pqCoreConfiguration Class Reference
runtime configuration options for ParaView Qt client More...
#include <pqCoreConfiguration.h>
Inherits QObject.
const std::string & stateFileName () const
 Returns state file to load on startup, if any. More...
const std::vector< std::string > & dataFileNames () const
 Returns data file to load on startup, if any. More...
const std::string & pythonScript () const
 Returns the Python script to load on startup, if any. More...
const std::string & baselineDirectory () const
 Returns directory where to output test results and temporary files, if any else an empty string is returned. More...
const std::string & testDirectory () const
const std::string & dataDirectory () const
 Returns directory containing test data files, if any, else an empty string is returned. More...
bool exitApplicationWhenTestsDone () const
 Returns true if the application should exit after test playback is complete. More...
int catalystLivePort () const
 When specified, ParaView will attempt to connect a Catalyst Live session at the given port. More...
bool populateOptions (vtkCLIOptions *options)
 Populate vtkCLIOptions instance with command line options to control the configurable options provided by this class. More...
int testScriptCount () const
 Returns information about tests scripts. More...
const std::string & testScript (int index) const
const std::string & testBaseline (int index) const
int testThreshold (int index) const
void setActiveTestIndex (int index)
 A little bit of hack to activate a particular test script. More...
const std::string & testScript () const
const std::string & testBaseline () const
int testThreshold () const
bool testMaster () const
 Collaboration testing related flags. More...
bool testSlave () const
static pqCoreConfiguration * instance ()
 Provides access to the singleton. More...
 pqCoreConfiguration ()
 ~pqCoreConfiguration () override
class pqPVApplicationCore
void addDataFile (const std::string &data)
pqCoreConfiguration is a singleton that maintains runtime configuration options for the ParaView Qt client.
See also
vtkCLIOptions, vtkRemotingCoreConfiguration, vtkProcessModuleConfiguration
Definition at line 25 of file pqCoreConfiguration.h.
◆ pqCoreConfiguration()
pqCoreConfiguration::pqCoreConfiguration ( )
◆ ~pqCoreConfiguration()
pqCoreConfiguration::~pqCoreConfiguration ( )
◆ instance()
static pqCoreConfiguration* pqCoreConfiguration::instance ( )
◆ stateFileName()
const std::string& pqCoreConfiguration::stateFileName ( ) const
inline
Definition at line 37 of file pqCoreConfiguration.h.
◆ dataFileNames()
const std::vector<std::string>& pqCoreConfiguration::dataFileNames ( ) const
inline
Definition at line 42 of file pqCoreConfiguration.h.
◆ pythonScript()
const std::string& pqCoreConfiguration::pythonScript ( ) const
inline
Definition at line 47 of file pqCoreConfiguration.h.
◆ baselineDirectory()
const std::string& pqCoreConfiguration::baselineDirectory ( ) const
inline
Definition at line 53 of file pqCoreConfiguration.h.
◆ testDirectory()
const std::string& pqCoreConfiguration::testDirectory ( ) const
inline
Definition at line 59 of file pqCoreConfiguration.h.
◆ dataDirectory()
const std::string& pqCoreConfiguration::dataDirectory ( ) const
inline
Definition at line 65 of file pqCoreConfiguration.h.
◆ testScriptCount()
int pqCoreConfiguration::testScriptCount ( ) const
inline
Definition at line 71 of file pqCoreConfiguration.h.
◆ testScript() [1/2]
const std::string& pqCoreConfiguration::testScript ( int  index) const
inline
Definition at line 72 of file pqCoreConfiguration.h.
◆ testBaseline() [1/2]
const std::string& pqCoreConfiguration::testBaseline ( int  index) const
inline
Definition at line 73 of file pqCoreConfiguration.h.
◆ testThreshold() [1/2]
int pqCoreConfiguration::testThreshold ( int  index) const
inline
Definition at line 74 of file pqCoreConfiguration.h.
◆ exitApplicationWhenTestsDone()
bool pqCoreConfiguration::exitApplicationWhenTestsDone ( ) const
inline
Definition at line 81 of file pqCoreConfiguration.h.
◆ catalystLivePort()
int pqCoreConfiguration::catalystLivePort ( ) const
inline
Definition at line 87 of file pqCoreConfiguration.h.
◆ populateOptions()
bool pqCoreConfiguration::populateOptions ( vtkCLIOptions *  options)
◆ setActiveTestIndex()
void pqCoreConfiguration::setActiveTestIndex ( int  index)
inline
Definition at line 99 of file pqCoreConfiguration.h.
◆ testScript() [2/2]
const std::string& pqCoreConfiguration::testScript ( ) const
inline
Definition at line 100 of file pqCoreConfiguration.h.
◆ testBaseline() [2/2]
const std::string& pqCoreConfiguration::testBaseline ( ) const
inline
Definition at line 101 of file pqCoreConfiguration.h.
◆ testThreshold() [2/2]
int pqCoreConfiguration::testThreshold ( ) const
inline
Definition at line 102 of file pqCoreConfiguration.h.
◆ testMaster()
bool pqCoreConfiguration::testMaster ( ) const
inline
Definition at line 109 of file pqCoreConfiguration.h.
◆ testSlave()
bool pqCoreConfiguration::testSlave ( ) const
inline
Definition at line 110 of file pqCoreConfiguration.h.
◆ addDataFile()
void pqCoreConfiguration::addDataFile ( const std::string &  data)
inlineprotected
Definition at line 121 of file pqCoreConfiguration.h.
◆ pqPVApplicationCore
friend class pqPVApplicationCore
friend
Definition at line 120 of file pqCoreConfiguration.h.
