vtkProcessModuleConfiguration Class Reference
runtime configuration for vtkProcessModule More...
#include <vtkProcessModuleConfiguration.h>
Inheritance diagram for vtkProcessModuleConfiguration:
Collaboration diagram for vtkProcessModuleConfiguration:
virtual bool GetForceMPIInit ()
 Get whether to call MPI_Init() on this process irrespective of whether MPI is needed on this process. More...
virtual bool GetForceNoMPIInit ()
 Get whether to not call MPI_Init() on this process irrespective of whether MPI is needed on this process. More...
virtual bool GetUseMPISSend ()
 Flag indicating whether to use synchronous send (SSend) for MPI communication. More...
virtual bool GetSymmetricMPIMode ()
 Get whether to use symmetric MPI mode. More...
virtual void SetSymmetricMPIMode (bool)
 Ideally, this method should not be public. More...
virtual vtkLogger::Verbosity GetLogStdErrVerbosity ()
 Get the verbosity level to use for reporting log messages on stderr. More...
std::string GetCSLogFileName () const
 Get the filename to use to generate client-server-stream logs, if any. More...
virtual bool GetEnableStackTrace ()
 Get whether to generate a stack trace after a crash. More...
const std::vector< std::pair< std::string, vtkLogger::Verbosity > > & GetLogFiles () const
 Returns a vector of pairs for log files requested. More...
bool PopulateOptions (vtkCLIOptions *options, vtkProcessModule::ProcessTypes processType)
 Populate command line options. More...
static vtkProcessModuleConfiguration * SafeDownCast (vtkObject *o)
static vtkProcessModuleConfiguration * GetInstance ()
 Provides access to the singleton. More...
static std::string GetRankAnnotatedFileName (const std::string &fname)
 A helper function to add a rank number to the filename, if needed. More...
 vtkProcessModuleConfiguration ()
 ~vtkProcessModuleConfiguration () override
vtkProcessModuleConfiguration is a singleton that maintains runtime configuration options that affect how vtkProcessModule is initialized.
Definition at line 24 of file vtkProcessModuleConfiguration.h.
Definition at line 27 of file vtkProcessModuleConfiguration.h.
◆ vtkProcessModuleConfiguration()
vtkProcessModuleConfiguration::vtkProcessModuleConfiguration ( )
◆ ~vtkProcessModuleConfiguration()
vtkProcessModuleConfiguration::~vtkProcessModuleConfiguration ( )
virtual const char* vtkProcessModuleConfiguration::GetClassName ( )
static int vtkProcessModuleConfiguration::IsTypeOf ( const char *  type)
virtual int vtkProcessModuleConfiguration::IsA ( const char *  type)
static vtkProcessModuleConfiguration* vtkProcessModuleConfiguration::SafeDownCast ( vtkObject *  o)
void vtkProcessModuleConfiguration::PrintSelf ( ostream &  os,
◆ GetInstance()
static vtkProcessModuleConfiguration* vtkProcessModuleConfiguration::GetInstance ( )
◆ GetForceMPIInit()
virtual bool vtkProcessModuleConfiguration::GetForceMPIInit ( )
◆ GetForceNoMPIInit()
virtual bool vtkProcessModuleConfiguration::GetForceNoMPIInit ( )
◆ GetUseMPISSend()
virtual bool vtkProcessModuleConfiguration::GetUseMPISSend ( )
◆ GetSymmetricMPIMode()
virtual bool vtkProcessModuleConfiguration::GetSymmetricMPIMode ( )
In this mode is only supported in "batch". In that case, all processes, including the satellites, execute the Python script locally.
◆ SetSymmetricMPIMode()
virtual void vtkProcessModuleConfiguration::SetSymmetricMPIMode ( bool  )
However, we are keeping it public to avoid changing to much code at this time.
◆ GetLogStdErrVerbosity()
virtual vtkLogger::Verbosity vtkProcessModuleConfiguration::GetLogStdErrVerbosity ( )
In other words, all messages at the chosen level and higher are posted to stderr. Default is vtkLogger::VERBOSITY_INVALID.
◆ GetCSLogFileName()
std::string vtkProcessModuleConfiguration::GetCSLogFileName ( ) const
If running in a distributed mode, the filename is automatically changed to include current rank index.
◆ GetEnableStackTrace()
virtual bool vtkProcessModuleConfiguration::GetEnableStackTrace ( )
This is currently only supported on POSIX systems.
◆ GetLogFiles()
const std::vector<std::pair<std::string, vtkLogger::Verbosity> >& vtkProcessModuleConfiguration::GetLogFiles ( ) const
inline
Definition at line 89 of file vtkProcessModuleConfiguration.h.
◆ PopulateOptions()
bool vtkProcessModuleConfiguration::PopulateOptions ( vtkCLIOptions *  options,
processType indicates which type of ParaView process the options are being setup for. That may affect available options.
◆ GetRankAnnotatedFileName()
static std::string vtkProcessModuleConfiguration::GetRankAnnotatedFileName ( const std::string &  fname)
This is useful to create a separate log file per rank, for example, when executing in parallel. If number of ranks is 1, the filename is unchanged.
