vtkAMRStreamingPriorityQueue Class Reference
implements a coverage based priority queue for vtkOverlappingAMR dataset. More...
#include <vtkAMRStreamingPriorityQueue.h>
Inheritance diagram for vtkAMRStreamingPriorityQueue:
Collaboration diagram for vtkAMRStreamingPriorityQueue:
void Initialize (vtkAMRInformation *amr)
 Initializes the queue. More...
void Reinitialize ()
 Re-initializes the priority queue using the amr structure given to the most recent call to Initialize(). More...
bool IsEmpty ()
 Returns if the queue is empty. More...
unsigned int Pop ()
 Pops and returns of composite id for the block at the top of the queue. More...
void SetController (vtkMultiProcessController *)
 If the controller is specified, the queue can be used in parallel. More...
void Update (const double view_planes[24], const double clamp_bounds[6])
 Updates the priorities of blocks based on the new view frustum planes. More...
void Update (const double view_planes[24])
static vtkAMRStreamingPriorityQueue * New ()
static vtkAMRStreamingPriorityQueue * SafeDownCast (vtkObject *o)
 vtkAMRStreamingPriorityQueue ()
 ~vtkAMRStreamingPriorityQueue () override
vtkAMRStreamingPriorityQueue is used by representations supporting streaming of AMR datasets to determine the priorities for blocks in the dataset. This class relies on the bounds information provided by the AMR meta-data i.e. vtkAMRInformation. This class support view-based priority computation. Simply provide the view planes (returned by vtkCamera::GetFrustumPlanes()) to the vtkAMRStreamingPriorityQueue::Update() call to update the prorities for the blocks currently in the queue.
See also
vtkAMROutlineRepresentation, vtkAMRStreamingVolumeRepresentation.
Definition at line 28 of file vtkAMRStreamingPriorityQueue.h.
Definition at line 32 of file vtkAMRStreamingPriorityQueue.h.
◆ vtkAMRStreamingPriorityQueue()
vtkAMRStreamingPriorityQueue::vtkAMRStreamingPriorityQueue ( )
◆ ~vtkAMRStreamingPriorityQueue()
vtkAMRStreamingPriorityQueue::~vtkAMRStreamingPriorityQueue ( )
static vtkAMRStreamingPriorityQueue* vtkAMRStreamingPriorityQueue::New ( )
virtual const char* vtkAMRStreamingPriorityQueue::GetClassName ( )
static int vtkAMRStreamingPriorityQueue::IsTypeOf ( const char *  type)
virtual int vtkAMRStreamingPriorityQueue::IsA ( const char *  type)
static vtkAMRStreamingPriorityQueue* vtkAMRStreamingPriorityQueue::SafeDownCast ( vtkObject *  o)
void vtkAMRStreamingPriorityQueue::PrintSelf ( ostream &  os,
◆ SetController()
void vtkAMRStreamingPriorityQueue::SetController ( vtkMultiProcessController *  )
So long as Initialize(), Update() and Pop() methods are called on all processes (need not be synchronized) and all process get the same amr tree and view_planes (which is generally true with ParaView), the blocks are distributed among the processes. By default, this is set to the vtkMultiProcessController::GetGlobalController();
◆ GetController()
virtual vtkMultiProcessController* vtkAMRStreamingPriorityQueue::GetController ( )
◆ Initialize()
void vtkAMRStreamingPriorityQueue::Initialize ( vtkAMRInformation *  amr)
All information about items in the is lost.
◆ Reinitialize()
void vtkAMRStreamingPriorityQueue::Reinitialize ( )
◆ Update() [1/2]
void vtkAMRStreamingPriorityQueue::Update ( const double  view_planes[24],
Information about blocks "popped" from the queue is preserved and those blocks are not reinserted in the queue.
◆ Update() [2/2]
void vtkAMRStreamingPriorityQueue::Update ( const double  view_planes[24])
◆ IsEmpty()
bool vtkAMRStreamingPriorityQueue::IsEmpty ( )
◆ Pop()
unsigned int vtkAMRStreamingPriorityQueue::Pop ( )
Test if the queue is empty before calling this method.
◆ Controller
vtkMultiProcessController* vtkAMRStreamingPriorityQueue::Controller
Definition at line 85 of file vtkAMRStreamingPriorityQueue.h.
