vtkRemotingCoreConfiguration Class Reference
runtime configuration options for vtkRemotingCore module. More...
#include <vtkRemotingCoreConfiguration.h>
Inheritance diagram for vtkRemotingCoreConfiguration:
Collaboration diagram for vtkRemotingCoreConfiguration:
virtual bool GetTellVersion ()
 Flag set when user expects the executable to simply print out the version number and exit. More...
virtual bool GetDisableRegistry ()
 Get whether to load user-specific session/configuration files from previous session or start the application using default configuration. More...
virtual bool GetPrintMonitors ()
 Print monitor information and exit. More...
const std::string & GetHostName () const
 Get the hostname to use. More...
const std::string & GetClientHostName () const
 Get the hostname for the "client" process. More...
virtual int GetServerPort ()
 Get the server-port number to use. More...
virtual bool GetReverseConnection ()
 Get if the process is acting in reverse connection mode. More...
virtual int GetConnectID ()
 Returns the connection identifier used to validate client-server connections. More...
virtual void SetConnectID (int)
virtual int GetTimeout ()
 On server processes, this denotes the time (in minutes) since the time that the connection was established with the server that the server may timeout. More...
const std::string & GetTimeoutCommand () const
 Get the timeout command, called regularly on server side and giving remaining time available for server access. More...
virtual int GetTimeoutCommandInterval ()
 On server processes, the interval in seconds between consecutive calls of TimeoutCommand. More...
const std::string & GetServerURL () const
 On client processes, this returns the server connection url to use to connect to the server process(es) on startup, if any. More...
const std::string & GetServerResourceName () const
 On client processes, this returns the server connection resource name to use to connect to the server process(es) on startup, if any. More...
const std::vector< std::string > & GetServerConfigurationsFiles () const
 On client processes, this provides list of server configurations files to use instead of the default user-specific server configurations file. More...
const std::vector< std::string > & GetPluginSearchPaths () const
 Get a list of paths to add to plugin search paths. More...
const std::vector< std::string > & GetPlugins () const
 Get a list of names for plugins to load. More...
virtual bool GetUseStereoRendering ()
 Get whether stereo rendering is enabled. More...
virtual int GetStereoType ()
 Get stereo type requested. More...
const char * GetStereoTypeAsString () const
double GetEyeSeparation () const
 Eye separation to use when using stereo rendering. More...
virtual int * GetTileMullions ()
 Get the gap in pixel between tiles in a tile display. More...
virtual void GetTileMullions (int &, int &)
virtual void GetTileMullions (int[2])
void GetTileDimensions (int dims[2])
 Get the dimensions of the tile display. More...
const int * GetTileDimensions ()
bool GetIsInTileDisplay () const
 Returns true if in tile display mode. More...
bool GetIsInCave () const
 Returns true of in CAVE mode. More...
vtkDisplayConfiguration * GetDisplayConfiguration () const
 When in CAVE mode, returns the display configurations. More...
virtual bool GetDisableXDisplayTests ()
 XDisplay test on server processes during initialization sometimes happens too early and may result in remote rendering prematurely disabled. More...
virtual bool GetForceOffscreenRendering ()
 When set to true, ParaView will create headless only render windows on the current process. More...
virtual bool GetForceOnscreenRendering ()
 When set to true, ParaView will create on-screen render windows. More...
int GetEGLDeviceIndex ()
 Returns the EGL device index for the current process. More...
std::string GetDisplay ()
 Returns the display setting, if any, for the current process. More...
virtual bool GetMultiServerMode ()
 Returns true on client process if it should enable connecting to multiple servers at the same time. More...
virtual bool GetMultiClientMode ()
 Returns true data server process if the server should allow connecting to multiple clients in a collaboration mode. More...
virtual bool GetDisableFurtherConnections ()
 Returns if this server does not allow connection after the first client. More...
bool PopulateOptions (vtkCLIOptions *app, vtkProcessModule::ProcessTypes processType)
 Populates vtkCLIOptions with available command line options. More...
bool PopulateGlobalOptions (vtkCLIOptions *app, vtkProcessModule::ProcessTypes processType)
bool PopulateConnectionOptions (vtkCLIOptions *app, vtkProcessModule::ProcessTypes processType)
bool PopulatePluginOptions (vtkCLIOptions *app, vtkProcessModule::ProcessTypes processType)
bool PopulateRenderingOptions (vtkCLIOptions *app, vtkProcessModule::ProcessTypes processType)
bool PopulateMiscellaneousOptions (vtkCLIOptions *app, vtkProcessModule::ProcessTypes processType)
void HandleDisplayEnvironment ()
 Method to setup environment variables for display. More...
