Interface class for plugins that add a context menu to pqViews. More...
#include <pqContextMenuInterface.h>
| pqContextMenuInterface () | |
| virtual | ~pqContextMenuInterface () |
| virtual bool | contextMenu (QMenu *menu, pqView *viewContext, const QPoint &viewPoint, pqRepresentation *dataContext, const QList< unsigned int > &dataBlockContext) const |
| This method is called when a context menu is requested, usually by a right click in a pqView instance. More... | |
| virtual bool | contextMenu (QMenu *menu, pqView *viewContext, const QPoint &viewPoint, pqRepresentation *dataContext, const QStringList &dataBlockContext) const |
| This is a newer variant of the contextMenu where the dataBlockContext is provided as selectors instead of composite ids. More... | |
| virtual int | priority () const |
| This method's return value is used to set the precedence of the interface. More... | |
pqContextMenuInterface is the interface which plugins adding a context menu to pqViews should implement. One would typically use the add_paraview_context_menu CMake macro to ensure an instance of the class is created and registered with the pqPipelineContextMenuBehavior class (which is responsible for creating the context menu).
Definition at line 25 of file pqContextMenuInterface.h.
| pqContextMenuInterface::pqContextMenuInterface | ( | ) |
This method should return true if (a) the context is one handled by this instance (and presumably it will modify the provided QMenu); and (b) this instance should be the last interface to contribute to the menu. Returning false indicates the context is not one this instance handles or that interfaces with a lower priority may modify the menu.
Each registered interface is called in order of descending priority until one returns true, so your implementation should return false as quickly as possible.
If dataContext is a pqDataRepresentation and holds multiblock data, the dataBlockContext is a list of block IDs to which the menu actions should apply.
Reimplemented in pqDefaultContextMenu.
Selectors are more reliable especially when dealing with partitioned datasets and their collections in distributed mode and hence should be preferred.
Reimplemented in pqBlockContextMenu.
inlinevirtual |
Interfaces with greater priority are invoked before others and may cause menu-building to terminate early. ParaView's default context-menu interface uses a priority of 0 and returns false.
If you wish to modify the default menu, assign a negative priority to your interface. If you wish to override the default menu, assign a positive priority to your interface and have contextMenu() return true.
Reimplemented in pqDefaultContextMenu, and pqBlockContextMenu.
Definition at line 70 of file pqContextMenuInterface.h.
