vtkCompositePropertyDecorator Class Reference
vtkPropertyDecorator subclass that can combine multiple decorators using boolean operations. More...
#include <vtkCompositePropertyDecorator.h>
Inheritance diagram for vtkCompositePropertyDecorator:
Collaboration diagram for vtkCompositePropertyDecorator:
typedef vtkPropertyDecorator Superclass
using DecoratorCreationFunction = std::function< vtkSmartPointer< vtkPropertyDecorator >(vtkPVXMLElement *, vtkSMProxy *)>
- Public Types inherited from vtkPropertyDecorator
enum  { VisibilityChangedEvent = vtkCommand::UserEvent + 1000, EnableStateChangedEvent = vtkCommand::UserEvent + 1001 }
 This event is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More...
void Initialize (vtkPVXMLElement *config, vtkSMProxy *proxy) override
 Constructor. More...
bool CanShow (bool showAdvanced) const override
bool Enable () const override
 Override this method to override the enable state of the widget in the panel. More...
void RegisterDecorator (DecoratorCreationFunction func)
- Public Member Functions inherited from vtkPropertyDecorator
virtual bool CanShow (bool vtkNotUsed(showAdvanced)) const
 Override this method to override the visibility of the widget in the panel. More...
static vtkCompositePropertyDecoratorNew ()
static vtkCompositePropertyDecoratorSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPropertyDecorator
static vtkPropertyDecoratorNew ()
static vtkPropertyDecoratorSafeDownCast (vtkObject *o)
static vtkSmartPointer< vtkPropertyDecoratorCreate (vtkPVXMLElement *xml, vtkSMProxy *proxy)
 Creates a new decorator, given the xml config and the proxy containing the property For unsupported/unknown, implementations should simply return nullptr without raising any errors (or messages). More...
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkCompositePropertyDecorator ()
 ~vtkCompositePropertyDecorator () override
- Protected Member Functions inherited from vtkPropertyDecorator
 vtkPropertyDecorator ()
 ~vtkPropertyDecorator () override
vtkPVXMLElementXML () const
vtkSMProxyProxy () const
void InvokeVisibilityChangedEvent ()
void InvokeEnableStateChangedEvent ()
vtkCompositePropertyDecorator helps combine multiple decorators using boolean operators as indicated in the example below.
<IntVectorProperty name="Expression1"
number_of_elements="1"
default_values="0">
<BooleanDomain name="bool" />
<Hints>
<!-- Expression === { A and [B or (C and D)] } or E -->
<PropertyWidgetDecorator type="CompositeDecorator">
<Expression type="or">
<Expression type="and">
<PropertyWidgetDecorator type="GenericDecorator" mode="enabled_state" property="A"
value="1" />
<PropertyWidgetDecorator type="GenericDecorator" mode="enabled_state" property="B"
value="1" />
<PropertyWidgetDecorator type="GenericDecorator" mode="enabled_state" property="C"
value="1" />
<PropertyWidgetDecorator type="GenericDecorator" mode="enabled_state" property="D"
value="1" />
</Expression>
</Expression>
</Expression>
<PropertyWidgetDecorator type="GenericDecorator" mode="enabled_state" property="E"
value="1" />
</Expression>
</PropertyWidgetDecorator>
</Hints>
</IntVectorProperty>
Definition at line 51 of file vtkCompositePropertyDecorator.h.
Definition at line 56 of file vtkCompositePropertyDecorator.h.
◆ DecoratorCreationFunction
Definition at line 78 of file vtkCompositePropertyDecorator.h.
◆ vtkCompositePropertyDecorator()
vtkCompositePropertyDecorator::vtkCompositePropertyDecorator ( )
◆ ~vtkCompositePropertyDecorator()
vtkCompositePropertyDecorator::~vtkCompositePropertyDecorator ( )
static vtkCompositePropertyDecorator* vtkCompositePropertyDecorator::New ( )
virtual const char* vtkCompositePropertyDecorator::GetClassName ( )
Reimplemented from vtkPropertyDecorator.
static int vtkCompositePropertyDecorator::IsTypeOf ( const char *  type)
virtual int vtkCompositePropertyDecorator::IsA ( const char *  type)
static vtkCompositePropertyDecorator* vtkCompositePropertyDecorator::SafeDownCast ( vtkObject o)
void vtkCompositePropertyDecorator::PrintSelf ( ostream &  os,
◆ Initialize()
void vtkCompositePropertyDecorator::Initialize ( vtkPVXMLElement xml,
vtkSMProxy proxy
Constructor.
Parameters
xmlThe XML element from the <Hints/> section for the proxy/property that resulted in the creation of the decorator. Decorators can be provided configuration parameters from the XML.
proxyThe proxy that owns the property of this decorator
◆ CanShow()
bool vtkCompositePropertyDecorator::CanShow ( bool  showAdvanced) const
override
◆ Enable()
bool vtkCompositePropertyDecorator::Enable ( ) const
This is called after the generic tests for advanced and text filtering are passed. Since there can be multiple decorators, the first decorator that returns 'false' wins. Default implementation returns true. Thus subclasses typically override this method only to force the widget disabled given the current state.
◆ RegisterDecorator()
void vtkCompositePropertyDecorator::RegisterDecorator ( DecoratorCreationFunction  func)