static vtkRemotingCoreConfiguration * SafeDownCast (vtkObject *o)
static vtkRemotingCoreConfiguration * GetInstance ()
 Provides access to the singleton. More...
 vtkRemotingCoreConfiguration ()
 ~vtkRemotingCoreConfiguration () override
vtkRemotingCoreConfiguration is a singleton that maintains runtime configuration for the process. These can be thought of as options settable by command line arguments and hence are initialized when the process launches and are not changed during the lifetime of the process.
vtkRemotingCoreConfiguration can be setup via command line arguments. For that, create a vtkCLIOptions object and populate it using PopulateOptions method. vtkCLIOptions can then pass command line arguments for parsing.
Definition at line 30 of file vtkRemotingCoreConfiguration.h.
Definition at line 33 of file vtkRemotingCoreConfiguration.h.
◆ vtkRemotingCoreConfiguration()
vtkRemotingCoreConfiguration::vtkRemotingCoreConfiguration ( )
◆ ~vtkRemotingCoreConfiguration()
vtkRemotingCoreConfiguration::~vtkRemotingCoreConfiguration ( )
virtual const char* vtkRemotingCoreConfiguration::GetClassName ( )
static int vtkRemotingCoreConfiguration::IsTypeOf ( const char *  type)
virtual int vtkRemotingCoreConfiguration::IsA ( const char *  type)
static vtkRemotingCoreConfiguration* vtkRemotingCoreConfiguration::SafeDownCast ( vtkObject *  o)
void vtkRemotingCoreConfiguration::PrintSelf ( ostream &  os,
◆ GetInstance()
static vtkRemotingCoreConfiguration* vtkRemotingCoreConfiguration::GetInstance ( )
◆ GetTellVersion()
virtual bool vtkRemotingCoreConfiguration::GetTellVersion ( )
◆ GetDisableRegistry()
virtual bool vtkRemotingCoreConfiguration::GetDisableRegistry ( )
◆ GetPrintMonitors()
virtual bool vtkRemotingCoreConfiguration::GetPrintMonitors ( )
This is currently only supported on Windows.
◆ GetHostName()
const std::string& vtkRemotingCoreConfiguration::GetHostName ( ) const
inline
By default, this is initialized to the hostname determined automatically using system calls (specifically, vtksys::SystemInformation).
Definition at line 72 of file vtkRemotingCoreConfiguration.h.
◆ GetClientHostName()
const std::string& vtkRemotingCoreConfiguration::GetClientHostName ( ) const
inline
This is used by server processes when in reverse-connection mode to determine where the client can be reached. Default is "localhost".
Definition at line 79 of file vtkRemotingCoreConfiguration.h.
◆ GetServerPort()
virtual int vtkRemotingCoreConfiguration::GetServerPort ( )
This is the port number that a server-process is expected to use as the 'listening' port. For reverse-connection, this is the port number that the client process is listening on.
◆ GetReverseConnection()
virtual bool vtkRemotingCoreConfiguration::GetReverseConnection ( )
This flag is only read on the server processes since client is capable of supported reverse and non-reverse connections in the same process.
◆ GetConnectID()
virtual int vtkRemotingCoreConfiguration::GetConnectID ( )
◆ SetConnectID()
virtual void vtkRemotingCoreConfiguration::SetConnectID ( int  )
Note
This API may change in future. This is left as is for now to keep changes in this MR to a minimal.
◆ GetTimeout()
virtual int vtkRemotingCoreConfiguration::GetTimeout ( )
timeout <= 0 means no timeout.
◆ GetTimeoutCommand()
const std::string& vtkRemotingCoreConfiguration::GetTimeoutCommand ( ) const
inline
Definition at line 119 of file vtkRemotingCoreConfiguration.h.
◆ GetTimeoutCommandInterval()
virtual int vtkRemotingCoreConfiguration::GetTimeoutCommandInterval ( )
◆ GetServerURL()
const std::string& vtkRemotingCoreConfiguration::GetServerURL ( ) const
inline
See also
Definition at line 132 of file vtkRemotingCoreConfiguration.h.
◆ GetServerResourceName()
const std::string& vtkRemotingCoreConfiguration::GetServerResourceName ( ) const
inline
Definition at line 138 of file vtkRemotingCoreConfiguration.h.
◆ GetServerConfigurationsFiles()
const std::vector<std::string>& vtkRemotingCoreConfiguration::GetServerConfigurationsFiles ( ) const
inline
Definition at line 144 of file vtkRemotingCoreConfiguration.h.
