4 #ifndef pqCoreConfiguration_h
5 #define pqCoreConfiguration_h
7 #include "pqCoreModule.h"
37 const std::string&
stateFileName()
const {
return this->StateFileName; }
42 const std::vector<std::string>&
dataFileNames()
const {
return this->DataFileNames; }
47 const std::string&
pythonScript()
const {
return this->PythonScript; }
59 const std::string&
testDirectory()
const {
return this->TestDirectory; }
65 const std::string&
dataDirectory()
const {
return this->DataDirectory; }
72 const std::string&
testScript(
int index)
const {
return this->TestScripts.at(
index).FileName; }
73 const std::string&
testBaseline(
int index)
const {
index).Baseline; }
127 std::string StateFileName;
128 std::vector<std::string> DataFileNames;
129 std::vector<std::string> PositionalFileNames;
130 std::string PythonScript;
131 std::string BaselineDirectory;
132 std::string TestDirectory;
133 std::string DataDirectory;
134 bool ExitAppWhenTestsDone;
135 int ActiveTestIndex = 0;
136 int CatalystLivePort = -1;
137 bool TestMaster =
false;
138 bool TestSlave =
false;
140 struct TestScriptInfo
142 std::string FileName;
143 std::string Baseline;
146 QVector<TestScriptInfo> TestScripts;
bool exitApplicationWhenTestsDone() const
Returns true if the application should exit after test playback is complete.
const std::string & testBaseline(int index) const
Returns information about tests scripts.
command line options manager
pqPVApplicationCore is the application code used by ParaView-based applications that use more of Para...
int testThreshold() const
A little bit of hack to activate a particular test script.
int Threshold(vtkDataSet *input, vtkUnstructuredGrid *output, vtkDataArray *field, double lower, double upper)
int testScriptCount() const
bool testMaster() const
Collaboration testing related flags.
const std::string & testBaseline() const
runtime configuration options for ParaView Qt client
const std::string & dataDirectory() const
Returns directory containing test data files, if any, else an empty string is returned.
int catalystLivePort() const
When specified, ParaView will attempt to connect a Catalyst Live session at the given port.
const std::string & stateFileName() const
Returns state file to load on startup, if any.
int testThreshold(int index) const
const std::string & pythonScript() const
Returns the Python script to load on startup, if any.
bool testSlave() const
const std::vector< std::string > & dataFileNames() const
Returns data file to load on startup, if any.
void addDataFile(const std::string &data)
void setActiveTestIndex(int index)
const std::string & testScript(int index) const
const std::string & baselineDirectory() const
Returns directory where to output test results and temporary files, if any else an empty string is re...
const std::string & testScript() const
const std::string & testDirectory() const
