpacityUnitDistance()
void vtkAMRStreamingVolumeRepresentation::SetScalarOpacityUnitDistance ( double  val)
◆ SetAmbient()
void vtkAMRStreamingVolumeRepresentation::SetAmbient ( double  )
◆ SetDiffuse()
void vtkAMRStreamingVolumeRepresentation::SetDiffuse ( double  )
◆ SetSpecular()
void vtkAMRStreamingVolumeRepresentation::SetSpecular ( double  )
◆ SetSpecularPower()
void vtkAMRStreamingVolumeRepresentation::SetSpecularPower ( double  )
◆ SetShade()
void vtkAMRStreamingVolumeRepresentation::SetShade ( bool  )
◆ SetIndependantComponents()
void vtkAMRStreamingVolumeRepresentation::SetIndependantComponents ( bool  )
◆ SetRequestedRenderMode()
void vtkAMRStreamingVolumeRepresentation::SetRequestedRenderMode ( int  )
◆ AddToView()
bool vtkAMRStreamingVolumeRepresentation::AddToView ( vtkView *  view)
◆ RemoveFromView()
bool vtkAMRStreamingVolumeRepresentation::RemoveFromView ( vtkView *  view)
◆ FillInputPortInformation()
int vtkAMRStreamingVolumeRepresentation::FillInputPortInformation ( int  port,
overrideprotectedvirtual
Fill input port information.
◆ RequestInformation()
int vtkAMRStreamingVolumeRepresentation::RequestInformation ( vtkInformation *  request,
This method should check if streaming is enabled i.e. vtkPVView::GetEnableStreaming() and the input pipeline provides necessary AMR meta-data.
◆ RequestUpdateExtent()
int vtkAMRStreamingVolumeRepresentation::RequestUpdateExtent ( vtkInformation *  request,
During StreamingUpdate, this will request the blocks based on priorities determined by the vtkAMRStreamingPriorityQueue, otherwise it doesn't make any specific request. AMR sources can treat the absence of specific block request to mean various things. It's expected that read only the root block (or a few more) in that case.
◆ RequestData()
int vtkAMRStreamingVolumeRepresentation::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
When not in StreamingUpdate, this also initializes the priority queue since the input AMR may have totally changed, including its structure.
◆ GetStreamingCapablePipeline()
virtual bool vtkAMRStreamingVolumeRepresentation::GetStreamingCapablePipeline ( )
protectedvirtual
It is set in RequestInformation().
◆ GetInStreamingUpdate()
virtual bool vtkAMRStreamingVolumeRepresentation::GetInStreamingUpdate ( )
protectedvirtual
◆ StreamingUpdate()
bool vtkAMRStreamingVolumeRepresentation::StreamingUpdate ( vtkPVRenderView *  view,
This method will update the PriorityQueue using the view planes specified and then call Update() on the representation, making it reexecute and regenerate the outline for the next "piece" of data.
◆ ProcessedData
vtkSmartPointer<vtkDataObject> vtkAMRStreamingVolumeRepresentation::ProcessedData
This is non-empty only on the data-server nodes.
Definition at line 217 of file vtkAMRStreamingVolumeRepresentation.h.
◆ ProcessedPiece
vtkSmartPointer<vtkDataObject> vtkAMRStreamingVolumeRepresentation::ProcessedPiece
Definition at line 224 of file vtkAMRStreamingVolumeRepresentation.h.
◆ PriorityQueue
vtkSmartPointer<vtkAMRStreamingPriorityQueue> vtkAMRStreamingVolumeRepresentation::PriorityQueue
Implementations can come up with their own rules to decide the request order based on application and data type.
Definition at line 232 of file vtkAMRStreamingVolumeRepresentation.h.
◆ Resampler
vtkSmartPointer<vtkResampledAMRImageSource> vtkAMRStreamingVolumeRepresentation::Resampler
Definition at line 238 of file vtkAMRStreamingVolumeRepresentation.h.
◆ VolumeMapper
vtkSmartPointer<vtkSmartVolumeMapper> vtkAMRStreamingVolumeRepresentation::VolumeMapper
Definition at line 244 of file vtkAMRStreamingVolumeRepresentation.h.
◆ AMRVolumeMapper
vtkSmartPointer<vtkAMRVolumeMapper> vtkAMRStreamingVolumeRepresentation::AMRVolumeMapper
Definition at line 245 of file vtkAMRStreamingVolumeRepresentation.h.
◆ Property
vtkSmartPointer<vtkVolumeProperty> vtkAMRStreamingVolumeRepresentation::Property
Definition at line 246 of file vtkAMRStreamingVolumeRepresentation.h.
◆ Actor
vtkSmartPointer<vtkPVLODVolume> vtkAMRStreamingVolumeRepresentation::Actor
Definition at line 247 of file vtkAMRStreamingVolumeRepresentation.h.
◆ DataBounds
vtkBoundingBox vtkAMRStreamingVolumeRepresentation::DataBounds
Definition at line 253 of file vtkAMRStreamingVolumeRepresentation.h.
◆ ResamplingMode
int vtkAMRStreamingVolumeRepresentation::ResamplingMode
Definition at line 255 of file vtkAMRStreamingVolumeRepresentation.h.
◆ StreamingRequestSize
int vtkAMRStreamingVolumeRepresentation::StreamingRequestSize
Definition at line 256 of file vtkAMRStreamingVolumeRepresentation.h.
