Public Slots | Public Member Functions | Protected Member Functions | List of all members
pqPipelineRepresentation Class Reference
This is PQ representation for a single display. More...
#include <pqPipelineRepresentation.h>
Inheritance diagram for pqPipelineRepresentation:
Collaboration diagram for pqPipelineRepresentation:
Public Slots
void resetLookupTableScalarRange ()
void resetLookupTableScalarRangeOverTime ()
- Public Slots inherited from pqDataRepresentation
virtual void updateLookupTable ()
 Slot to update the lookup table if the application setting to reset it on visibility changes is on. More...
virtual void resetAllTransferFunctionRangesUsingCurrentData ()
void onVisibilityChanged () override
 Overridden to set the VisibilityChangedSinceLastUpdate flag. More...
- Public Slots inherited from pqRepresentation
void renderView (bool force)
 Renders the view to which this representation has been added if any. More...
void renderViewEventually ()
 Simply calls renderView(false);. More...
 pqPipelineRepresentation (const QString &group, const QString &name, vtkSMProxy *repr, pqServer *server, QObject *parent=nullptr)
 ~pqPipelineRepresentation () override
vtkSMRepresentationProxy * getRepresentationProxy () const
- Public Member Functions inherited from pqDataRepresentation
 pqDataRepresentation (const QString &group, const QString &name, vtkSMProxy *display, pqServer *server, QObject *parent=nullptr)
 ~pqDataRepresentation () override
pqPipelineSource * getInput () const
 Get the source/filter of which this is a display. More...
pqOutputPort * getOutputPortFromInput () const
 Returns the input pqPipelineSource's output port to which this representation is connected. More...
vtkPVDataInformation * getInputDataInformation () const
 Returns the data information for the data coming into the representation as input. More...
vtkPVTemporalDataInformation * getInputTemporalDataInformation () const
 Returns the temporal data information for the input. More...
vtkPVDataInformation * getInputRankDataInformation (int rank) const
 Returns rank-specific data information from input. More...
vtkPVDataInformation * getRepresentedDataInformation (bool update=true) const
 Returns the represented data information. More...
bool getDataBounds (double bounds[6])
 Get the data bounds for the input of this display. More...
virtual vtkSMProxy * getLookupTableProxy ()
 Returns the lookuptable proxy, if any. More...
virtual pqScalarsToColors * getLookupTable ()
 Returns the pqScalarsToColors object for the lookup table proxy if any. More...
unsigned long getFullResMemorySize ()
 Returns the data size for the full-res data. More...
pqDataRepresentation * getRepresentationForUpstreamSource () const
 This is convenience method to return first representation for the upstream stream filter/source in the same view as this representation. More...
- Public Member Functions inherited from pqRepresentation
 pqRepresentation (const QString &group, const QString &name, vtkSMProxy *repr, pqServer *server, QObject *parent=nullptr)
 ~pqRepresentation () override
virtual bool isVisible () const
 Returns if the status of the visbility property of this display. More...
virtual void setVisible (bool visible)
 Set the visibility. More...
pqView * getView () const
 Returns the view to which this representation has been added, if any. More...
vtkSMViewProxy * getViewProxy () const
 Returns the view proxy to which this representation has been added, if any. More...
- Public Member Functions inherited from pqProxy
 pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr)
 ~pqProxy () override
pqServer * getServer () const
 Get the server on which this proxy exists. More...
void rename (const QString &newname)
 This is a convenience method. More...
const QString & getSMName ()
 Get the name with which this proxy is registered on the server manager. More...
const QString & getSMGroup ()
vtkSMProxy * getProxy () const
 Get the vtkSMProxy this object stands for. More...
ModifiedState modifiedState () const
 Gets whether or not the source has been modified. More...
void setModifiedState (ModifiedState modified)
 Sets whether or not the source has been modified. More...
vtkPVXMLElement * getHints () const
 Returns the hints for this proxy, if any. More...
QList< vtkSMProxy * > getHelperProxies () const
 Returns a list of all helper proxies. More...
QList< vtkSMProxy * > getHelperProxies (const QString &key) const
 Returns a list of all the helper proxies added with a given key. More...
QList< QString > getHelperKeys () const
 Returns the keys for helper proxies. More...
virtual void addHelperProxy (const QString &key, vtkSMProxy *)
 Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More...
void removeHelperProxy (const QString &key, vtkSMProxy *)
void updateHelperProxies () const
 Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More...
vtkSMSessionProxyManager * proxyManager () const
 Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More...
bool userModifiedSMName ()
 Return whether or not the user has modified the GUI name of the source. More...
