| void | Initialize (vtkPVXMLElement *config, vtkSMProxy *proxy) override |
| | Constructor. More...
| bool | Enable () const override |
| | Overridden to enable/disable the widget based on input data type. More...
| bool | CanShow (bool showAdvanced) const override |
| | Overriden to show or not the widget based on input data type. More...
| virtual bool | CanShow (bool vtkNotUsed(showAdvanced)) const |
| | Override this method to override the visibility of the widget in the panel. More...
vtkInputDataTypeDecorator is a vtkPropertyWidgetDecorator subclass.
For certain properties, they should update the enable state based on input data types. For example, "Computer Gradients" in Contour filter should only be enabled when an input data type is a StructuredData. Please see vtkPVDataInformation::IsDataStructured() for structured types.
Definition at line 20 of file vtkInputDataTypeDecorator.h.