◆ GetPluginSearchPaths()
const std::vector<std::string>& vtkRemotingCoreConfiguration::GetPluginSearchPaths ( ) const
inline
Any plugin requested by name will be searched under these paths.
Definition at line 158 of file vtkRemotingCoreConfiguration.h.
◆ GetPlugins()
const std::vector<std::string>& vtkRemotingCoreConfiguration::GetPlugins ( ) const
inline
Definition at line 163 of file vtkRemotingCoreConfiguration.h.
◆ GetUseStereoRendering()
virtual bool vtkRemotingCoreConfiguration::GetUseStereoRendering ( )
This is only valid on rendering processes.
◆ GetStereoType()
virtual int vtkRemotingCoreConfiguration::GetStereoType ( )
Returned values are VTK_STEREO_* defined in vtkRenderWindow.h.
◆ GetStereoTypeAsString()
const char* vtkRemotingCoreConfiguration::GetStereoTypeAsString ( ) const
◆ GetEyeSeparation()
double vtkRemotingCoreConfiguration::GetEyeSeparation ( ) const
◆ GetTileMullions() [1/3]
virtual int* vtkRemotingCoreConfiguration::GetTileMullions ( )
◆ GetTileMullions() [2/3]
virtual void vtkRemotingCoreConfiguration::GetTileMullions ( int &  ,
int &
◆ GetTileMullions() [3/3]
virtual void vtkRemotingCoreConfiguration::GetTileMullions ( int  [2])
◆ GetTileDimensions() [1/2]
void vtkRemotingCoreConfiguration::GetTileDimensions ( int  dims[2])
◆ GetTileDimensions() [2/2]
const int* vtkRemotingCoreConfiguration::GetTileDimensions ( )
◆ GetIsInTileDisplay()
bool vtkRemotingCoreConfiguration::GetIsInTileDisplay ( ) const
◆ GetIsInCave()
bool vtkRemotingCoreConfiguration::GetIsInCave ( ) const
◆ GetDisplayConfiguration()
vtkDisplayConfiguration* vtkRemotingCoreConfiguration::GetDisplayConfiguration ( ) const
inline
Definition at line 212 of file vtkRemotingCoreConfiguration.h.
◆ GetDisableXDisplayTests()
virtual bool vtkRemotingCoreConfiguration::GetDisableXDisplayTests ( )
When this flag is set, ParaView will skip such X-display tests. Note, if the display is truly inaccessible when ParaView tries to connect to the server, we will indeed get runtimes errors, including segfaults.
◆ GetForceOffscreenRendering()
virtual bool vtkRemotingCoreConfiguration::GetForceOffscreenRendering ( )
◆ GetForceOnscreenRendering()
virtual bool vtkRemotingCoreConfiguration::GetForceOnscreenRendering ( )
◆ GetEGLDeviceIndex()
int vtkRemotingCoreConfiguration::GetEGLDeviceIndex ( )
This uses vtkMultiProcessController::GetLocalProcessId to determine the rank of the process. -1 indicates no index was specified.
◆ GetDisplay()
std::string vtkRemotingCoreConfiguration::GetDisplay ( )
◆ GetMultiServerMode()
virtual bool vtkRemotingCoreConfiguration::GetMultiServerMode ( )
◆ GetMultiClientMode()
virtual bool vtkRemotingCoreConfiguration::GetMultiClientMode ( )
◆ GetDisableFurtherConnections()
virtual bool vtkRemotingCoreConfiguration::GetDisableFurtherConnections ( )
This requires MultiClientMode.
◆ PopulateOptions()
bool vtkRemotingCoreConfiguration::PopulateOptions ( vtkCLIOptions *  app,
processType indicates which type of ParaView process the options are being setup for. That may affect available options.
◆ PopulateGlobalOptions()
bool vtkRemotingCoreConfiguration::PopulateGlobalOptions ( vtkCLIOptions *  app,
◆ PopulateConnectionOptions()
bool vtkRemotingCoreConfiguration::PopulateConnectionOptions ( vtkCLIOptions *  app,
◆ PopulatePluginOptions()
bool vtkRemotingCoreConfiguration::PopulatePluginOptions ( vtkCLIOptions *  app,
◆ PopulateRenderingOptions()
bool vtkRemotingCoreConfiguration::PopulateRenderingOptions ( vtkCLIOptions *  app,
◆ PopulateMiscellaneousOptions()
bool vtkRemotingCoreConfiguration::PopulateMiscellaneousOptions ( vtkCLIOptions *  app,
◆ HandleDisplayEnvironment()
void vtkRemotingCoreConfiguration::HandleDisplayEnvironment ( )