- Public Member Functions inherited from pqServerManagerModelItem
 pqServerManagerModelItem (QObject *parent=nullptr)
 ~pqServerManagerModelItem () override
void setView (pqView *view) override
 Called by pqView when this representation gets added to / removed from the view. More...
- Protected Member Functions inherited from pqDataRepresentation
void initialize () override
 Use this method to initialize the pqObject state using the underlying vtkSMProxy. More...
- Protected Member Functions inherited from pqProxy
void setSMName (const QString &new_name)
 Make this pqProxy take on a new identity. More...
virtual void addInternalHelperProxy (const QString &key, vtkSMProxy *) const
virtual void removeInternalHelperProxy (const QString &key, vtkSMProxy *) const
- Protected Member Functions inherited from pqServerManagerModelItem
vtkEventQtSlotConnect * getConnector ()
 All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More...
- Public Types inherited from pqProxy
enum  ModifiedState { UNINITIALIZED, MODIFIED, UNMODIFIED }
 The modification state of this proxy. More...
- Signals inherited from pqDataRepresentation
void dataUpdated ()
 Fired when the representation proxy fires the vtkCommand::UpdateDataEvent. More...
void colorTransferFunctionModified ()
 Fired to indicate that the "LookupTable" property (if any) on the representation was modified. More...
void colorArrayNameModified ()
 Signal fired to indicate that the "ColorArrayName" property (if any) on the representation was modified. More...
void attrArrayNameModified ()
 Signal fired to indicate that the rendering attribute arrays properties (Normals, TCoords, Tangents) were modified. More...
void representationTypeModified ()
 Signal fired to indicate the representation type has changed. More...
void useSeparateOpacityArrayModified ()
 Signal fired to indicate the use separate opacity array property has changed. More...
void useTransfer2DModified ()
 Signal fired to indicate the use 2D transfer function property has changed. More...
- Signals inherited from pqRepresentation
void visibilityChanged (bool visible)
 Fired when the visibility property of the underlying display changes. More...
void updated ()
 Fired whenever Update() is called on the underlying display proxy. More...
- Signals inherited from pqProxy
void nameChanged (pqServerManagerModelItem *)
 Fired when the name of the proxy is changed. More...
void modifiedStateChanged (pqServerManagerModelItem *)
 Fired when the modified status changes for the proxy. More...
- Static Public Member Functions inherited from pqProxy
static pqProxy * findProxyWithHelper (vtkSMProxy *aproxy, QString &key)
 Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More...
static std::string rstToHtml (const char *rstStr)
 convert proxy documentation from RST to HTML (so that it can be used in Qt) More...
static QString rstToHtml (const QString &rstStr)
- Protected Slots inherited from pqDataRepresentation
virtual void onInputChanged ()
 called when input property on display changes. More...
- Protected Slots inherited from pqRepresentation
virtual void onVisibilityChanged ()
 called when the display visibility property changes. More...
- Protected Slots inherited from pqProxy
void onProxyRegistered (const QString &, const QString &, vtkSMProxy *)
void onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *)
A pqRepresentation represents a single vtkSMRepresentationProxy. The display can be added to only one render module or more (ofcouse on the same server, this class doesn't worry about that.
Definition at line 30 of file pqPipelineRepresentation.h.
◆ pqPipelineRepresentation()
pqPipelineRepresentation::pqPipelineRepresentation ( const QString &  group,
const QString &  name,
vtkSMProxy *  repr,
pqServer *  server,
QObject *  parent = nullptr
◆ ~pqPipelineRepresentation()
pqPipelineRepresentation::~pqPipelineRepresentation ( )
override
◆ getRepresentationProxy()
vtkSMRepresentationProxy* pqPipelineRepresentation::getRepresentationProxy ( ) const
◆ setView()
void pqPipelineRepresentation::setView ( pqView *  )
overrideprotectedvirtual
Reimplemented from pqRepresentation.
◆ resetLookupTableScalarRange
void pqPipelineRepresentation::resetLookupTableScalarRange ( )
slot
◆ resetLookupTableScalarRangeOverTime
void pqPipelineRepresentation::resetLookupTableScalarRangeOverTime ( )
slot
