1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Remoting/ApplicationComponents 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
40 # Set path to fallback-tool for dependency-resolution. 41 if(NOT DEFINED CMAKE_OBJDUMP)
42 set(CMAKE_OBJDUMP
"/usr/sbin/objdump")
46 file(INSTALL DESTINATION
"vtkRemotingApplicationComponents-hierarchy.txt" FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkRemotingApplicationComponents-hierarchy.txt")
51 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingApplicationComponents-pv6.2.so.6.2
" 52 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingApplicationComponents-pv6.2.so.1
" 54 if(EXISTS "${file}
") 58 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
" TYPE SHARED_LIBRARY FILES 62 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingApplicationComponents-pv6.2.so.6.2
" 63 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingApplicationComponents-pv6.2.so.1
" 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingApplicationComponents-pv6.2.so.6.2
" 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingApplicationComponents-pv6.2.so.1
" 69 if(EXISTS "${file}
") 73 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 74 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 75 if(CMAKE_INSTALL_DO_STRIP) 76 execute_process(COMMAND "/usr/sbin/strip
" "${file}
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingApplicationComponents-pv6.2.so
" TYPE FILE FILES 101 "/builds/gitlab-kitware-sciviz-ci/Remoting/ApplicationComponents/
vtkShowDecorator.h
" 105 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 106 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Remoting/ApplicationComponents/vtkRemotingApplicationComponentsModule.h
") 109 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 110 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Remoting/ApplicationComponents/vtkRemotingApplicationComponents.spdx
") 113 string(REPLACE ";
" "\n
" CMAKE_INSTALL_MANIFEST_CONTENT 114 "${CMAKE_INSTALL_MANIFEST_FILES}
") 115 if(CMAKE_INSTALL_LOCAL_ONLY) 116 file(WRITE "/builds/gitlab-kitware-sciviz-ci/build/Remoting/ApplicationComponents/install_local_manifest.txt
" 117 "${CMAKE_INSTALL_MANIFEST_CONTENT}
") vtkSessionTypeDecorator is a vtkPropertyDecorator subclass that can be used to control show/hide or e...
vtkEnableDecorator can be used to enable/disable a widget based on the status of another property not...
vtkOSPRayHidingDecorator's purpose is to prevent the GUI from showing any of the RayTracing specific ...
vtkMultiComponentsDecorator's purpose is to prevent the GUI from showing Multi Components Mapping che...
vtkPropertyDecorator hold the logic of pqPropertyDecorator TODO provides a mechanism to decorate pqPr...
vtkANARIHidingDecorator's purpose is to prevent the GUI from showing any of the ANARI specific render...
vtkBoolPropertyDecorator is a base class for enable/disable or show/hide widgets based on the status ...
vtkShowDecorator can be used to show/hide a widget based on the status of another property not direct...
vtkGenericPropertyDecorator is a vtkPropertyDecorator that supports multiple common use cases from a ...
vtkPropertyDecorator subclass that can combine multiple decorators using boolean operations.
