Public Member Functions | Protected Slots | Protected Member Functions | Protected Attributes | List of all members
pqPipelineContextMenuBehavior Class Reference
#include <pqPipelineContextMenuBehavior.h>
Inherits QObject.
 pqPipelineContextMenuBehavior (QObject *parent=nullptr)
 ~pqPipelineContextMenuBehavior () override
Protected Slots
void onViewAdded (pqView *)
 Called when a new view is added. More...
virtual void buildMenu (pqDataRepresentation *repr, unsigned int blockIndex, int rank)
 called to build the context menu for the given representation. More...
bool eventFilter (QObject *caller, QEvent *e) override
 event filter to capture the right-click. More...
QMenu * Menu
QPoint Position
This behavior manages showing up of a context menu with sensible pipeline related actions for changing color/visibility etc. when the user right-clicks on top of an object in the 3D view. Currently, it only supports views with proxies that vtkSMRenderViewProxy subclasses.
Definition at line 29 of file pqPipelineContextMenuBehavior.h.
◆ pqPipelineContextMenuBehavior()
pqPipelineContextMenuBehavior::pqPipelineContextMenuBehavior ( QObject *  parent = nullptr)
◆ ~pqPipelineContextMenuBehavior()
pqPipelineContextMenuBehavior::~pqPipelineContextMenuBehavior ( )
override
◆ onViewAdded
void pqPipelineContextMenuBehavior::onViewAdded ( pqView *  )
protectedslot
We add actions to the widget for context menu if the view is a render-view.
◆ buildMenu()
virtual void pqPipelineContextMenuBehavior::buildMenu ( pqDataRepresentation *  repr,
int  rank
protectedvirtual
If the picked representation was a composite data set the block index of the selected block will be passed in blockIndex.
With introduction of vtkPartitionedDataSetCollection and vtkPartitionedDataSet, flatIndex is no longer consistent across ranks and hence rank is also returned. Unless dealing with these data types, rank can be ignored.
◆ eventFilter()
bool pqPipelineContextMenuBehavior::eventFilter ( QObject *  caller,
QEvent *  e
We don't directly use mechanisms from QWidget to popup the context menu since all of those mechanism seem to eat away the right button release, leaving the render window in a dragging state.
◆ Menu
QMenu* pqPipelineContextMenuBehavior::Menu
Definition at line 67 of file pqPipelineContextMenuBehavior.h.
◆ Position
QPoint pqPipelineContextMenuBehavior::Position
Definition at line 68 of file pqPipelineContextMenuBehavior.h.
