vtkResampledAMRImageSource Class Reference
image data source that resamples an AMR dataset to produce the image data. More...
#include <vtkResampledAMRImageSource.h>
Inheritance diagram for vtkResampledAMRImageSource:
Collaboration diagram for vtkResampledAMRImageSource:
typedef vtkTrivialProducer Superclass
- Public Types inherited from vtkTrivialProducer
enum  DesiredOutputPrecision
void Reset ()
 To restart the incremental resample process, call this method. More...
void UpdateResampledVolume (vtkOverlappingAMR *)
 Updates the volume. More...
bool NeedsInitialization () const
 Returns true if the resampler will reinitialize the volume in the next call to UpdateResampledVolume(). More...
virtual void SetMaxDimensions (int, int, int)
 Get/Set the maximum number of samples along each axis. More...
virtual void SetMaxDimensions (int[3])
virtual int * GetMaxDimensions ()
virtual void GetMaxDimensions (int &, int &, int &)
virtual void GetMaxDimensions (int[3])
virtual void SetSpatialBounds (double, double, double, double, double, double)
 When provided, the resampled image is set up to cover these bounds. More...
virtual void SetSpatialBounds (double[6])
virtual double * GetSpatialBounds ()
virtual void GetSpatialBounds (double &, double &, double &, double &, double &, double &)
virtual void GetSpatialBounds (double[6])
- Public Member Functions inherited from vtkTrivialProducer
vtkTrivialProducer * NewInstance () const
virtual void SetOutput (vtkDataObject *output)
virtual void SetWholeExtent (int, int, int, int, int, int)
virtual void SetWholeExtent (int[6])
virtual int * GetWholeExtent ()
virtual void GetWholeExtent (int &, int &, int &, int &, int &, int &)
virtual void GetWholeExtent (int[6])
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkResampledAMRImageSource * New ()
static vtkResampledAMRImageSource * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkTrivialProducer
static vtkTrivialProducer * New ()
static vtkTrivialProducer * SafeDownCast (vtkObjectBase *o)
static void FillOutputDataInformation (vtkDataObject *output, vtkInformation *outInfo)
static vtkAlgorithm * New ()
 vtkResampledAMRImageSource ()
 ~vtkResampledAMRImageSource () override
bool Initialize (vtkOverlappingAMR *amr)
bool UpdateResampledVolume (const unsigned int &level, const unsigned &index, const vtkAMRBox &box, vtkImageData *data)
- Protected Member Functions inherited from vtkTrivialProducer
 vtkTrivialProducer ()
 ~vtkTrivialProducer ()
virtual int FillInputPortInformation (int, vtkInformation *)
virtual int FillOutputPortInformation (int, vtkInformation *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
int MaxDimensions [3]
double SpatialBounds [6]
vtkSmartPointer< vtkImageData > ResampledAMR
vtkSmartPointer< vtkPointData > ResampledAMRPointData
vtkSmartPointer< vtkIntArray > DonorLevel
- Protected Attributes inherited from vtkTrivialProducer
vtkDataObject * Output
int WholeExtent [6]
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkResampledAMRImageSource is a image data source that resamples a vtkOverlappingAMR dataset to produce an image data. The output AMR will have both the point data and cell data from the input AMR grids passed along as point data for the output image data. This filter assumes that all blocks in the input AMR have exactly the same point/cell arrays in same order. If they are different we will end up with weird runtime issues that may be hard to debug.
Attention
We subclass vtkTrivialProducer since it deals with all the meta-data that needs to be passed down the pipeline for image data, keeping the code here simple.
Definition at line 35 of file vtkResampledAMRImageSource.h.
Definition at line 40 of file vtkResampledAMRImageSource.h.
