Public Member Functions | Protected Slots | Protected Member Functions | Protected Attributes | List of all members
pqDefaultContextMenu Class Reference
This interface creates ParaView's default context menu in render views. More...
#include <pqDefaultContextMenu.h>
Inheritance diagram for pqDefaultContextMenu:
Collaboration diagram for pqDefaultContextMenu:
 pqDefaultContextMenu (QObject *parent=nullptr)
 ~pqDefaultContextMenu () override
int priority () const override
 The priority is used to order calls to pqContextMenuInterface::contextMenu among all registered instances of pqContextMenuInterface. More...
bool contextMenu (QMenu *menu, pqView *viewContext, const QPoint &viewPoint, pqRepresentation *dataContext, const QList< unsigned int > &dataBlockContext) const override
 Create ParaView's default context menu. More...
virtual bool contextMenu (QMenu *menu, pqView *viewContext, const QPoint &viewPoint, pqRepresentation *dataContext, const QList< unsigned int > &dataBlockContext) const
virtual bool contextMenu (QMenu *menu, pqView *viewContext, const QPoint &viewPoint, pqRepresentation *dataContext, const QStringList &dataBlockContext) const
- Public Member Functions inherited from pqContextMenuInterface
 pqContextMenuInterface ()
virtual ~pqContextMenuInterface ()
 This is a newer variant of the contextMenu where the dataBlockContext is provided as selectors instead of composite ids. More...
Protected Slots
void hide ()
 called to hide the representation. More...
void reprTypeChanged (QAction *action)
 called to change the representation type. More...
void colorMenuTriggered (QAction *action)
 called to change the coloring mode. More...
void showAllBlocks () const
 called to show all blocks. More...
virtual void buildColorFieldsMenu (pqPipelineRepresentation *pipelineRepr, QMenu *menu) const
 called to build the color arrays submenu. More...
QPoint Position
QPointer< pqDataRepresentation > PickedRepresentation
It has priority 0, so you can modify the QMenu it creates by using a lower (negative) priority in your own custom interface. You can eliminate the default menu by assigning your custom interface a positive priority and have its contextMenu() method return true.
See also
pqPipelineContextMenuBehavior
Definition at line 30 of file pqDefaultContextMenu.h.
◆ pqDefaultContextMenu()
pqDefaultContextMenu::pqDefaultContextMenu ( QObject *  parent = nullptr)
◆ ~pqDefaultContextMenu()
pqDefaultContextMenu::~pqDefaultContextMenu ( )
override
◆ contextMenu() [1/3]
bool pqDefaultContextMenu::contextMenu ( QMenu *  menu,
pqView *  viewContext,
const QPoint &  viewPoint,
pqRepresentation *  dataContext,
const QList< unsigned int > &  dataBlockContext
) const
It will always return false (i.e., allow lower-priority menus to append/modify its output).
Reimplemented from pqContextMenuInterface.
◆ priority()
int pqDefaultContextMenu::priority ( ) const
inlineoverridevirtual
Definition at line 57 of file pqDefaultContextMenu.h.
◆ hide
void pqDefaultContextMenu::hide ( )
protectedslot
◆ reprTypeChanged
void pqDefaultContextMenu::reprTypeChanged ( QAction *  action)
protectedslot
◆ colorMenuTriggered
void pqDefaultContextMenu::colorMenuTriggered ( QAction *  action)
protectedslot
◆ showAllBlocks
void pqDefaultContextMenu::showAllBlocks ( ) const
protectedslot
◆ buildColorFieldsMenu()
virtual void pqDefaultContextMenu::buildColorFieldsMenu ( pqPipelineRepresentation *  pipelineRepr,
QMenu *  menu
) const
protectedvirtual
◆ contextMenu() [2/3]
virtual bool pqContextMenuInterface::contextMenu
◆ contextMenu() [3/3]
◆ Position
QPoint pqDefaultContextMenu::Position
mutableprotected
Definition at line 87 of file pqDefaultContextMenu.h.
◆ PickedRepresentation
QPointer<pqDataRepresentation> pqDefaultContextMenu::PickedRepresentation
mutableprotected
Definition at line 88 of file pqDefaultContextMenu.h.