◆ vtkResampledAMRImageSource()
vtkResampledAMRImageSource::vtkResampledAMRImageSource ( )
◆ ~vtkResampledAMRImageSource()
vtkResampledAMRImageSource::~vtkResampledAMRImageSource ( )
static vtkResampledAMRImageSource* vtkResampledAMRImageSource::New ( )
virtual const char* vtkResampledAMRImageSource::GetClassName ( )
static int vtkResampledAMRImageSource::IsTypeOf ( const char *  type)
virtual int vtkResampledAMRImageSource::IsA ( const char *  type)
Reimplemented from vtkTrivialProducer.
static vtkResampledAMRImageSource* vtkResampledAMRImageSource::SafeDownCast ( vtkObject *  o)
void vtkResampledAMRImageSource::PrintSelf ( ostream &  os,
◆ SetMaxDimensions() [1/2]
virtual void vtkResampledAMRImageSource::SetMaxDimensions ( int  ,
int  ,
int
◆ SetMaxDimensions() [2/2]
virtual void vtkResampledAMRImageSource::SetMaxDimensions ( int  [3])
◆ GetMaxDimensions() [1/3]
virtual int* vtkResampledAMRImageSource::GetMaxDimensions ( )
◆ GetMaxDimensions() [2/3]
virtual void vtkResampledAMRImageSource::GetMaxDimensions ( int &  ,
int &  ,
int &
◆ GetMaxDimensions() [3/3]
virtual void vtkResampledAMRImageSource::GetMaxDimensions ( int  [3])
◆ SetSpatialBounds() [1/2]
virtual void vtkResampledAMRImageSource::SetSpatialBounds ( double  ,
double  ,
double  ,
double  ,
double  ,
double
If not provided, data bounds are used. If provided, these bounds MUST fit within the data bounds. This is essential to ensure valid resampled volume is generated.
◆ SetSpatialBounds() [2/2]
virtual void vtkResampledAMRImageSource::SetSpatialBounds ( double  [6])
◆ GetSpatialBounds() [1/3]
virtual double* vtkResampledAMRImageSource::GetSpatialBounds ( )
◆ GetSpatialBounds() [2/3]
virtual void vtkResampledAMRImageSource::GetSpatialBounds ( double &  ,
double &  ,
double &  ,
double &  ,
double &  ,
double &
◆ GetSpatialBounds() [3/3]
virtual void vtkResampledAMRImageSource::GetSpatialBounds ( double  [6])
◆ Reset()
void vtkResampledAMRImageSource::Reset ( )
The output image data is setup in the first call to Update().
◆ UpdateResampledVolume() [1/2]
void vtkResampledAMRImageSource::UpdateResampledVolume ( vtkOverlappingAMR *  )
Updates the volume.
Any non-empty pieces provided by the amr are added to the resampled volume if it adds refinement to the volume.
◆ NeedsInitialization()
bool vtkResampledAMRImageSource::NeedsInitialization ( ) const
inline
Definition at line 78 of file vtkResampledAMRImageSource.h.
◆ Initialize()
bool vtkResampledAMRImageSource::Initialize ( vtkOverlappingAMR *  amr)
◆ UpdateResampledVolume() [2/2]
bool vtkResampledAMRImageSource::UpdateResampledVolume ( const unsigned int &  level,
const unsigned &  index,
const vtkAMRBox &  box,
vtkImageData *  data
◆ MaxDimensions
int vtkResampledAMRImageSource::MaxDimensions[3]
Definition at line 88 of file vtkResampledAMRImageSource.h.
◆ SpatialBounds
double vtkResampledAMRImageSource::SpatialBounds[6]
Definition at line 89 of file vtkResampledAMRImageSource.h.
◆ ResampledAMR
vtkSmartPointer<vtkImageData> vtkResampledAMRImageSource::ResampledAMR
Definition at line 91 of file vtkResampledAMRImageSource.h.
◆ ResampledAMRPointData
vtkSmartPointer<vtkPointData> vtkResampledAMRImageSource::ResampledAMRPointData
Definition at line 92 of file vtkResampledAMRImageSource.h.
◆ DonorLevel
vtkSmartPointer<vtkIntArray> vtkResampledAMRImageSource::DonorLevel
Definition at line 94 of file vtkResampledAMRImageSource.h.
